04-21-2012, 08:14 AM | #1 |
Drives: Audi S4 Join Date: Jul 2010
Can this or will this end the clay bar?
NANOSKIN Autoscrub 6 inch Pad - Better and Faster than Claying
Wow is all I can say about this new tool and new technology. I believe this will change the way most pro detailers and DIYers will prep their cars. This is truly a time saver and will pay for itself after a couple detail jobs. We have spent in some cases 1-2 hours claying and prepping a midsize sedan (in rough shape) we recently tested the AutoScrub on an Audi S8 and we were finished in about 15 minutes! You really won't believe this until you try it yourself. The AutoScrub will make you leave your clay bar behind. NANOSKIN AutoScrub works fast and achieves professional results with the new advanced rubber polymer technology, which replaces the use of clay bars. A dual action orbital polisher is required. AutoScrub will safely and easily removes paint over spray, water spots, tree sap, rail dust and other bonded surface contaminants from the surface of automotive paint, glass, moldings and plastic. AutoScrub works great with your favorite detail spray or clay lubricant. Unlike the clay bar, the AutoScrub can be cleaned by simply rinsing off the accumulated contaminates with water. If you drop the AutoScrub on the ground, no worries, just rinse the sponge pad clean and you're ready to keep using it. AutoScrub allows for sturdy and controlled handling, unlike clay bars where constant reshaping is required. Features - Lasts up to 4 times longer than clay bars - Glides on & off easily for a slick finish - If inadvertently dropped on shop floor, simply rinse clean - Up to 50-60 uses before you need to replace it Directions 1. Thoroughly wash vehicle free of dust, sand, and dirt. 2. Mist sufficient detail spray or clay lubricant onto the surface evenly. 3. Polish the surface with dual action orbital polisher using light pressure (Low Speed). 4. Wipe off residue and move on to compound and polishing or even go straight to your last step. Important tips: - Sufficient lubrication is crucial to the AUTOSCRUB application. - DO NOT use water - DO NOT use with rotary polisher. Various photos of how the pad looks and works 3 inch pad kit 6 inch pad on the Griots on an Uber 5 inch backing plate |
04-21-2012, 08:18 AM | #2 |
what's the diff between rotary & orbital polisher, speed?
04-21-2012, 08:25 AM | #3 |
Drives: 2010 ss2 white w/gold stripes Join Date: May 2011
How much is this kit?
04-21-2012, 08:31 AM | #4 |
Drives: 2010 Camaro IOM 1SS M6 Join Date: Aug 2010
Interested!
04-21-2012, 09:07 AM | #5 |
Drives: 2010 Camaro 2SS/RS Black & Silver Join Date: Aug 2010
Where can you purchase this?
STAINLESS WORKS HEADERS-TUNED BY JANNETTY RACING-C.A.I. INTAKE-TAYLOR 409 WIRES-SOLO AXLE BACK EXHAUST-ELITE CATCH CAN |
04-21-2012, 09:22 AM | #6 |
04-21-2012, 09:24 AM | #7 |
Drives: 2012 Camaro 2SS 45th Anniversary Ed Join Date: Oct 2011
It says don't use water, so if you have to rinse it (accidentally dropped)...do you then have to dry it or wait for it to dry?
2012 Camaro 2SS 45th Anniversary Edition - No longer owned: 2010 Camaro 2LT, 1993 Camaro Z-28
04-21-2012, 09:26 AM | #8 |
Drives: 2010 SS/RS M6/2500HD Lmm LTZ Join Date: Apr 2012
Very nice! Where???
04-21-2012, 09:35 AM | #9 |
sure you can get them here.
NanoSkin AutoScrub if you drop it, you want to rinse it with water, no need to let it dry. |
04-21-2012, 09:35 AM | #10 |
04-21-2012, 09:39 AM | #11 |
Thanks
04-21-2012, 09:41 AM | #12 | |
Coupe Newbie
Drives: 2017 ZL1, 2021 Corvette Convertible Join Date: Jul 2011
04-21-2012, 09:43 AM | #13 |
sure thing no problem.
04-21-2012, 03:23 PM | #14 |
Drives: 2011 Camaro 2SS Join Date: Oct 2011
Is a PC ok?
