Old 01-10-2018, 04:55 PM   #1
Jkelley3209
Jkelley3209's Avatar
Drives: Savage ls
17x10 tire drag set up.
What is the tallest tire you guys have been able to fit on a 17x10 wheel. I just ordered my forgestar 17in drag wheels and haven't decided on a tire yet... curious just how big I can go with stock suspension???
Thanks in advance.
Jkelley3209 is offline   Reply With Quote
Old 01-12-2018, 10:16 AM   #2
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
From my reading. Going tall is the wrong way to go.
You want to keep it around or under 27".
275/45/17 or 295/40/17
Old 01-12-2018, 10:24 AM   #3
Tenfive
Tenfive's Avatar
Drives: 2017 1SS camaro ,2SS a 68 + 08 C6
X2 !! Shortest tire that will hook ( will give you more gear + less reciprocating mass )
Tenfive is offline   Reply With Quote
Old 01-12-2018, 10:26 AM   #4
parish8
Drives: 17 SS a8
The height depends on your power goals. If your keeping it na then a shorter lighter tire will probably make you faster. If your going with a power adder and making a shit ton of hp taller is probably going to work out better for you.
I would go with a 305/45/17 but a smaller tire would be quicker up to the point it no longer hooks.
Old 01-12-2018, 10:33 AM   #5
Jkelley3209
Drives: Savage ls
I will be using a power adder, plan on being 7-800hp. Stock suspension for the time being. 305/45 is what I had planned on. Just wanted some extra input on the subject before diving in.
Old 01-12-2018, 12:12 PM   #6
BradfordCamaro
SABIO
Well... since you will have 700+hp....
I would agree with taller.
Old 01-12-2018, 01:01 PM   #7
atomicfusion
Drives: 07 Z06 11 L99 SS 16 c7 16 1SS
305/45/17 Mickeys all day long
atomicfusion is offline   Reply With Quote
Old 01-12-2018, 04:22 PM   #8
Solid_Sim
Solid_Sim's Avatar
Drives: 2018 Red hot A10 ZL1
I'm wondering why go 17x10 and not 17x9.5 like I found was recommended for our cars?
2018 Red hot A10 ZL1 with black center stripe and Nav. Stock for now!
(SOLD) 2017 Red hot 2SS, M6, NPP, MRC, GM ground effects, ACS Composite decklid spoiler, Mishimoto Catch can, Diablosport i2030 with custom tune, Primary cat delete pipes by CA Performance, Roto-Fab CAI
Solid_Sim is offline   Reply With Quote
Old 01-12-2018, 04:27 PM   #9
Jkelley3209
Drives: Savage ls
I not sure of your source... Forgestar and my local tire connect both recommended 10inch over 9.5.
You're limited to a 295 tire width on a 9.5. Anything wider will start to bubble the sidewall.
Old 01-12-2018, 06:10 PM   #10
Tenfive
Tenfive's Avatar
I agree
Yep you'll need some side wall , and the tire is 27.9 inches in height so not really losing any gear there either .
Probably the best combo you can bolt on there Especially for a power adder .
And def go with 10 inch rim . Just check the proper back spacing and caliper clearance also.
Old 01-13-2018, 08:00 AM   #11
Chevy71
Chevy71's Avatar
Drives: 2016 2SS
Our car comes stock with a 9.5” rim, if you want traction you need rubber on the road and wider tires give you just that.
I run Mickey Thompson ET Street S/S in a 304/45R17 Andy it has been better than any Nitto or Hoosier tire I have tried. Don’t waste your time and money on anything else, honestly! I’ve done the testing. Unless you go full slick this is as good as it gets!
2016 2SS/Hyper Blue/M6/NPP/Navi
Forged pistons
Custom cut Brian Tooley Cam
SW long tube headers
3" stainless mid pipe - Secondary Cat delete - High flow cats
Port and polished heads-Double valve springs-platinum lifters & push rods
Cam phaser limiter - DOD delete
P1SC-1 Pro Charger 3.7 pulley
Stage II intercooler
667rwhp 577ft lbs
Chevy71 is offline   Reply With Quote
Old 01-13-2018, 08:11 AM   #12
parish8
Drives: 17 SS a8
I agree other than running a 15” rear wheel. That is the max effort set up.
Old 01-13-2018, 03:59 PM   #13
Chevy71
Chevy71's Avatar
Drives: 2016 2SS
That’s true, if you’re willing to put the 15” wheel kit on for that added side wall, you will certainly do much better. I haven’t done that to this car yet. Not sure if I will.
Forged pistons
667rwhp 577ft lbs
Old 01-16-2018, 07:02 AM   #14
blkbeauty16
blkbeauty16's Avatar
Drives: 2019 zl1
Any input on what to run up front? I'm going with the race star 17x9.5 with the Mickey Thompson 305/45r17 what size would you recommend for the fronts?
blkbeauty16 is offline   Reply With Quote
