Vararam
Old 04-24-2016, 03:40 PM   #1
Ewey
Ewey's Avatar
Drives: 2013 Camaro SS 6 speed black
Vitesse Eco Modes
Has anyone tested the mpg using the Vitesse throttle controller on its E modes? I commute 5 days a week with my car and would like to know as this could be another reason to justify the purchase with the wife
Ewey is offline   Reply With Quote
Old 04-24-2016, 04:39 PM   #2
Mr. Stacy
El Duderino
Mr. Stacy's Avatar
Drives: 2011 2LTRS Convertible
OK then.... potential gas savings is about one mpg per setting. IE ECO 5 will save 30% of the rounded sum of the prime (about 56.765123254) times inertia (42?) vs. the overall speed coefficient. So right about 5 mpg. To simplify (a)= (c)x (b)÷^6.765498/£. lbs. She'll understand.
Seriously, you might just need to do like I have to do sometimes and make something up. Think of all the gas savings I am getting from my CAI!
I bowl. Drive around. The occasional acid flashback.
Mr. Stacy is offline   Reply With Quote
Old 04-24-2016, 05:07 PM   #3
genuineduke
genuineduke's Avatar
Drives: 2015 Camaro 2LS
If you want to save gas, why Camaro lol
genuineduke is offline   Reply With Quote
Old 04-24-2016, 05:08 PM   #4
Ewey
Ewey's Avatar
(a¹)= (cº)x (b)÷^6.765498/£. lbs pre-multiplied by Qx¶¹.33333333333333
It seems like all the reviews I've looked up always focus on the SP0-9
Old 04-24-2016, 05:10 PM   #5
Ewey
Ewey's Avatar
I figured if I had the Vitesse controller I could save gas on the boring drives and have fun with it when I want to. It seems like a popular mod so why not at least test out the other features?
Old 04-24-2016, 06:46 PM   #6
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
My understanding was that the ECO modes did not work with the LS3 or L99's. Personally, I wouldn't use them anyway, but I'm pretty sure they are non-functional with the V-8's.
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 04-24-2016, 06:50 PM   #7
Ron_MA
Ron_MA's Avatar
Drives: 2014 AGM Trifecta Tuned V6
All it does is change how wide the throttle opens based on how far you press the gas, so flooring on sp9 or Eco will eventually have the same effect eco will just take longer to open wide, so it's saving you gas by keeping you low in the rev range. I'm talking out of my ass by the way but that's my .2
Ron_MA is offline   Reply With Quote
Old 04-24-2016, 07:43 PM   #8
Skillet
Drives: car
First things first. You turned in your man card already right?
Skillet is offline   Reply With Quote
Old 04-24-2016, 07:58 PM   #9
rfopt
Drives: 2019 Corvette Grand Sport
The eco modes do indeed work as you can clearly feel the difference from stock. However, I don't know if fuel economy improves. The eco modes make the throttle position change very slowly, and is very mushy/numb feeling.
rfopt is offline   Reply With Quote
Old 04-24-2016, 08:24 PM   #10
sspolo
sspolo's Avatar
Drives: 2014 Camaro SS 1LE
Back many months ago, I read that the higher eco modes were causing the check engine to turn on. Don't quote me that though...
sspolo is offline   Reply With Quote
Old 04-24-2016, 09:21 PM   #11
Ewey
Ewey's Avatar
Drives: slow
thats from your profile...
Old 04-24-2016, 09:47 PM   #12
nosmr2
Drives: 2011 L99 SS
You're having a hard time getting a PO for $200?
Good luck
2011 SS
ADM LSA Conversion
nosmr2 is offline   Reply With Quote
Old 04-24-2016, 10:02 PM   #13
Mr. Stacy
El Duderino
Mr. Stacy's Avatar
Seriously, I do get 2-3 extra MPG with my CAI. Finally ended up with Airaid. The biggest, baddest, mofo of an CAI you will find outside the track. JMHO. (what? ass talk was previously mentioned so it's allowed right?)
Hit me up with a PM, I have a slightly used VTC you might be interested in.
Old 04-24-2016, 10:26 PM   #14
MrChrisLS3
Drives: 2018 1SS M6
The whole reason I bought it was to fix the terrible throttle response, why on God's green earth would I choose to make it worse?
Even if the Eco settings did work on the v8, I can't imagine there is enough gas saving going on to make it worth the aggravation. Just my $.02
MrChrisLS3 is offline   Reply With Quote
