![]() Drives: 2016 Camaro 1LT Join Date: Apr 2016
"If I could turn back time"
Key the cheesy Cher music
![]() For real though, finally did my first rinseless wash with ONR this past weekend. What was I waiting for? I must say that I'm really impressed. The product works great and not having to worry about water spots made the process much less stressful. I used 2 gallons of distilled water and had plenty to spare. I'm on board from here out. The water out here in AZ is just too hard to wash the old fashion way. And I'm way too cheap to buy one of those DI filter things. I just wish I did them from the start and hadn't jacked up my paint learning how to properly wash/dry. The car needs paint correction but for now it's at least clean and protected. I plan on doing another wash this weekend and will post some pics. The car is already covered in a light layer of dust but nothing like it typically is. I did as Glen suggested and used about 7-8 mf towels. That method is great for not introducing extra dirt to the paint but it did take me a little longer than expected. Probably because the car was super dirty and it was my first time. Next time I am going to try it with a nice mf wash mitt. After using the product and watching countless YouTube videos, I am confident that using a mitt will not harm the paint as long as I use it correctly. Anyone out there have experience with Optimum's Big Red Sponge? Would you recommend or no? Any way, if you're on the fence about trying rinseless, just give it a try. I'm a believer for sure. |
You should stick with microfiber towels per panel or so for a rinseless wash. Unless your going to use 7 to 8 mitts?
![]() Drives: 2017 1LT RS Convertible V6 A8 Join Date: Dec 2014
MF Waffle Towels work great, too. I have been using ONR for about 7 years and would never even consider something else.
2017 Camaro 1LT RS V6 A8 Convertible - Silver Ice/Black Cloth, K&N CAI, MRT v. 2 Axle Back, Redline-style Badges and Wheel Hashes, American Authority Grille & a Whole Lot of Attitude
2019 GMC Terrain SLE 1.5T - Blue Steel Metallic/Black Cloth "Soccer Mom Spec" |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 2SS M6 Mosaic Blk Met-SOLD Join Date: Jun 2016
I have the Optimum Big Red Sponge. Its nothing special. Any sponge will work. Optimum recommends the 1 bucket rinseless method and 1 sponge. Squeeze out the sponge in the bucket and the ONR is supposed to encapsulate the dirt and sink it to the bottom.
Official Detailer of CamaroFest 8 & 9
https://www.autogeekonline.net/forum...st-8-pics.html https://www.camaro6.com/forums/showt...=521655&page=1 https://www.camaro6.com/forums/showt...=547470&page=1 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. http://KirkTheDetailer.com |
Retired from Car mfrs....
The multiple towels are the central concept of a rinseless. Because once the towel picks up the debris from the surface and holds it (max 2 panels) you need to discard it. You might as well just use car soap if you're going to use a mitt and do the two bucket method. I don't think you understand the concept of the Gary dean rinsless method.…
#6 | |
I rarely do rinseless... but when I do I use Rag Co. Everest 1100 towels, they hold a ton of rinseless solution.
This method of rolling the towel will keep you from installing any scratches or swirls. When you buy a D/A polisher, correct one panel of your paint first, then get your rinseless method down so you know your not re-installing the swirls/scratches. Once you have it down, then go ahead and correct the rest of the car. The only thing you will need to do in the future is use a finishing polish or an AIO product for very light wash marring.
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles. Last edited by Joe M 2012 2SS; 02-28-2018 at 09:01 PM. |
#7 |
Those are great towels. The only thing that holds more rinseless solution is a natural sheepskin mitt.
#8 | |
I've been using the MM Incredimitt for four years now. Really soft and also extremely durable mitt....doesn't hold quite as much water, but fairly close to a sheepskin. They used to put the Everest 1100's on sale for $4.75-$5.00 each... they haven't done this for a long time! Glad I bought 30 the last time they had this sale. Now if only we could get MM Crazy Pile towels for $5 each...that will never happen! ![]()
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles. |
#9 | |
But nothing holds as much water. I haven't measured it but based on how many rinses until I have to add more water, i'd say it holds 3/4 of a gallon of solution! I have a business account so I can get Everest 1100 towels for about $4.25 each but I can't share that discount so I can't do a group buy.
#10 | |
Again, this was my first time doing one so I might have been a little slower than I needed to be. We'll see. Thanks to everyone for the comments and suggestions because I see this as a real alternative to the traditional wash. Or even worse, driving to the touchless wash ![]() |
#11 |
![]() Drives: 2018 Camaro SS 1LE Join Date: Oct 2011
Is the rinseless solution okay on satin wrap (1LE)?
#12 |
Fine on wrap.....
#13 |
![]() Drives: 2018 zl1 1LE Join Date: Mar 2017
Yes, ONR is pretty much exclusively how i wash mine, no issues whatsoever.
2018 ZL1 1LE
2021 GLS63 AMG 2005 SRT4 2017 Ram 1500 |
#14 |
LT4 M6
Drives: 2018 ZL1 1LE Join Date: Nov 2010
I just placed an order for the Griots garage rinsless kit. Wish me luck.
