Old 07-03-2013, 09:13 PM   #1
crewdogg15
Drives: 2013 chevy camaro
HELP WITH TACH INSTALL
I was told from PEPBOYS SPEED SHOP I can't install a TACH on a 2013 1SS LS3 Because of the wiring, is this true?
crewdogg15 is offline   Reply With Quote
Old 07-04-2013, 02:24 AM   #2
DaFisch
Master Amateur Mechanic
DaFisch's Avatar
Drives: Victory Red 2011 2SS/RS
Of course not... Ypu can install on any car.
DaFisch is offline   Reply With Quote
Old 07-04-2013, 05:43 AM   #3
REDXIIIDave
El Chupacabra
REDXIIIDave's Avatar
Drives: 2011 2SS/RS A6 Black/Black
Um.... you already have a tach. It's right next to your speedometer.
El Chupacabra
REDXIIIDave is offline   Reply With Quote
Old 07-04-2013, 08:03 AM   #4
crewdogg15
Then how do you hook it up then? A tach is hooked to the negative side if the ignition coil. So if there are 8?? How do you do it??
Old 07-04-2013, 08:07 AM   #5
RJT-SS
RJT-SS's Avatar
Drives: '11 2SS/RS A6
So, the tach in the dashboard of your 2013 Camaro is not working? I would take it to the dealership.
Performance Mods:
Kooks 1-7/8 LTs; Calico coated w/HFCs, Solo Mach XL catback w/J-pipes, VMax TB, C.A.I. Intake, JRE Tune, RX Catch-Can
RJT-SS is offline   Reply With Quote
Old 07-04-2013, 08:16 AM   #6
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
crew dog it is already working on the dashboard of your car you do not need to figure how its working as if it was a 65 chevy. If it is not working you need to see a dealership, and if you really want it a hud can be installed that also shows your revs you just have to look for the info.
christianchevell is offline   Reply With Quote
Old 07-04-2013, 08:23 AM   #7
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
If the factory tach is not working it is covered under warranty, unless you did something to the car modding it to disable it.
The tach is controlled by the ECM, you cannot hook up a old fashioned tach any more. But you can get something that plugs into the diagnostic module to read out RPMs if you want a secondary gauge.
The Bird is the word!
Old 07-04-2013, 08:31 AM   #8
Smirnoff
Smirnoff's Avatar
Drives: Camaro SS
Bump for asking Pep Boys.
11.90's w/headers, CAI, custom tune, slicks/skinnys, shifter & 100+ Ethyl.
Smirnoff is offline   Reply With Quote
Old 07-04-2013, 09:33 AM   #9
crewdogg15
I wanted a secondary gauge and the one i had picked out was small and digital, why the bump for asking pepboys? Its a speedshop pepboys and the guy that works there is reputable.
Old 07-04-2013, 09:45 AM   #10
Angrybird 12
I have a Bluetooth device called the BT1 and an app on my IPod touch called Dash Command that you can use for all kinds of gauges including the tach. It also reads codes and resets them.
Old 07-04-2013, 11:20 AM   #11
crewdogg15
Originally Posted by Comrando View Post
I use the Ultragauge. It plugs in the OBD port.
There are others out there as well.
Now i like that!!!
Old 07-04-2013, 02:38 PM   #12
two_wheel_mayhem
Would rather be riding
two_wheel_mayhem's Avatar
Drives: No car no more
In these modern times we always pick up our tach signal at the ECM. 8 coils, no problem pick one there will be 8 to choose from.
If your aftermarket tach won't calibrate for an 8 coil set-up it's not your car's fault.
No dog in this fight anymore.
5th Gen owner 2009-2016.
two_wheel_mayhem is offline   Reply With Quote
Old 07-04-2013, 05:39 PM   #13
crewdogg15
So i just hook it up to the #1 coil and i should be good?
Old 07-04-2013, 07:34 PM   #14
two_wheel_mayhem
Well that would make it work, but I'm unsure of the tach calibration procedure on a modern multi-coil vehicle. It certainly won't read correctly if it's some universal tach intended for older vehicles.
I would call Auto Meter and ask them tomorrow. They are always willing to offer advice about what product you should buy and inform you of any extra items you may need to make it function on your specific vehicle.
