Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Dragstrip and Launch Techniques Discussion
Old 06-16-2016, 11:44 PM   #15
Moreair1
Moreair1's Avatar
Drives: 2011 ss convertible
Originally Posted by Merc View Post
On a 2step at probably north of 5000 look out. Big Thanks to DSS for all there support.
Dang if I even thought about doing that my clutch or rear end would check out, yes I'm still stock in those areas
Cai intake and a few other mods😎
Moreair1 is offline   Reply With Quote
Old 06-17-2016, 12:29 PM   #16
krisprz2010camaross
krisprz2010camaross's Avatar
Drives: 2010 Camaro 2ss/Rs Transformers
2 step on 2010 ss auto?
If your asking what a trans brake is, I'm not sure your qualified to tell the rest of us that 2 steps are for auto's too. A 2 step is designed to release the rpm hold off a clutch pedal sensor when you leave the line. 2 steps are really designed to work properly with a manual only. BTW I has a 2step on Pumpkin.
I'm not telling anyone what 2 step is? Lol I'm just saying I've seen it in auto cars...
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage
LS3 conversion
Vararam intake(tune model)
Kooks LT headers & cats delete
Corsa ZL1 3" exhaust
RedBarn Racing Tune
CMS Stage 3 Cam
AFR CNC ported heads
MSD Spark plug wires
LNC-2000 Launch controller
NGK TR6 Spark Plugs
1le strut tower brace-TPIS spacers
Nick Williams 102mm throttle body
Fast lsxr 102 intake manifold
Slp 25% UDP
Katech Tensioner Pulley
Circle D 3600-3700 multi disk Stall
GM 3.91 gears
DDS carbon fiber driveshaft
ZL1 fuel pump & injectors
Flex fuel sensor(91/E85)
https://wheelwell.com/kris-perez
krisprz2010camaross is offline   Reply With Quote
Old 06-17-2016, 03:36 PM   #17
MudderFinger
MudderFinger's Avatar
Drives: 2011 IOM SS/RS
A 2 step rev limiter is normally used with a transbrake on an auto, so that when the transbrake is engaged it has a lower rev limit to hold thottle to floor while on starting line, and then once released it switches over to higher rev limit. If not for this, rpms would go to high with thottle to the floor at starting line.
A transbrake holds the car in both forward and reverse gears to prevent it from moving while engaged, so that thottle can be held to floor and button released to launch car at full thottle and the 2 step would allow you to control that launch RPM.
Using 2 step on manuel would be more of a launch control using clutch.
MudderFinger is offline   Reply With Quote
Old 06-17-2016, 07:36 PM   #18
2013 ZL1 #7860
Drives: 2013 ZL1 A6 #7860
Wow...
2 steps are definitely used on Autos for drag racing and VERY common...
(combined with a high stall it gives you a measure of consistency and a way to adjust the launch rpm accurately, helps dial in the car's reaction time as well)
They don't have trans brakes for 6l80's as far as I know...
IMO: Camaro 5 has been a very poor source for information about drag racing a 5th gen. This thread being a good example... The OP should try looking at other forums more centered on drag racing for better information.
2013 ZL1 #7860 is offline   Reply With Quote
Old 06-18-2016, 01:26 AM   #19
62nalide
62nalide's Avatar
Drives: 2013 SS
You can run them but you don't need them on a stalled auto. Best 60fts are leaving off idle (1.42) all motor to date. Maybe if you ran like a th400 or so.
62nalide is offline   Reply With Quote
Old 06-18-2016, 10:20 AM   #20
Merc
In The Circle
Merc's Avatar
Correct for a 2step to work as it's meant to, it need's to be a trans brake auto or a manual and there both a form of launch control.
