12-04-2016, 02:45 PM | #1 |
Drives: 2016 Camaro 2SS Join Date: Jul 2015
Brakes
Hey guys just wanted to see if anyone is having this issue too. My 2016 2SS seems to have had issues with the brakes since owning. Whenever I'm on the freeway and hit the breaks I can feel shaking in the steering wheel and sometimes at lower speeds as well (like 30-40mph) The dealer machined the rotors twice and then just replaced them and now it seems to be doing the same thing again. I've never owned an SS or had Brembo brakes before but I feel like this isn't normal. The dealer kinda blamed me saying I was breaking too hard but I'm not. Even so I shouldn't have that many issues with them so far. I live in LA so i sit in the traffic a lot not sure if this is a factor or not. Thanks guys for any input
Sent from my iPhone using Tapatalk |
12-04-2016, 03:32 PM | #2 |
Drives: 18 Silverado 1500 Join Date: Dec 2015
Mine has 11,600 miles and never shakes during braking.
12-04-2016, 03:35 PM | #3 |
Drives: Fifty Join Date: Nov 2016
Mine seems fine. There is a small break in for brakes as well. What I do when I put new brakes on is slowly warm them up kind of pump the brakes while on the highway. Then when they are good and warm I'll be going about 65 then press hard on the brakes to slow down to maybe 40. I'll do that twice then go about 5 miles so the brakes can cool down some and I'll do it once more. For me it beds in the brakes and heat treats the rotors. Also what I do is each time I get in any car I'll warm up the brakes slowly before needing them. I also probably go overboard but every time I stop I will pump the brakes a little to warm them up before each stop. That last part is probably going overboard but I never have warped rotors and my brakes work great. Thinking about it one of your calipers may be sticking or something. If it keeps up try a different dealer if you can. Hope you can find and fix your issue.
2017 Fifty 2ss/NPP/SEMA rear lights/K&N air filter/LED side markers/Catch can
12-05-2016, 11:10 AM | #4 |
Drives: 2016 Camaro 1LT Join Date: Apr 2016
Have you had your tires checked to make sure they are balanced and aligned?
12-05-2016, 01:09 PM | #5 |
Drives: 2016 2SS Convertible Join Date: May 2012
12-05-2016, 02:46 PM | #6 |
Drives: '17 2SS convertible'20 Yukon Denali Join Date: Nov 2011
Could also be the pads. I put on PowerStop Z23 pads to cut down on the brake dust. No problems with the stops, even fairly hard ones. I didn't have a problem with the Brembo except for the dust.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers Delivered: 08/15/2016 #TeamBeckyD |
12-05-2016, 02:50 PM | #7 |
Drives: Hyper Blue Metalic gen 6 Join Date: Dec 2016
Could have warped rotors
12-05-2016, 02:52 PM | #8 |
Drives: Kubota 2640, 83 BMW R-65, 2017 1 SS Join Date: Nov 2016
I agree with the balance, alignment suggestion. Had a vehicle that did the same thing. Turns out one of the front tires was out of balance, had lost a weight. Funny deal; never felt the imbalance except when braking.
12-05-2016, 02:54 PM | #9 |
Drives: 2016 Hyper Blue 1SS Join Date: Jul 2015
My car did this before I was in a accident and couldn't figure out what was going, all is well after they replaced alot of suspension parts while repairing car.
1ss/Auto-Hyper Blue
acs carbon flash spoiler, bmr springs, gm clear tails. Texas speed cam, 223/227 .635/.635 116 LSA, Kooks Long Tube Headers with green cats, MSD Atomic Air Force Intake, CAI Cold Air Intake, QTP cutouts. 503 hp Best so far 11.5 at 123 with a 1.83 60ft. BMR lower and upper trailing arms and upper control arms,E85 DELIVERED 12/29/15 http://youtube.com/bybcous " no talking only racing on my youtube" |
12-05-2016, 04:19 PM | #10 |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
Check the wheel/tire assembly balance. Also have the front suspension checked for anything that may be loose (inner and outer tire rods, wheel bearings, strut to knuckle bolts and strut top mount), to be sure. If the rotors are warped, you'd have an issue at medium speed and possibly low speed as well.
I very much doubt you're causing an issue with the brakes... |
12-28-2016, 12:49 PM | #11 | |
2016 2SS 6-Speed Manual... Magnetic Ride Control, Dual Mode Exhaust, Sunroof, Adrenaline Red Interior, Mylink W/Navigation
Added Edelbrock E-Force Supercharger, GM 1LE Sway Bars, BMR Upper/Lower Trailing Arms, BMR Upper Control Arms. BMR Front/Rear Chassis Braces, BMR Tunnel Brace. GM Red knee Pads, GM Black Front Splitter, GM SEMA Concept Grille, GM Dark Taillights, GM Ground Effects package... Savini Di Forza BM-14 Gloss Black Wheels 9's front, 10's rear. |
01-03-2017, 05:12 PM | #12 |
Drives: CamaroSS Join Date: Jul 2016
Try some two piece rotors built with feature allowing heat expansion/contraction which should alleviate this vibration issue during heat cycles.
01-20-2017, 11:38 AM | #13 |
Drives: SS 6 speed of course Join Date: Jan 2016
i have the same issue as OP, I'm looking for better rotors... um I drive hard... really really hard.
Power stop looks good and reasonably priced: https://www.carid.com/2016-chevy-camaro-brakes/
01-20-2017, 11:51 AM | #14 | |
I used to be Dragoneye...
If they've established that the rotors are not the problem, then they should move on to something else. It's nearly impossible to "brake too hard" and overheat these things in daily driving...they're big, and have coolers. You'd have to be at the track, regularly... |
