11-30-2016, 12:07 PM | #1 |
JANNETTY RACING FORCED INDUCTION Q&A
I started one of these over on Camaro5 and it has been very successful with over 10,000 veiws 135 replies so I thought it would be cool to start a Q&A session regarding Forced Induction since we are a major dealer for all supercharger, and turbo companies.
We have experience and can answer questions for the following companies. A&A Corvettes Superchargers AGP turbo EastCoast Supercharging Edelbrock Hellion Turbo systems Kraftwerks superchargers Magnuson/Magnacharger SLP superchargers Paxton Procharger Vortech Whipple We work with all of these companies and offer full kits and Tuner kits with supporting mods and Custom tuning to make it a Plug and Play Power solution. Any technical questions post them here and I will be happy to answer. Please NO Questions regarding Pricing that should be handled via Email at tedj@jannettyracing.com Ted.
www.jannettyracing.com
12-01-2016, 08:15 AM | #2 |
Drives: Audi S6 V8TT, Volvos XC60 & S60R Join Date: Feb 2016
Ted,
From all the companies you mention, wich ones have systems for the 6 Gen Camaro and what are the expected power levels using 91 octane fuel? Also, what systems would work better drivability wise with an A8 transmission? Thanks. |
12-01-2016, 08:27 AM | #3 | |
Those in red are currently available, the rest are in the works, when we don't know yet. I do expect Whipple to be next though as PRI is next week and I am going. 6 psi of boost is 6 psi of boost they will all make similar Peak power, the Centris with a slight edge at Redline but give up low speed torque to the PD blowers. The turbo systems will have lag but will produce more torque and Horsepower per lb of boost, by what percentage is yet to be determined, but I expect it to be somewhere between 2-8% A&A Corvettes Superchargers AGP turbo EastCoast Supercharging Edelbrock Hellion Turbo systems Kraftwerks superchargers Magnuson/Magnacharger SLP superchargers Paxton Procharger Vortech Whipple
12-01-2016, 08:33 AM | #4 | |
Drives: 2019 Dodge Challenger Scat Pack Join Date: Jun 2016
You're saying that all of those systems are recommended for an A8?
"Submariners are a bunch of intelligent misfits that somehow seem to get along, understand each other and work well together." - overheard from a surface officer explaining to another sailor about Submariners
12-01-2016, 08:37 AM | #5 | |
Gains will be the same if you start on 91 and add the supercharger you will gain X power. If you start on 93 and add a supercharger you will gain the same X power. Your baseline numbers will reflect 91 or 93 octane. Any of these systems can be used on an A8 or M6
12-01-2016, 08:59 AM | #6 | |
I understand that any of these can be used on an A8 what is "Most" recommended? I would thing that one type/brand is better than another.
12-01-2016, 09:06 AM | #7 | |
It really comes down to personal preference on what type of power curve you will use most. PD blowers are pretty much the number one recommendation and choice for most people who use their car primarily on the street and will carry over very well to the track. If your primary focus is Track then you may consider any of the above. Ted.
12-01-2016, 09:15 AM | #8 | |
12-01-2016, 09:39 AM | #9 |
True the 8 speed keeps the rpms up which will help the soggy feel of the centri or turbo
12-01-2016, 09:56 AM | #10 |
Only drives on Sundays
Drives: '16 2SS A8 NPP MRC NGray Join Date: Feb 2011
Assuming an equal level of mods (intercooling, boost level, etc.) what is your experience with IATs with PD blowers? I did a centri on my last build, and loved it for the IATs and how I had it set up.
From my reading, of the newer systems, the Magnuson seems to have it handled best. What's your opinion? Looking at Magnuson, Edlebrock, or the LT4. Padre |
12-01-2016, 10:09 AM | #11 | |
Previous generation Whipple was the King so I expect they will do a great job when they release theirs for this model. At 6-10 psi of boost no one really has an IAT problem that are intercooled, the differences start showing up above 10 psi.
12-01-2016, 10:18 AM | #12 | |
Thanks Ted. Padre |
12-02-2016, 12:21 AM | #13 |
Drives: 2002 Camaro SS Join Date: Jun 2012
With a spot on tune, what kind of hp numbers are these motors capable of handling "safely" ? Wanting my SS to remain my daily driver for as long as possible, but with some boost!
12-02-2016, 08:50 AM | #14 | |
The engine can handle more power than the current fuel system can supply. I am on the dyno with 16 SS A8, currently at 575 RWHP 581 RWTQ with only a Heartbeat, smaller pulley, Fuel pump voltage booster and a tune. Still working on the tune a bit but very close to completion. Ted.
