11-10-2017, 09:48 AM | #1 |
#becauseracecar
Drives: 2016 SS Sedan, 2016 Camaro SS Join Date: May 2015
ZL1 1LE spec handling upgrade vs BMR spherical bearings?
Debating between these 2 options as the price seems to be comparable. The BMR spherical bearings for the front radius rods and lower control arms and for the rear trailing arms and control arms seem pretty cool. The GM ZL1 1LE Spec handling upgrade kit I think takes care of the same bushings. They won’t be as stiff but do the BMR spherical bearings do ok on the street as far as longevity is concerned? Are the ZL1 1LE components ACTUALLY different and stiffer or is it just the bushings that make the rods and arms stiffer? Or is there material actually added to the trailing links? Are the ball joints different?
ZL1 1LE kit: http://www.gmperformancemotor.com/parts/84352119.html BMR items: rear: http://m.bmrsuspension.com/?page=pro...=121&catid=449 And front: http://m.bmrsuspension.com/?page=pro...=121&catid=450 Or third option. Use the BMR trailing arms and upper control arms and their spherical bushings in the front? Any other options? Front tire wear especially needs help. Killing the inner and outer edges with tons of center tread left. Thanks all Last edited by Eric SS; 11-10-2017 at 10:52 AM. |
11-10-2017, 10:55 AM | #2 |
since you already have bmr i would go bmr but its up to you lol pricing wise how different is it?
11-10-2017, 11:06 AM | #3 | |
#becauseracecar
EDIT: the BMR suspension I currently have are their springs, adj sway bars and end links, toe rods, and strut tower bar. Last edited by Eric SS; 11-10-2017 at 12:27 PM. |
11-10-2017, 11:42 AM | #4 |
i would just keep it all bmr and im sure they will give you a good deal if you keep it all bmr
11-10-2017, 12:15 PM | #5 |
#becauseracecar
11-10-2017, 12:16 PM | #6 | |
Drives: 2016 Camaro 2SS Join Date: Sep 2009
11-10-2017, 12:52 PM | #7 | |
#becauseracecar
11-10-2017, 02:03 PM | #8 |
11-10-2017, 03:05 PM | #9 |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
If you're building a track-only car and truly don't care about street manners, then going full spherical bearing is the best solution for precise wheel control. That means eliminating the rubber in the strut mounts, front control links, every bushing in the rear end, including subframe. It looks like BMR offers enough line items to pull it off but I can't see how they retain the rear lower control arm alignment eccentric. Hopefully they can clear that up.
Also know that spherical bearings are fantastic in the beginning, but they also wear our and become loose over time. That means mandatory replacement much more often than rubber bushings. As long as you budget that into your tracking programme, you'll be good. I definitely do not recommend polyurethane. Having been down that road, it's an awful bushing choice for cars in most applications, definitely ones with complicated articulation paths like our virtual pivot front strut and rear multi-link suspensions. Poly really can only work on straight-up axial applications, ditto with delrin. A solid rubber bushings is infinitely preferred over poly in pretty much every scenario. It appears the ZL1 1LE "arms and bushings" kit ends up being a mix of mostly rubber bushings and two spherical bearings, to be verified. This might give a good mix of compliance and control, and seeing the cir-clipped boots on the bearings in the GM kit means they went the extra step to weather-resist the bearings so they'll last longer. Weather wears out spherical bearings much quicker than clean & dry track use. Get some salt spray in an unprotected spherical and they're F'ed in short order.
