Roto-Fab
Old 05-14-2011, 06:21 PM   #1
Oxtar41
Oxtar41's Avatar
Drives: 700 rwhp 2010 SS
ADM gauges installed! My quick thoughts...
I installed my dual gauges from ADM last night and I have to be honest for the money you pay for these I think the craftsmanship could be better. The gauges in the bracket sit slightly crooked and the mounting studs on the bracket need to be slightly wider to fit the mounting holes better.
I slotted the holes that the studs go through to compensate for it but there is a small gap on the left side between the cluster bezel and the gauge pod. The directions mentioned a "green" wire that needed to be hooked to ground from the AFR box wiring and there was no green wire only a brown.
Install was pretty easy though, the hardest part was routing all of the wires neatly to keep everything hidden. All in all Im happy with them and they do work, they are pretty accurate too. If i had to give them a rating I'd say 7/10 maybe I got a bad batch but for the money I think ADM could take a little more time to correct the issues I found with mine . Maybe I'm just to anal about stuff?
Oxtar41 is offline   Reply With Quote
Old 05-14-2011, 06:48 PM   #2
Turbo99
Turbo99's Avatar
Drives: 08' F250 Diesel & 10' Camaro 2SS
I do agree that the instructions could be alittle more detailed but all in all I was happy with mine.
08' F250 CCSB 6.4L Diesel White & Black, Blacked out, 580RWHP @ 55psi 13.21 @ 101mph
10' Camaro 2SS LS3 M6 White & Black, Blacked out, 684 RWHP & 633 FT.LBS @ 10psi 10.82@130mph
TVS2300 ,Hendrix Street Slayer Twin Carbon Clutch, Dana 60 3.73, DSS 1400HP Axles,JRe cam & LaMotta Performance tuned,LPE Fuel, AI Super Chiller,MT ET Streets
Turbo99 is offline   Reply With Quote
Old 05-14-2011, 06:51 PM   #3
Jose
Jose's Avatar
Drives: 2010 Camaro 2SS/RS White S/C
I am about to purchase them, how much dismanteling of the dash is required?
"It does not matter if you win or loose, what matters is if I win" Carl Fogarty
Jose is offline   Reply With Quote
Old 05-14-2011, 07:06 PM   #4
Oxtar41
Oxtar41's Avatar
just the bezel around the speedo and tach has to come off
Old 05-14-2011, 09:27 PM   #5
yotaman96
yotaman96's Avatar
Drives: 2017 Camaro SS1LE 2000 Trans Am WS6
I bought the single boost gauge. I haven't installed it yet. I noticed it doesn't look straight, but I figured it was designed that way and will look straight once installed. I hope I'm right.
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans
2002 Trans Am
2015 Ram Crew Cab Cummins
yotaman96 is offline   Reply With Quote
Old 05-14-2011, 09:32 PM   #6
Turbo99
Turbo99's Avatar
yeah they look crooked as hell until you get them installed. I told Andy he might should just put something in the instructions about that so he dosen't get so many calls about it.
Old 05-15-2011, 10:50 AM   #7
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
I am getting mine installed this week and was wondering if you had to get a vaccuum hose for the air fuel gauge that didn't come with the kit and if so what size and how long? Thanks.
MODS:
ADM built 417, 2.9L Whipple with 3.250 pulley, ADM ported and polished LSA heads,ADM stage3 cam,ADM LSA belt drive system,ADM CAI race scoop, ADM dual fuel pumps, ID 850's, BMR full suspension, Gforce 9 inch kit with 3.5 inch driveshaft, Street Slayer twin carbon clutch, Lingenfelter oil seperator. Tuned by built by ADM Performance, 763rwhp,705rwtq
10aSSee D is offline   Reply With Quote
Old 05-15-2011, 11:44 AM   #8
Oxtar41
Oxtar41's Avatar
it depends on what supercharger you have and where you want to mount it. I have an
E-force and used the NPT fitting on the drivers side of the supercharger. I used a 3/16 hose from napa and used about 3 feet because I routed it so it would be hidden. Hose is cheap I think i paid $2.17 for 4 feet. Hope this helps
Old 05-15-2011, 11:55 AM   #9
HufferSS
I Wanna Go Faster!!
HufferSS's Avatar
Drives: 2011 2SS Synergy Green M6
Do they have a boost and KR option? I'd much rather see if I am pulling timing due to knock than the AF ratio??
HufferSS is offline   Reply With Quote
Old 05-15-2011, 12:25 PM   #10
Oxtar41
Oxtar41's Avatar
check their site or call them. I dont think it would be hard to wire the display in to watch KR if they didnt
Old 05-15-2011, 12:52 PM   #11
Caliman93230
Caliman93230's Avatar
Drives: LS3S/C
KR monitoring seams like a good idea , would like to know if it could be done
MODS whipple 2.9L s/c, ADM race scoop, 600 rwhp 550 wrtq, .
Caliman93230 is offline   Reply With Quote
Old 05-16-2011, 12:56 PM   #12
lock
lock's Avatar
Drives: 11 2SS/RS E-Force Supercharged
Still need to put mine in. Keep putting it off. Did you get the power from the fuse box and run that wire all the way in? Where did you get a ground? I wish the instructions were Camaro specific. They are pretty general.
11 IOM 2SS/RS E-Force Supercharged. 616 RWHP/578 RWTQ. Click link for my journal!!!
lock is offline   Reply With Quote
Old 05-16-2011, 04:25 PM   #13
papabearcamaro
papabearcamaro's Avatar
Drives: 2012 Chevrolet Silverado 4x4 Z71
I will let everyone know my thoughts on these when I get my car back Saturday when my build is finished.
SOLD(Traded for 2012 Silverado Z71 4x4 and 2012 Sonic Hatch.)...2010 Camaro 1SS/RS/LS3,yellow with House of Kolor Tangerine Pearl rally stripes,manual trans.Hurst short throw shifter,4 pack rally gauges,Roto-Fab air intake,Kooks long tube headers with high-flow cats,Borla S-Type catback exhaust,Comp Cam,PRC ported heads,Maggie with 3.6 pulley and 1:1 cog drive,secondary fuel system with 65lb injectors,ADM digital A/F and Boost gauge,Pfadt trailing arms and subframe bushings.614.25rwhp/566.82rwtq on 8# of boost.
2012 Chevrolet Silverado 1500 EX.Cab 4X4 Z71.
papabearcamaro is offline   Reply With Quote
Old 05-16-2011, 05:05 PM   #14
yotaman96
yotaman96's Avatar
Since I had my dash apart doing the HUD, I went ahead and put my boost gauge in last night. I also have the gap on the left and the gauge is slightly crooked.
2002 Trans Am
KITT light installed and Thoughts ttexxan Cosmetics and Lighting Modification Discussions 3 04-27-2010 07:53 AM
4-Pack gauges installed ladysman07 5th Gen Camaro SS LS LT General Discussions 23 01-24-2010 10:49 AM
ARH 1 7/8" + MAGNAFLOW 3" = ADM ROCKS - LOUDLY! Number_9 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 34 12-10-2009 09:24 PM
ADM / Magnaflow 3" system for the ARH Catted system - Pics and thoughts Crowley Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 26 09-17-2009 04:51 PM
A few quick thoughts on the March 16th startup to calm people down... fbodfather 5th Gen Camaro SS LS LT General Discussions 605 02-13-2009 12:29 PM
