09-01-2017, 07:10 PM | #15 |
Drives: 2017 50th SS convertible Join Date: Oct 2016
09-02-2017, 09:31 AM | #16 |
http://www.ebay.com/itm/Tekonsha-118...-/263181561992
Some body is making a harness for it. |
09-02-2017, 10:00 AM | #17 |
Drives: 2016 2SS, Red Hot, NPP, Nav, M6 Join Date: Jul 2016
I don't see a problem either. Increased clutch wear maybe.
09-28-2017, 01:13 PM | #18 |
Just ordered a Curt hitch and wiring harness myself. Planning on pulling a motorcycle and trailer with mine, probably going to be at 1100-1200 lbs. A friend towed 2 motorcycles with his 5th gen 1LE, no problems. I'm not worried.
09-28-2017, 02:32 PM | #19 |
Drives: '17 ZL1 A10 Vert Join Date: Mar 2017
As someone who knows nothing about towing, what is the difference in stress to transmission/etc between A) a car carrying four 250lb adults plus some cargo in the trunk, and B) a car carrying one 250lb adult and pulling a 1000lb trailer?
The total amount of weight being moved by the engine/transmission is the same, just moved from inside the cabin to behind. |
09-28-2017, 03:26 PM | #20 |
09-28-2017, 08:36 PM | #21 |
Drives: Nightfall, 2SS, A8, MRC, NPP,RE-71R Join Date: Jul 2016
I wouldn't worry about the car handling it, I'd be worried about the hitch not being mounted to a sturdy location of the chassis. Maybe where they mount the hitch is only strong enough for a bike rack.
If its mounted to sheet metal that is only designed to hold a plastic bumper, then I would worry. If the mounting points are beefy, id tow with it. |
09-28-2017, 10:24 PM | #22 |
Drives: 2017 Camaro 2SS 6MT Join Date: Aug 2006
Part of what goes into the load advisory in the owners manual is chassis configuration and strength/load stress at specific points on the chassis.
Pulling 1000 pounds on a trailer connected to the rear bumper subframe is a VERY different load and stress calc on the chassis than having 1000 pounds of people/luggage inside the interior and in the trunk. It also forces all suspension components to shift load and stress points. Towing is not just about your engine, transmission, and brakes. It puts load on the entire car. A Silverado pickup truck is engineered from the start with all of that in mind. A Camaro isn't. If GM says don't tow, don't tow. |
11-28-2017, 11:16 PM | #23 | |
Drives: 2017 Hyper Blue 2SS Join Date: Mar 2017
Thanks Shawn
Hyper Blue 2SS, 6MT, NPP, 6 piston Brembo, 1LE suspensions upgrade, ZL1 Seats, Wheels & Tires
11-29-2017, 10:17 AM | #24 |
Drives: 2016 2SS Join Date: Dec 2015
The hitch receivers available for this car all attach at the bumper beam attach points. You remove the crash beam, slide the hitch over the studs, and reinstall the beam on top. The Draw-Tite receiver doesn't even require cutting the bumper cover, so the install is completely reversible.
I installed the receiver only to carry a bike rack. I'm not sure how much I'd want to tow a trailer though. I wouldn't be so worried about the drivetrain or suspension, so much as the forces on the unibody. As was mentioned earlier in this thread, the attach points may be strong, but they're designed to be strong for a completely different type of force. The direction of the forces from a crash impact would be completely different, and they wouldn't be repeated. Towing a trailer would cause a repeated stress on the mount points. The fact that the ATS can tow, and uses the same type of hitch is certainly interesting though. It's hard to say whether they beefed up the mount points differently on the Cadillacs, or whether the lack of a tow rating on the Camaro is just kind of arbitrary. Sent from my Pixel 2 XL using Tapatalk |
11-29-2017, 09:47 PM | #25 | |
Shawn.
