06-01-2014, 08:11 PM | #1 |
AC Pickles!
Drives: 2014 Camaro ZL1 Join Date: Mar 2014
None Ethanol gas
I have read several articles about the benefits of using none ethanol gas. Gas with 10% or more ethanol is harder on the engine, injectors, etc.
Here in NC there are several station that offer none ethanol gas for sale. The gas is only 91 octane not 93 as recommend by the owner’s manual. After doing some research it appears all none ethanol gas is only 91 octane. I was wondering if any of you have experience in using none ethanol gas and will it hurt my cars performance using gas 2 octane below what is recommended? On a side note, the guy who owns the gas station closest to me that sells none Ethanol gas owns a beautiful 2014 Blue GT500. He swears by none ethanol gas and is insisting not only is it much better for my car bit it will increase performance even with the loss of 2 octane. |
06-01-2014, 08:42 PM | #2 | |
Drives: 20 1LE 2SS M6 Rally Green Join Date: Mar 2014
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.” Ronald Reagan - |
06-01-2014, 09:19 PM | #3 |
Drives: 2013 Triple Black ZL1 / 2006 TB SS Join Date: Feb 2011
You'll be fine. I've run it before with no problems.
06-01-2014, 09:26 PM | #4 |
Question is what makes more power. Both are available. 91 w/o ethanol or 93 with ethanol.
I was leaning toward the 93 but would really like to hear from so so e who has tested both on a dyno
06-01-2014, 09:36 PM | #5 |
AC Pickles!
06-01-2014, 09:55 PM | #6 |
The reason GM recommends 93 octane for "best performance" is because these cars run pretty high timing at WOT. I haven't dyno'd between the two (don't think it would be worth it imo), but I have datalogged extensively between the two and I always saw full timing at WOT with 91 clear same as 93. The car will also run richer with the clear and even get a little better mpg.
06-01-2014, 11:51 PM | #7 |
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
Octane is basically a standardized reading of how much compression a fuel can take before it spontaneously combusts like diesel fuel. In a gasoline engine this is called knock and it is bad. The cars today run a lot more compression on average because the computers will automatically retard timing to reduce the chance of knock. If your car knock sensor is retarding timing you are losing some possible power. Unless you have some special equipment, you have no way in a stock car to tell if the car is retarding the timing to prevent knock. It happens a lot more than most people realize.
Ethanol has interesting properties. It can be compressed a lot more than gasoline without detonation. Early drag racing cars used to run pure ethanol because they could run crazy compression ratios if they could get the fuel into the motor. It inherently is "high octane" but when fuel burns there is a certain amount of heat that can be released from the fuel. The BTU is the standard unit and the more heat the fuel can make the more power. Pure gasoline is somewhere around 114,000 btu/gal while pure ethanol is about 76,000 btu's per gallon. You only get about 2/3 of the power per gallon with the ethanol. So fuels like e85 that are 85% gas and 15% ethanol are blended to prevent detonation like a high octane but don't make as much heat/energy when burned as pure gas. So if your car is pulling timing you could probably do better with some ethanol but if it is not you will get more power and better mpg with pure gas.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. Last edited by jessrayo; 06-02-2014 at 12:04 AM. |
06-02-2014, 12:11 AM | #8 |
Drives: 2014 Red Hot ZL1 Join Date: Jan 2010
My 2014 Camaro users manual states to use 91 octane or higher for LSA and LS7 engines. There is nothing specifically stating a suggested use of 93 octane. Is there a newer or revised 2014 edition of the users manual that states 93 octane?
2014 Red Hot Camaro ZL1
2002 Victory Red Trans Am WS6 2000 Lt Pewter Metallic Silverado Z71 1996 Metallic Gray Ford Taurus GL |
06-02-2014, 12:18 AM | #9 | |
Drives: 2014 2SS L99 Join Date: Mar 2014
Mostly true except for the percentage ratio of E85. It's 85% ethanol and 15 % dino gasoline. |
06-02-2014, 12:21 AM | #10 |
I don't have a ZL1 manual.............yet.......but that said ,there are many areas where only 91 octane is available in ethanol blend.
06-02-2014, 12:49 AM | #11 |
I live in one of those areas. 83, 87, and 91 all ethanol blend, no non-ethanol blend available. E85 is available as well. Once in a blue moon we will see 92 octane during the hot summer months. 100 octane at a premium price ~$6.00 a gallon is also available.
2002 Victory Red Trans Am WS6 2000 Lt Pewter Metallic Silverado Z71 1996 Metallic Gray Ford Taurus GL Last edited by WSSICK; 06-02-2014 at 01:02 AM. |
06-02-2014, 12:55 AM | #12 | |
Yea ,there used to be all three grades available down here in non ethanol variety but only 87 as of one year ago. I use the 87 though in my 96' model two stroke outboard,my lawn equipment, and a 92' FZR Yamaha.. They don't like ethanol gas. |
06-02-2014, 06:15 AM | #13 | |
Drives: 02 Z06, 95 Trans Am, 2012 ZL1 Join Date: Mar 2012
There are plenty that carry 93 octane pure gas. Go check out http://pure-gas.org/
Bryan 2018 ZL1 M6
06-02-2014, 06:44 AM | #14 | |
I'm going to use the blended 93
