Old 04-19-2018, 06:24 AM   #1
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
I have a misfire / spark plug issue
Hello all, it’s been a long time! Last week I started having an issue on my L99 with a very rough idle, misfires and backfiring. Yesterday I decided to pull the plugs and while the tips all seemed OK, the threads on 6 of the 8 had a lot of oil on them. See the attached picture. I’m guessing this is somehow my problem, however I’m not very mechanical. The car is six years old in November, but only has just under 13,000 miles.
Any suggestions here? What should I do or what should I be looking for? Someone mentioned to me it could be the valve cover gasket, however I don’t see any oil on the outside. And then someone also mentioned spark plug O-rings, however I can’t seem to find anything about them on the on l99.
Thanks everyone and I look forward to the replies.
Soprano 4/1/00-6/14/11, Gone but NEVER forgotten!
FSP tuned: 377/389
nyrfan is offline   Reply With Quote
Old 04-19-2018, 09:21 AM   #2
DvKillar
DvKillar's Avatar
Drives: 2015 Chevy Camaro 2LS
hmm. looks odd that the electrode seems clean, but threads have wet oil, but not the terminal! were the 6 and 8 plugs seated properly? tight?
DvKillar is offline   Reply With Quote
Old 04-19-2018, 09:44 AM   #3
cypressh
Canadian
cypressh's Avatar
Drives: 2011 Camaro 2SS/RS
Is there a leak from the valve cover by chance? And if not do you see any fluid from the exh. Manifolds at all?
2011 Camaro SS/RS
The cars we drive say a lot about us.
cypressh is offline   Reply With Quote
Old 04-19-2018, 10:06 AM   #4
nyrfan
Let's go Rangers!
nyrfan's Avatar
Like I said only that the treads appear to be wet, but I’m assuming oil is getting onto the electrodes as I’m getting a lot of misfire and backfires. I see no oil anywhere around the valve covers or anywhere else for that matter, only in the treads. And yes they seemed pretty solidly in there.
FSP tuned: 377/389
Old 04-19-2018, 10:14 AM   #5
cypressh
Canadian
cypressh's Avatar
It could be possible blow by, it could also be the excess oil that is ingested through the pcv system that is routed back through the intake.
2011 Camaro SS/RS
Old 04-19-2018, 11:53 AM   #6
nyrfan
Let's go Rangers!
nyrfan's Avatar
I don’t believe this would be blow by.
FSP tuned: 377/389
Old 04-19-2018, 12:12 PM   #7
JD555
JD555's Avatar
Drives: 2014 2SS RS, 6 sp man
When you say backfire do you mean backfire into the intake manifold or an after fire in the exhaust? Backfire is usually caused by a lean condition or a valve stuck or damaged. After fire a rich condition such as lose of spark or overfuel. Weird about the oil only on the treads.
JD555 is offline   Reply With Quote
Old 04-19-2018, 12:26 PM   #8
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
Any CEL? As there’s oil on both banks kind of rules out both VCs leaking. Have the vc, plugs, heads ever been out before? What’s the catch can look like?
camguynj is offline   Reply With Quote
Old 04-19-2018, 12:28 PM   #9
xc_SS/RS
Drives: 2010 Camaro SS/RS
check your valve cover gaskets. it'll just barely be leaking
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 04-19-2018, 12:47 PM   #10
nyrfan
Let's go Rangers!
nyrfan's Avatar
BF through the exhaust. And it doesn't happen all the time. Like yesterday morning it was just a rough idle, but in the afternoon it kept popping
FSP tuned: 377/389
Old 04-19-2018, 12:48 PM   #11
nyrfan
Let's go Rangers!
nyrfan's Avatar
I believe the plugs came out when I had the headers done. Nothing else was removed. CC pretty empty. Also I did get a flashing CEL, which means misfire, but it went off and AZ could not read any codes other then my O2 sensors which are tuned out.
FSP tuned: 377/389
Old 04-19-2018, 12:51 PM   #12
nyrfan
Let's go Rangers!
nyrfan's Avatar
If it's the VC gaskets, wouldn't I see oil somewhere? The engine is completely dry.
FSP tuned: 377/389
Old 04-19-2018, 01:40 PM   #13
camguynj
camguynj's Avatar
Maybe the plug seals are bad from not being torqued to spec from when the headers where installed? It might be worth while to put in new plugs making sure they’re torqued to spec and the seat threads are dry. Then check after a day or two to see what they look like. If oil is present then you know it’s not the plug seals.
Old 04-19-2018, 02:06 PM   #14
nyrfan
Let's go Rangers!
nyrfan's Avatar
Anyone know the torque specs for the spark plugs?
FSP tuned: 377/389
