Roto-Fab
Old 08-15-2015, 09:24 PM   #1
Quicksilver-SS
Quicksilver-SS's Avatar
Drives: 2014 1SS / RS M6
Vitesse Throttle Controller......
So, I've looked thru the threads and the VTC seems to be a nice way to increase throttle response, but has anyone actually compared stock to VTC 0-60 or 1/4 or 1/8 times with it? I'm strongly leaning towards this mod. Just curious about real world gains on a mostly stock LS3 M6.
Quicksilver-SS is offline   Reply With Quote
Old 08-15-2015, 09:25 PM   #2
Quicksilver-SS
Old 08-16-2015, 12:04 AM   #3
MrChrisLS3
Drives: 2018 1SS M6
It's only real effect is open the TB quicker, not more. So at WOT, as in a drag race situation, it has no effect. It's real virtue is part throttle acceleration. like when passing, accelerating while moving, a.k.a. 'tip in' or starting from a stop light. In a nutshell, it removes the gas saving, tire saving delayed response installed by the factory. I like it, but no, it won't increase top end speed.
MrChrisLS3 is offline   Reply With Quote
Old 08-16-2015, 04:29 AM   #4
Red2014SS
Red2014SS's Avatar
Drives: 2014 2SS/RS Camaro
I have tried it at the strip. It's pretty much worthless at the strip because it creates too much wheelspin. Hooking up is the biggest problem 5th Gen Camaros drivers have on the track. The VTC makes it even harder. I plan to get some drag radials and try it again in the future.
2014 2SS/RS, L99, SW LTH w/HF Cats, GMPP Ex. Z/28 CAI, FR41s in PVD Black Chrome, Recaros, Pfadt Sway
377hp, 383tq 12.739@110.44 MPH
Red2014SS is offline   Reply With Quote
Old 08-16-2015, 09:16 AM   #5
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
its not so much a mod, and having been on here for years.....there was a big FANBOY base for people to buy it and try it and they said sure no problems ever..... then the problems slowly trickled in, then a flood when they talked to each other. It just changes the response which is a delay in the potentiometer ( The thingy you hook it up too), opening the throttle blade rather than slower opening, do not expect any real performance gain or totally trouble free life for the product, and as a matter of fact its undesirable to loose traction due to so fast a response for those of us who are highly modified.
The potentiometer is basically a resistor slowing the impulse so the car gets better traction for safety and better fuel economy for making every bit of mileage for the EPA etc..... And not chirping the tires at every stop light is nice when your modified, and tuning does reduce the LAG that's especially present on Automatics like the one I used to own a 2011 2ss/rs vert L99.
christianchevell is offline   Reply With Quote
Old 08-16-2015, 09:17 AM   #6
954camaro
954camaro's Avatar
Drives: Camaro SS/RS inferno red interior
Ummmm I tried it and it helped me at the drag strip. Got a lower time because I got into my power range must faster than I could without it. So I say it helps! You just got to be able to put the power to the ground
954camaro is offline   Reply With Quote
Old 08-16-2015, 11:51 AM   #7
Bo White
Bo White's Avatar
Drives: 2015 Summit White 2SS 1LE
Local guy with a L99 on DRs didnt see any gain but that was one case I know of.
Bo White is offline   Reply With Quote
Old 08-16-2015, 12:06 PM   #8
hammdo
'It's an experiment'
hammdo's Avatar
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE
I have it. When my L99 was bolt on only, it would help throttle response but no power gain. I'd set it between 3 and 5 and you could tell the difference... and the fuel Milage. Milage would drop! I tested that and sure enough, you'd have to set it to 0 once you're on the highway. It was fun to use for take off.. Now that I'm FI, I don't even use it- just not needed. For a bolt on or V6, I can see it being fun to play with and may help a bit on takeoffs...
-Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari
See My Build: http://www.camaro5.com/forums/showthread.php?t=385577
hammdo is offline   Reply With Quote
Old 08-16-2015, 12:09 PM   #9
AF1Strider
AF1Strider's Avatar
Drives: 2011 Camaro 1SS/RS
Big reason I got rid of mine was didn't help at the Strip. It made the car "feel" faster but did nothing for 1/4 times. I actually ran better with it off, better launches. It did make the burnout easier if I was to do one.
AF1Strider is offline   Reply With Quote
Old 08-16-2015, 06:51 PM   #10
62nalide
62nalide's Avatar
Drives: 2013 SS
lol @ post #4 and #6
These guys made my day lol
62nalide is offline   Reply With Quote
Old 08-17-2015, 05:25 AM   #11
Red2014SS
Red2014SS's Avatar
You're such a great guy. Glad to see you were entertained. If there is anything else you need, just ask!
Old 08-17-2015, 01:43 PM   #12
954camaro
954camaro's Avatar
Old 08-17-2015, 05:00 PM   #13
Jasper
Jasper's Avatar
Drives: 2011 Summit White Camaro SS (LS3)
I like it and wouldn't get rid of it unless it was glitchy. It's fun and worth the money. Been running it all this year and not an issue to be seen yet. I turn it down to zero and wonder how I could ever put up with the car before. It feels so sluggish.
J
Jasper is offline   Reply With Quote
Old 08-17-2015, 05:57 PM   #14
1LE Timmy
1LE Timmy's Avatar
Drives: 2014 1SS 1LE
Can't you do the same thing with an actual tune?
1LE Timmy is offline   Reply With Quote
