Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Old 10-10-2021, 10:17 AM   #1
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
What coolant do you guys recommend? Factory Dex-cool? 2014 2SS LS3
Hi, The car has 14K on it now but I am thinking of changing it because of age, Stick with the Factory brand Dex-cool? I know not to mix coolant types, Just wasn't sure if there's a better brand.
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS
Stainless Works Ceramic LTH/HiFlo Cats
SCT X4 Dynosteve,
Hotckis 1" Springs & Chassis Max Brace
BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings
Pedders Radius Rod Inserts Strut tower brace
Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 10-10-2021, 01:45 PM   #2
demonspeed
not afraid of the wall
demonspeed's Avatar
Drives: Camaros
I believe the coolant is 10yr/100k service intervals. Just run the OE stuff if you don’t feel like doing a full flush. Otherwise, distilled water with water wetter is the way to go of you don’t drive in the winter (which I’m guessing you don’t since the miles indicate you don’t drive much in general).
2023 1LE 1SS BCD GCF JF5 MN6 SIA SLN UQT
10/13/22: 1100
Past Camaros: 13 1LE|02 SS|01 Z28|00 SS|91 1LE|91 Z28|89 IROC-Z
demonspeed is offline   Reply With Quote
Old 10-10-2021, 01:48 PM   #3
ElderJ
ElderJ's Avatar
Drives: 2014 Camaro 1LT
I just roll with Dex-cool. If it already has Dex-cool in it, then you'd have to have a very thorough flush if you want to change coolant type (or so I've been told).
ElderJ is offline   Reply With Quote
Old 10-10-2021, 01:51 PM   #4
Joe.G
Joe.G's Avatar
Yeah, I am just going to run Ac Delco Brand Dex Cool in it. I switched most of my Power sports stuff over to Honda Pro/Type 2 years ago, I also have 2 Chrysler products here that take a Different type from one another and a Ford product and a Toyota as well.. It is a pain with all these different types of coolants. I am not a fan of universal.
I am guessing 4 Gal Total should get the Job Done, I Run The Zerex Dex Cool in my GMC Plow truck.
SCT X4 Dynosteve,
Old 10-10-2021, 01:54 PM   #5
Joe.G
Joe.G's Avatar
No Winter driving, Car is stored in my Climate controlled shop, I have quite a few vehicles, This one is just for some road trips and cruises. I am planning to get back to the track, I have a fully set up 3 RD gen for years that this is going to replace.
SCT X4 Dynosteve,
Old 10-10-2021, 07:37 PM   #6
HOJO
HOJO's Avatar
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro
Stick with what the factory states and you can not go wrong, based on your signature.
HOJO is offline   Reply With Quote
Old 10-11-2021, 08:48 AM   #7
Stingr69
'69 Owned Since '79
Stingr69's Avatar
Drives: '69 Z/28 LeMans Blue w/White
Dexcool but try to not mix it with tap water. Tap water IS compatible BUT you will greatly reduce the anti-corrosion inhibitor life. Leads to more frequent coolant changes required.
Stingr69 is offline   Reply With Quote
Old 10-11-2021, 09:25 AM   #8
Joe.G
Joe.G's Avatar
Yes I know not to use Tap water and what not, I just wasn't sure if there was a aftermarket brand of Dex Cool that people preferred.
SCT X4 Dynosteve,
Old 10-19-2021, 01:43 PM   #9
Joe.G
Joe.G's Avatar
Are you guys changing the Coolant while hot or cold? I don't think I am going to flush it with water, I was planning on just draining it and refilling it along with the coolant tank. I am changing because of age not use/Mileage.
SCT X4 Dynosteve,
Old 10-19-2021, 03:30 PM   #10
xstuntman
Drives: 2012 Victory Red LFX
Hot.
Flushed and cycled it five times with distilled before filling with dexcool.
I change it every five years regardless of mileage.
2018 SS wheels, red Heritage grille, actual driving lights, ZL1 strut tower brace, GM Performance billet aluminum fuel door, front grille Bowtie delete, painted red rotors and calipers, 1/4 window American Flags, splash guards, AEM dry panel air filter.
xstuntman is offline   Reply With Quote
Old 10-22-2021, 06:45 PM   #11
Joe.G
Joe.G's Avatar
I drained the coolant today at operating temp, I did not flush it I just drained it out I tried to get all of it out of the Overflow as well. I only got 2 Gallons back in, I am assuming I did not drain it all. My Plan is to do it again next year then every other after that. I am not a fan of the dark Over flow tank.
SCT X4 Dynosteve,
