Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 02-01-2013, 05:25 PM   #1
c4maroboy
[HOONIGAN]
c4maroboy's Avatar
Drives: 2012 ZL1 #1848[The HOONIGAN MOBILE]
Oracle side markers
I recently received my oracle ghost side markers for my car the other day and so decided to install them today..however i ran into trouble when i couldn't reach my hand or see behind the small opening in the wheel well to remove the stock side markers. i looked up on youtube how to install them but all the videos only showed camaro models other than the ZL1. I thought the process would be the same regardless of model but im having trouble. anybody have any experience installing these? help?
2012 ZL1 BLack M6 ECF
c4maroboy is offline   Reply With Quote
Old 02-01-2013, 05:27 PM   #2
Frid
Frid's Avatar
Drives: '11 Camaro 2SS/RS LS3
You can jack the car up and remove the tires and liners to make it much easier.
Frid is offline   Reply With Quote
Old 02-01-2013, 05:30 PM   #3
c4maroboy
[HOONIGAN]
c4maroboy's Avatar
yeah, i was just hoping to do it in my garage this weekend to get me excited for spring. But if cant figure it out ill just drop it off at the dealer and have them install it for me.
Old 02-01-2013, 05:32 PM   #4
Frid
Frid's Avatar
Old 02-01-2013, 06:20 PM   #5
ZL1 Spoked
ZL1 Spoked's Avatar
Drives: Camaro ZL1
No way don't waste 200 bucks for them to install it, you can do it in 15 minutes!
-2013 Camaro ZL1-Black Stripe Package-Ambient Light Kit-Subwoofer Package-Sunroof-Suede Package-NAV MYLINK-MANUAL BABY-Dual Vented Fenders-Exposed Carbon Fiber Insert
-Black 10 Spoke Wheels
604 RWHP 602 LBS/TQ
ZL1 Spoked is offline   Reply With Quote
Old 02-01-2013, 06:30 PM   #6
Jay_ray23
Jay_ray23's Avatar
Drives: 2013 Black ZL1
I'm subscribed I also have Some oracle side markers to install
Jay_ray23 is offline   Reply With Quote
Old 02-01-2013, 06:31 PM   #7
Normagene
Normagene's Avatar
Drives: 2013 Ashen Gray M6 ZL1
I installed mine. Took about ten minutes for the first one then maybe five for the second one. Same amount of time for the back ones. There's a gap for the screw driver to slide into, at first I didn't push it in far enough, but then it just popped out. Really easy, no need to remove the tires or anything, not one screw, just follow the instructions. I watched a u tube video first then went out and gave it a try.
Normagene is offline   Reply With Quote
Old 02-01-2013, 06:51 PM   #8
OVERPAR73
2018 Garnet Red ZL1 conve
OVERPAR73's Avatar
Drives: 2013 & 2018 ZL1 vert
AAC side markers
c4maroboy,
It's so easy, watch the DIY video again. It took me about ten minutes each side, use a really long skinny screw driver to push on the clip and they pop right out after you get the few screws and one 7mm bolt removed. You will really love them after there installed! I bought mine CRT ghosted from AAC and they look amazing!! (Light off/light on)
Build Thread: 2018 ZL1 Vert Purchased (Overpar73)
OVERPAR73 is offline   Reply With Quote
Old 02-01-2013, 09:49 PM   #9
69NMYSS
69NMYSS's Avatar
Drives: '69 Camaro SS and '12 ZL1
Only takes 5 min per marker light. Super easy. No need to lift, take tires off etc. in rear just pull back carpet side lining and youll have access
69NMYSS is offline   Reply With Quote
Old 02-01-2013, 09:53 PM   #10
G-Oil Guy
Where am I?
G-Oil Guy's Avatar
Drives: Zoe the ZL1, 2012 Frontier
Originally Posted by OVERPAR73 View Post
c4maroboy,
Where's the DIY located?
FOR SALE: 2013 ZL1 Message me if interested
G-Oil Guy is offline   Reply With Quote
Old 02-02-2013, 06:36 AM   #11
OVERPAR73
OVERPAR73's Avatar
Here you go:
Old 02-02-2013, 08:56 AM   #12
toyosuprablue
Drives: 2013 ZL1 Black M6
For the back two I jacked up the rear and went straight from underneath. Didnt have to remove any covers just did it blind by reaching up and feeling the clip and popping it out. Took less than 5 min a side. For the front the clips were giving me trouble so i removed the wheels and pulled the plastic back further
toyosuprablue is offline   Reply With Quote
Old 02-02-2013, 09:23 AM   #13
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Drives: 2012 CRT NF Cammed 2SS/RS For Sale
I know you may have wider tires than me, but just turn the wheel all the way in, take off one side of the wheel well and splash guards if applicable, and you can get in there. If its not coming then you are probably forgetting a screw. I think theres one holding the lens in place? And then theres one perpendicular to the light holding the fascia in place, and another from underneath. Just feel around and take out any screws until the fascia moves freely.
Might want to find the DIY heritage grille install video to show you where all the bolts are, since it involves removing the fascia entirely.
EDIT I may be making too big of a deal about it, per the video above hahaha. Maybe there arent any screws holding it in.
vroomapunk is offline   Reply With Quote
Old 02-02-2013, 09:41 AM   #14
OVERPAR73
OVERPAR73's Avatar
Sorry the video above was not for your ZL1, you only have to add the 7mm bolt going straight up really, really close to the fender lip in addition to the three screws. Good luck!
