07-18-2017, 08:13 PM | #1 |
Drives: 2ss Join Date: Apr 2016
Nitrous Setup
Just recently decided to go with nitrous on my camaro. I currently have cam/headers/e85 and it dyno'd roughly around 530 on an a8. My biggest concern here is, will my fuel pump give up if I spray anything over 100hp? Or till what extent can i go? What options I have like is a fuel cell better or zl1 pump.
Nitrous outlet plate kit Bottle heater Purger kit Remote opener Window switch Lingenfelter timing retard Anything else im missing? Im also thinking about buying the innovate nitrous gauge to prevent from any fuel lean blowing up my motor lol. Any help would be great guys thanks. |
07-19-2017, 05:38 AM | #2 |
Drives: 2016 camaro 1ss Join Date: Jan 2016
I'm can't answer your main question but if your cam swap includes a lash cap I wouldn't use a LT4 pump. I guess the lash caps can ruin LT4 (not LT1) fuel pumps.
2016 1SS (M6) Kooks headers and exhaust, pray ported MSD/TB, JLT CAI, JLT catch can, TSP heads/VVT-2 cam, E85, Centerfirce clutch, g force axels and DS, most of what BMR makes, blah blah blah
07-19-2017, 09:56 AM | #3 | |
Drives: Camaro 17 SS Join Date: Jan 2017
I had a much longer response but it was lost. I would suggest colder plugs, YOU will run out of pump with e85 much sooner than pump or race gas, and IMO I would build a better low side fuel system over adding a cell. over the lingenfelter and innovative I would invest in HP tuners and use that in place of both.
07-19-2017, 11:25 AM | #4 |
So basically, just upgrade the lowside in tank pump, stock injectors will also hold? I searched up any nitrous setups with something similar I want here on camaro6 but didn't find anything... just heard people with boost loosing pressure after being in the 600s
07-19-2017, 01:34 PM | #5 | |
Drives: 2016 Gen 6 SS 6spd Join Date: Jun 2017
Great Article off the CF. https://www.corvetteforum.com/forums...learances.html |
07-19-2017, 05:47 PM | #6 |
If you are installing a wet nitrous kit that hooks up it's fuel solenoid to the stock fuel rail in the engine compartment, then the low pressure/intank fuel pump is the one you should upgrade. Such a system does not rely on the hpfp or injectors for it's fuel supply.
07-19-2017, 11:03 PM | #7 | |
07-20-2017, 04:12 AM | #8 |
ZL1 intank pump is just a better version of the stock pump, so goes in just like a stock pump.
07-20-2017, 06:53 AM | #9 |
Drives: 2017 Camaro SS 2SS Join Date: Jun 2017
I want to run this same setup on an otherwise stock SS. Guess I'll be looking for a ZL1 fuel pump.
07-20-2017, 10:55 AM | #10 |
07-20-2017, 11:34 AM | #11 |
I love the car the way it is. Sound and ride wise, Performance is good but who couldn't use 200 hp on demand. That being said, my wife also likes the car the way it is. My last couple of cars and my bike for that matter, drive my wife nuts. They are fast and LOUD. she likes this one because when I want I can keep it quiet and it looks good. That being said, I want this to be fast as hell also. I just need to find a way to do that without taking the joy out of it for her. She also likes to drive this car. so being able to close a valve in the trunk and taking the power away is perfect.
07-20-2017, 12:14 PM | #12 |
There are afew nitrous threads on this forum. Also I would be cautious going to a 200 shot. The pistons are reported to be very weak. It is because of this that I decided against going with a remote bottle opener. It is a mechanical "do I really need this" check.
07-20-2017, 02:23 PM | #13 |
I don't know that I would take it all the way to a 200 shot. Then again, who knows.
07-20-2017, 07:50 PM | #14 | |
Drives: 2016 Camaro 2SS M6 Join Date: Jan 2017
I used to be a serious nitrous addict. I would spend more a week in nitrous than I did gas--I was easily using something like 80-120lbs of nitrous a month. I probably should have been in a rehab center, even though it was for my car
‘16 Camaro 2SS M6 - RotoFab CAI, Soler Performance TB, E85
8.102 @ 89.85 MPH (bone stock) |
