Old 07-15-2014, 11:24 PM   #1
KahunaSS
KahunaSS's Avatar
Drives: 2011 Camaro ss
2011 Camaro 2SS Can Not Burn Out & Low Idle
i have a 2011 AUTOMATIC ss camaro and i have been trying to break the tires loose and i can't do a burn out to save my life.. only time i can get a little spin is if I'm in a sharp turn or in dirt... If i hit the brake and gas it it will spin a little before stopping.. Basically I'm losing power and it feels sluggish,, I did a fuse pull #5 and #20 (overnight) and still nothing,, I put on a CAI and still nothing,, I replaced the Maf sensor and still nothing,, Went to the dealer and had it test driven by service tech and he said the car does feel sluggish and it is bogging out when you punch it, so he made a report and is said he will look into it...., Its killing me.... I have babied the car it has 37,000 miles and i wanna have some fun now, The car always meet my expectations on the highway when speeding and racing cars in motion but on take off it sucks!!! My friends V6 feels stronger on take off. I also have taken of TC and ST and BOTH and put it in Comp mode.. STILL NOTHING!! Can anybody help me?? I have looked al under my hood for something and nothing,.,, No lights on or anything. I don't sometimes get a rpm jump from 1st into 2nd.. car shifts at 2000-3000 rpms and sometimes it jumps to 5000 and catches,.. also the car idles at 400 to 550 rpms up and down,, PLEASE HELP!!!!! I would just start adding things but i still have power train warranty till 100,000 miles
KahunaSS is offline   Reply With Quote
Old 07-15-2014, 11:31 PM   #2
rebelyell22
rebelyell22's Avatar
Drives: 2011 SIM 2SS/RS LS3
You are running premium, right? Hold the traction control for 10 seconds. It shuts it all off
2011 2SS/RS built 8/24/10
rebelyell22 is offline   Reply With Quote
Old 07-15-2014, 11:36 PM   #3
i2disturbedSS
i2disturbedSS's Avatar
Drives: 2010 SS L99 IOM
Yes what kind of gas?
Have you owned it since new?
You shouldn't have to turn everything off -
What kind of tires do you have and how hot is it in South Jeresy?
369rwhp/392rwtq
"Spending money I don't have, to buy parts I don't need, to impress people I don't know!" -Jenkins
i2disturbedSS is offline   Reply With Quote
Old 07-15-2014, 11:58 PM   #4
TommyTheCat
SHKE BKE
TommyTheCat's Avatar
Drives: 2013 Camaro
I've heard a lot of related problems even on the ZL1s. I think they were all automatics, too. Maybe do a search and someone found a solution.
TommyTheCat is offline   Reply With Quote
Old 07-16-2014, 12:19 AM   #5
rberns
rberns's Avatar
Drives: 2011 Camaro 2SS/RS
The L99s start off in 2nd gear. So if you use your paddle shifter and bring it down to 1st gear it should help out more.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8 full exhaust, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, MM can, GFX, Subs, B&M Deep transmission pan,
Holley fuel rail, Proform valve covers, relocated coil packs
rberns is offline   Reply With Quote
Old 07-16-2014, 04:14 AM   #6
Destructo09
Drives: 2010 CGM Camaro 2SS/LS3
I noticed the same thing in the 2013 Automatic SS Convertible I rented in Arizona. It had pretty worn P-Zeros on the back and from a stop there really wasn't any tire spinning action going on. It wouldn't do a burnout either like you said.
I felt like the torque management or something maybe had something to do with, but not sure. First gear didn't really make any huge difference when I tried manual mode either.
2010 2SS
BMR 1" Springs
Koni Orange struts/shocks
1LE rear sway bar
SRP Racing Pedals
Hurst Billet short shifter
Square tire/wheel setup
Elite Engineering Catch Can
Stainless Power longtubes/highflow cats
K&N Typhoon CAI
RPM Motorsports of Garner, NC dyno tune (421 RWHP)
Destructo09 is offline   Reply With Quote
Old 07-16-2014, 06:37 AM   #7
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: 2023 ZL1 Sharkskin
You must be blowing the doors off against your friends if you car is Hooking all the time and all they do is spin when they floor it. There is just one little thing you are probably not doing right, these car will burn some rubber if you learn how to do it.
These threads confuse me a lot because you get one thread they someone cannot do a burnout and another thread where they cannot get the car to hook at all. I know I would be happy as hell if my car hooked up no matter how hard I hit the pedal.
hrpiii is offline   Reply With Quote
Old 07-16-2014, 07:19 AM   #8
Trob85
Svt lol
Trob85's Avatar
Drives: 2011 ss inferno orange blown
It isn't that hard to do a burnout I don't know why these threads keep coming up. Turn off traction control............foot on the brake.....give it gas hard enough to break the tires loose.........regulate the tire spin and that's how you do a burnout.
plasti dip is not a mod.......and a cold air intake doesn't make you fast!
Trob85 is offline   Reply With Quote
Old 07-16-2014, 07:23 AM   #9
CamaroKid300
ace5.org
CamaroKid300's Avatar
Drives: 2017 ZL1 M6
LS3 ftmfw
Stock...For Now.
CamaroKid300 is offline   Reply With Quote
Old 07-16-2014, 07:24 AM   #10
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
OP: you car is idle fine, your right in range.
I have no issue lighting my L99, and that's without turning any nannies off, in fact I can chirp all the way up to 4th. Grant it I am tuned and that made the biggest difference.
Soprano 4/1/00-6/14/11, Gone but NEVER forgotten!
FSP tuned: 377/389
nyrfan is offline   Reply With Quote
Old 07-16-2014, 07:32 AM   #11
rontammy0
Drives: 2011 2SS/ RS INFERNO ORANGE L99
I have no issue lighting my L99, and that's without turning any nannies off, in fact I can chirp all the way up to 5th. Grant it I am tuned and that made the biggest difference.
oh yea...speaking of chirping...chirp this......http://youtu.be/ozDDYcyrCNE
rontammy0 is offline   Reply With Quote
Old 07-16-2014, 07:38 AM   #12
nyrfan
Let's go Rangers!
nyrfan's Avatar
wtf
FSP tuned: 377/389
Old 07-16-2014, 07:39 AM   #13
Duke
Duke's Avatar
Drives: 2010 Red SS/RS
If you get a a chirp, then you are not running Pirelli's. What tire do you have on the rear.
I am still running Pirelli's and they are dead silent. Frankly, I'm tired of the silence.
Duke is offline   Reply With Quote
Old 07-16-2014, 07:40 AM   #14
nyrfan
Let's go Rangers!
nyrfan's Avatar
I am running the stock PZERO's. For the record I meant to say up to 4th, not 5th.
FSP tuned: 377/389
wrong subforum
