Roto-Fab
Old 10-23-2020, 08:48 PM   #1
supersnake05
supersnake05's Avatar
Drives: 2015 Camaro SS 1LE, 2014 Chevy SS
Opinions on which lowering springs
I have a 2015 1LE Camaro. My birthday is around the corner and may ask for springs. I've had eibachs and vogtlands in the past both on Mustangs.. Have it narrowed to 1. Hotchkis 2. Pfadt 3. BMR. I'm looking at 1"-1.25" drop. The Pfadt are 300 and can get BMR and Hotchkis for 200. If anyone has any negatives and positives on what they have/ had I would appreciate it. I'm a little confused on some online pictures. The 1" hotchkis looks like some people's car are as low as 1.4" and I know from past experience cars dont always drop as much as advertised. Thanks in advance.
supersnake05 is offline   Reply With Quote
Old 10-23-2020, 09:02 PM   #2
Firefighter
Firefighter's Avatar
Drives: Black '13 2SS/RS/1LE w/NPP/NAV
I've been running the Hotchkiss for a number of years now. They tuck the wheels/tires well and handle really nice. The ride is pretty decent also. The only gripe is if I hit just the right angle when backing out of my driveway some coils will rub and make a little bit of a creak. I feel like they work well with my 1LE struts too. I have a 2013 1LE for reference. I would recommend them 100%.
Saying all that I do have some Afe/Pfadt coil overs to install.
Sent from my SM-T837V using Tapatalk
Firefighter is offline   Reply With Quote
Old 10-23-2020, 09:05 PM   #3
supersnake05
Appreciate it. Was just reading someone had noise from BMR springs as well. Nature of the beast. Is your wheel gap gone with the hotchkis?
Old 10-23-2020, 10:04 PM   #4
Camaro2ss2010
Camaro2ss2010's Avatar
Drives: 2010 Camaro 2SSRS M6
I have 1” BMR and have no noise. A little stiffer than normal but that is to be expected.
ECS supercharger, custom ground cam, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
Camaro2ss2010 is offline   Reply With Quote
Old 10-23-2020, 11:19 PM   #5
VR Baron
SoCal Camaro5 Race Team
VR Baron's Avatar
Drives: 2021 Shadow Grey Camaro 2SS 1LE
I can chime in. The wheel gap is not closed. I had them for awhile. They lower 1” in front and about 3/4” rear. At least on my SS. To close gap you need 1.5 to 2”
VR Baron is online now   Reply With Quote
Old 10-24-2020, 06:52 AM   #6
Avenging Orange
Avenging Orange's Avatar
Drives: 2010 Inferno Orange 2SS/RS
I have the BMR 1" on a 2010 as with (new) stock dampers. It rides damn near stock until you get into it. Your 1le dampers will make it ride a bit stiffer. As for filling the gap....it depends on your wheel offsets and tire size as well. As we all know, the early 5th gen was too high and had bad wheel offsets. My new wheels are a +30 which pushes the wheel further out.. That being said, If my 1" drop can make a 2010 look good, I'm sure the 1le would look even better.
And lastly, most lowering springs will be bratty close in comparison.
I had a bit of spring noise from the coils touching. Just fixed it with about a foot of plastic tubing. I think some of the Eibach springs actually come with coil sleeves.
Good luck
2010 Inferno Orange 2SS/RS M6 Black Leather, Sun Roof, OBX Headers, Borla touring axle back, Cold Air Inductions CAI , non synthetic fluids, BMR total bushing upgrade/1" lowering springs, DSE 32mm rear sway bar. GM fe4 shocks/struts/LCA's, AAM 3.91 diff, Vertini RFS1.8 20x9 +30. Conti ExtremeContact Sport 275/35/20. sjm autoprod ABL dash kit. Mike Norris tuned 413/419.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!!
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
KICKING CANCERS ASS SINCE 2015!!
Avenging Orange is offline   Reply With Quote
Old 10-24-2020, 06:54 AM   #7
supersnake05
Looked like in the pictures the Pfadt springs have a sleeve half way up on the coils.
Old 10-24-2020, 06:56 AM   #8
supersnake05
The spring rates are pretty close to each other, so I'm sure it boils down to word of mouth or brand loyalty. I guess just more worried about getting rid of the gap without being too low.
Old 10-24-2020, 07:00 AM   #9
supersnake05
Looks like the wheel gap on mine is about 2" in the front and just under 3" in the rear.
Old 10-24-2020, 07:22 AM   #10
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
I have had the PFADT's on my 2011 SS for 9 years now and no issues or noise from them at all. They are the 1.25's..
1JEWLDSSRS is offline   Reply With Quote
Old 10-24-2020, 09:12 AM   #11
supersnake05
Attachment 1048142
Beautiful car love the color. I was leaning that way at first but almost 100 dollars more for springs compared to the other 2.
Old 10-24-2020, 09:41 AM   #12
Firefighter
This is the best side shot I have. Being it's all black it's kinda tough to see but there you go.
Also as for the creak it is VERY rare. Practically nonexistent.
Sent from my SM-G973U using Tapatalk
Old 10-24-2020, 09:42 AM   #13
Domangue418
Domangue418's Avatar
Drives: 2013 camaro SS
I run bmr 1” springs and love them. If u have skirts and splitter I wouldn’t recommend going lower. At least in Louisiana
Domangue418 is offline   Reply With Quote
Old 10-24-2020, 10:06 AM   #14
supersnake05
Front looks good back is a tad high. Love that hood!!
