02-18-2016, 11:09 AM | #43 | |
Drives: All things Turbocharged Join Date: Dec 2010
02-18-2016, 11:35 AM | #44 |
Served USN - Atomic Chimp
Drives: 2021 Camaro ZL1 1LE A10 Join Date: Jul 2012
In v2.24 HPT, you had to use a equation manually entered which was in the Help pages. In v3, they have a Boost [Math - User] function that you can. I'm not sure what it uses for Atmospheric Pressure, 14.7 or the Baro from the car. It will read negative when vacuum.
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
02-18-2016, 09:02 PM | #45 |
After looking at the video it actually is the same set up that I have now but I do like how you installed the solenoid so when I get a chance I will have to change that and eliminate a short hose, what is the mph switch, not like my set up needs it but maybe down the line
Cai intake and a few other mods😎
02-19-2016, 08:58 AM | #46 |
Drives: 2013 Black Camaro 2SS/RS Convert. Join Date: Jun 2013
Taking notes...yes
2013 Camaro 2SS/RS-Smoked tail lights and side markers, HID log lights, & LED lighting inside/outside the car, SJM LED Cupholder, SJM full dashboard ABL lighting, ZL1 Rockers, 1LE Splitter, Showstopper LED Mirrors, Showstopper LED Side Markers, & Showstopper Heat Extractor Hood, 20" Niche Concourse ZL1 Styled wheels 20X8.5 & 20X10 with 275/40/20 & 315/35/20 Nitto Invos, Black Gorilla Lug Nuts/Locks, Black Billet Elite Camaro License Plate Holder, and Hydro Dipped Speedo/Shifter/AC-Heat Bezels.
02-19-2016, 09:26 AM | #47 |
Op do we have a final verdict yet on what happened to your ride?
02-19-2016, 04:36 PM | #48 |
Drives: it changes Join Date: Nov 2010
That's crazy that in this day and age any modern controller doesnt have some degree of closed loop control...and the AEM isnt even dirt cheap !
That's a huge FAIL on AEM's part. You'd maybe expect that for a $100 controller, not something 3x the price. |
02-23-2016, 12:10 AM | #49 |
Drives: 2010 2SS Join Date: Sep 2012
why do i always find out these things after i buy and install em...
2010 2SS- 562whp/634wtq 12 psi on3 turbo 78mm magnum /w aem truboost, pat g cam, Kooks 3" catback, Factory Rep 41s with 285/315 20" michelin PSS, Snow Meth, Hex Hood Vents, ZL1 FP & ADM FPCM /w JMS BAP, ID 850s, DSS lvl 4 axles & aluminum 1 piece D/S, Total Pro BMR bushings, fe4 sways, toe rods & trailing arms, Prothane engine mounts, MGW shifter, eaton true trac, mantic 9000 clutch, idealg master cylinder, JDP clutch oil reservoir, ram clutch pedal adjust, Tick clutch & bleed lines, Dewitts Rad
02-23-2016, 12:56 AM | #50 | |
Drives: 2011 2SS/RS (M6) 427 Twin Turbo Join Date: May 2008
Sorry guys i didn't get a notification that anyone responded on the thread. I did a leak down and compression test and the results were 35-55% leakage in each cylinder. Working on deciding what route to go.
2011 Camaro 2SS/RS ERL 427 M6 TT -AGP Twin Turbo 55/57 .83ar | ERL 427ci | Squash Fuel System | Stainless Works Chambered 3" | Mcleod RXT | Factory Hurst Short Throw | Black Forgestar F14s | CTS V 6 Piston Brembo | VIS AMS Carbon Fiber Hood | Anvil Carbon Fiber Spoiler |
02-23-2016, 12:58 AM | #51 | |
My sentiments exactly. I thought it was a pretty decent one but i later find out its considered a dumb boost controller.
02-23-2016, 07:06 AM | #52 |
Drives: 2010 Camaro SS Join Date: Aug 2013
That type of leakage in every cylinder sounds like bent valves to me. Hopefully you get her fixed up and back on the road soon!
02-23-2016, 11:24 AM | #53 | |
He did also mention a compression test was done...what where those results ? |
02-23-2016, 11:09 PM | #54 | |
That is possible because it was my first time trying to use the leak down tester. But when i used it the catch can was bubbling up. Compression test was roughly these figures below #1 -185 #2- 180 #3- 135 #4- 175 #5- 140 #6- 165 #7- 135 #8- 170