Old 06-21-2016, 07:20 PM   #21
htggems
Drives: 2011 Camaro 2SS/RS
There seems to be a lot of assumptions on this thread. You CAN wire a MSD 2-Step into an Auto car. You can't do it on the brake pedal itself. You have to go to a switched 12v source like the clutch switch on the manuals. I suggest using the 3rd brake light wire from the BCM. It's in the black plug and is a white wire. There are 2 in there so it's best to test them with a multimeter. Tap the wire and plug it into the 12v white wire on the MSD 2Step. You don't have to use them with a trans brake at all. I don't recommend using them with a factory torque converter as you can't stall them very high and makes it pretty much moot. I use it to activate the methanol kit I have set up through a WOT switch on the gas pedal. Helps lower my IAT's before launching and then of course through the trip down the track. It's an NA car. 3800 rpm stall.
htggems is offline   Reply With Quote
Old 06-22-2016, 06:24 PM   #22
jrpimp00
jrpimp00's Avatar
Drives: '10 Black/IOM Camaro SS/RS
Originally Posted by 2013 ZL1 #7860 View Post
Wow...
^^ AGREED !!!
OP, the benefit of me running a 2 step on my Trans AM is it allows me to leave the line in boost and the same level everytime. You dont have to worry about trying to get your foot position set. You set your 2 step to the desired RPM and floor it.
You need to check out yellowbullet or ls1tech
2010 Camaro 2SS/RS Black/IOM //// 1998 Pontiac Trans AM 819 RWHP @ 12 PSI (Turbo)
jrpimp00 is offline   Reply With Quote
Old 06-22-2016, 07:44 PM   #23
Merc
In The Circle
Merc's Avatar
For those who want to run a 2 step launch control on a M6 these are parts you need, plus a RPM controller of your choice. All plug an play and totally adjustable with your clutch pedal. I'd recommend a Lingenfelter RPM controller as the MSD one I bought is a paper weight do to issues with it.
Name:  Screen Shot 2016-06-22 at 5.39.48 PM.png
Name:  Screen Shot 2016-06-18 at 8.35.54 AM.png
Old 06-22-2016, 07:49 PM   #24
Merc
In The Circle
Merc's Avatar
This is how it works with an M6, consistent 1.62 sixty foots.
https://youtu.be/R-q7FpV_mr8?t=8
Old 06-22-2016, 07:57 PM   #25
Merc
In The Circle
Merc's Avatar
I used this RPM controller.
Name:  Screen Shot 2016-06-22 at 5.55.09 PM.png
Old 02-15-2018, 10:08 PM   #26
matts86cam
Drives: 1986 z28 and 2015 ss
Back from the dead, lol,what if I want one (a 2step rev limiter) for just showing off with the l99 in neutral?possible?
matts86cam is offline   Reply With Quote
Old 02-20-2018, 01:17 AM   #27
krisprz2010camaross
Yes. That’ll work fine lol. I have the lingenfelter launch control/2 step. Works perfectly. But I don’t use it often. Still awesome
LS3 conversion
RedBarn Racing Tune
CMS Stage 3 Cam
NGK TR6 Spark Plugs
Slp 25% UDP
GM 3.91 gears
Old 02-20-2018, 06:17 AM   #28
Rob10CamaroSS
Drives: 2012 ZL1 Redline Phase 4
I've had 2 steps on street vehicles and there's really no practical use for it
BUT at the track with the right set up, OH YA!!!
I had a Brand X Race Truck I recently sold to a good friend and it had a 3 step I used as a 2 step. 418 cu in 351W w/ 13.2:1 Compression, C4 w/ Brake, 5500 RPM Stall, 4.88 Gears with a 3000 RPM Launch Chip & 8000 RPM Limiter Chip.
It goes against everything you know the first time you roll in and push the Trans Brake Button and take your foot off the brake pedal while pushing the go pedal to the floor. But when you let go of the button holy someone hit me in the back of the head with a baseball bat
2012 ZL1 w/Redline PHASE 4-ZL Performance Package
Rob10CamaroSS is offline   Reply With Quote
