Old 07-09-2013, 02:36 PM   #1
blk13SS
blk13SS's Avatar
Drives: '13 1SS LS3 '05 Neon SRT-4
Lets Talk Ethanol
Anyone on here has switched to E85? My '13 SS is currently bone stock, and I will soon be switching to E85. Will my factory injectors be enough to handle the added fuel, or will I need to upgrade them along with the factory fuel pump?
blk13SS is offline   Reply With Quote
Old 07-09-2013, 02:49 PM   #2
FaytalsCamaro
Distributor of Liquor
FaytalsCamaro's Avatar
Drives: My Wife Crazy
I coulda sworn that the e85 eats away at the factory fuel pump lines and youll have to replace them. I could be wrong
FaytalsCamaro is offline   Reply With Quote
Old 07-09-2013, 02:58 PM   #3
cadyshac
It's in the hole!
cadyshac's Avatar
Drives: '11 2SS L99 SGM, '18 2SS, M6, HWSE
First I wouldn't do this and second I have heard that E85 is hard on seals and any rubber it comes in contact with.
I have a Tahoe rated for E85 and I have never used the stuff.
cadyshac is offline   Reply With Quote
Old 07-09-2013, 03:01 PM   #4
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
Everyone says that ethanol decreases mpg and that's both true and not. It doesn't decrease mpg but you instead get less out of it. I believe for ethanol to do the same amount of work regular gas does you need 30% more of it. For that reason you will go through it quicker
Click Picture for Build Thread
lscamaro is offline   Reply With Quote
Old 07-09-2013, 03:13 PM   #5
gajagfan
gajagfan's Avatar
Drives: 2013 1SS 1LE Black - Std Exhaust
It is cheaper by us, but it will not make any more power or torque. Alcohol also tends to be a bit corrosive to internals. I would avoid it. Not worth the $.20 per gallon savings guys!
gajagfan is offline   Reply With Quote
Old 07-09-2013, 03:17 PM   #6
IOM2SSRS
Drives: 2010 Camaro 2SS/RS M6
$0.80 per gallon cheaper here. If you do a conversion or your car is made for it, it is definitely worth it, even if you lose 2-3 mpgs.
IOM2SSRS is offline   Reply With Quote
Old 07-09-2013, 04:01 PM   #7
skipinminn
Chiquita
Drives: 2013 1LE/1SS YELLO1LE 1 of Only 28
Almost a full $1.00 here ~
skipinminn is offline   Reply With Quote
Old 07-09-2013, 04:22 PM   #8
blk13SS
blk13SS's Avatar
My other car is a 2005 Dodge SRT4. Back in 09 I was the 2nd SRT4 in South FL that I know of to switch to E85. Back then ethanol was just being descovered and people were sceptical of it. Once I switched to it I have never looked back. And so have many others switched and become instant fans of E85. 5 years later, my SRT4 is still running strong on ethanol and never will I switch back to pump gas.
Old 07-09-2013, 04:25 PM   #9
blk13SS
blk13SS's Avatar
The thing with ethanol is, it burns 4 times more than premium pump gas. The added octane rating also allows you to increase timing when you tune the vehicle, therefore increasing power.
Within a week or so I will retune my SS on E85 and I will keep you guys posted on any increase in power.
Old 07-09-2013, 04:35 PM   #10
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Drives: 2012 CRT NF Cammed 2SS/RS For Sale
Most modern cars have seals, gaskets, rubber etc that doesnt get eaten away by ethanol.
Put fuel with ethanol in your weed eater, and its a different story, your fuel lines will be gone in a few weeks.
vroomapunk is offline   Reply With Quote
Old 07-09-2013, 05:02 PM   #11
MBS
MBS's Avatar
Drives: 2010 rs 2lt
No but I switched to 91 octane and NO Ethanol,, Car runs better has more power , and it helps keep food prices down . Screw Corn , I eat it n thats it .
MBS is offline   Reply With Quote
Old 07-09-2013, 05:45 PM   #12
suzook
Drives: camaro
Are you seriously putting in e85? Our cars are NOT designed for this. Your asking for trouble.
Hyperblue/JetBlack
Old 07-09-2013, 05:47 PM   #13
blk13SS
blk13SS's Avatar
I can tell most of you have no clue of the power you can gain out of e85
Old 07-09-2013, 05:53 PM   #14
suzook
Drives: camaro
I'm not disagreeing with that...the problem is injectors...fuel lines...fuel pump....will have big problems after time with the e85
Hyperblue/JetBlack
