04-05-2012, 02:25 AM | #1 |
Drives: SIM 2010 2SS/RS LS3 LPE750 Join Date: Feb 2012
Clutch pedal stuck
Took the SS up to some higher speeds and my clutch pedal was stuck about 3/4 the way down afterwards. I had to pull it up to the normal position with my foot. Car was shifting fine even when the pedal was stuck in the down position. Brakes also had some fade in them. Do you think this was do to over heated clutch / brake fluid?
04-05-2012, 07:13 AM | #2 |
xbox: this is tedious
Sounds like it. That's why a lot of us have seperated our clutch and brake reservoirs for that specific reason. It's just not safe.
May want to change your fluid out
Big Carrot's Changes - It's a work in progress |
04-05-2012, 07:15 AM | #3 |
Lingenfelter clutch return spring works.
It's cheap. It's easy to install. Some may call it a bandaid, but it works!!! I believe that the ZL1 has a similar spring as well.
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
Street Slayer Ultra Performance Clutches Data/Info | Hendrix-Engineering | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 64 | 07-27-2012 10:08 PM |
Stuck gas pedal due to floor mat. | SFcamaro | 5th Gen Camaro SS LS LT General Discussions | 44 | 12-09-2011 12:58 PM |
Street Slayer Brought to you by Hendrix Engineering | Hendrix-Engineering | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 2 | 12-08-2011 04:32 PM |
Clutch Pedal stuck, minor driving? | AWS-GTAW | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 5 | 08-19-2011 09:53 PM |
Oil Change Ramp | mjlash22 | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 17 | 01-21-2010 10:40 PM |
