Old 05-20-2011, 05:23 PM   #1
forplay
forplay's Avatar
Drives: 2011 2SS/RS LS3
Need new clutch
Well its time to upgrade my clutch set up... I want to get a set up that will handle all the rest of my engine mods + a lil more ..cam will be the next mod going in .. anyone already replaced theirs want to help with some advice.. I would like to keep it as much as possible like the way the stocker feels..Best bang for the buck....
2011 SS/RS M6 Synergy green 559RWHP...530RWTQ
Mods: Maggie supercharger...LS9X Twin disk clutch..85lb Fast inj..ZL1 Fuel pump..,MSD BAP..Roto-Fab cold air..Hotchkis max chassis brace, strut brace,, sway bars front and rear ,HD end links.adj toe link,lower control arm,,trailing arm,, Norris catch can..XS Power 1 7/8 ss lt headers..3" cat delete..3"X pipe..XS 3" mufflers. Hurst shifter.. Lowering springs..22" Foose wheels. Boost/vac ..Fuel pressure gauge..GPS stereo Head unit, all speakers and amp 4 10" subs..Ram air hood.heat extractors .Custom leather interior.Escort 9500ci..
forplay is offline   Reply With Quote
Old 05-20-2011, 05:26 PM   #2
CyberPredator
50 Shades of Prey
Drives: TT/SS
Ls9r
Futral Motorsports built and tuned
CyberPredator is offline   Reply With Quote
Old 05-20-2011, 06:44 PM   #3
urr2slo
urr2slo's Avatar
Drives: 2010 2ss ss/rs abm, 2016 2ss/rs hbm
Centerforce twin disc, best clutch out there, will hold 1200 ft lbs of torq. pedal pressure is 3 lbs less than the stock one. i have over 12k on mine.
URR2SLO - If you're not going fast enough, get out the way......
urr2slo is offline   Reply With Quote
Old 05-20-2011, 06:56 PM   #4
Matster
Matster's Avatar
Drives: 2010 2SS/RS IOM/IOM #3625
LPE ZR1 twin disc is getting good reviews
666 EVIL RWHP BUILT AND TUNED BY SHIFTED PERCEPTIONS INC.(SPi)
416 Forged Stroker, E-Force Supercharger, Blower Cam, Rotofab CAI, Stainless Works 2" LT Headers and 3" Exhaust, LPE ZR1 Twin Disc Clutch, DSS 1400 HP Axles, Pfadt Performance Kit Stage 3.
Matster is offline   Reply With Quote
Old 05-24-2011, 02:31 PM   #5
lock
lock's Avatar
Drives: 11 2SS/RS E-Force Supercharged
I went with the ACT twin disc. Love it. Feel pretty much stock but it actually holds. My stock one was slipping at my power level.
11 IOM 2SS/RS E-Force Supercharged. 616 RWHP/578 RWTQ. Click link for my journal!!!
lock is offline   Reply With Quote
Old 05-24-2011, 03:40 PM   #6
Ovenmitt
Drives: 2011 RJT 1SS
Send a message via AIM to Ovenmitt
Love my spec supertwin st. Will hold more then you'll ever make and drives surprisingly well.
Ovenmitt is offline   Reply With Quote
Old 05-24-2011, 03:44 PM   #7
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
What is the LPE ZR1 clutch good for as far as horsepower and torque?
MODS:
ADM built 417, 2.9L Whipple with 3.250 pulley, ADM ported and polished LSA heads,ADM stage3 cam,ADM LSA belt drive system,ADM CAI race scoop, ADM dual fuel pumps, ID 850's, BMR full suspension, Gforce 9 inch kit with 3.5 inch driveshaft, Street Slayer twin carbon clutch, Lingenfelter oil seperator. Tuned by built by ADM Performance, 763rwhp,705rwtq
10aSSee D is offline   Reply With Quote
Old 05-24-2011, 06:05 PM   #8
RichieRichZ06
RichieRichZ06's Avatar
Drives: 2006 Z06, 2015 Z06, 2014 Silverado
I have the Katech version of the LS9 clutch (alum flywheel instead of heavy steel) in my 582 rwhp Z06 that we race every weekend. I've been running it for 1 1/2 years without issues. I consistantly rip off 1.5 and 1.6 short times on drag radials all night long. it has a stock pedal feel, no chatter and has been able to hold all that I've thrown at it.
RichieRichZ06 is offline   Reply With Quote
Old 05-25-2011, 10:38 AM   #9
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
We put the the Katech LS9Xclutch/Aluminum flywheel in our Ring Spec Camaro build, and echo your comments. Super quiet, always holds power, no issues, easy pedal tarvel, and an overall great upgrade for the Camaro. Just our $.02
|Blair
PfadtRacing is offline   Reply With Quote
Old 05-25-2011, 10:53 AM   #10
forplay
forplay's Avatar
I have read that on the aluminium flywheel it has to be heated for the initial clearance to be set up.. is this what you have found on yours
Old 05-25-2011, 11:37 AM   #11
Matster
Matster's Avatar
Not sure about HP but they list 960+ ft-lbs torque capacity.
Old 05-25-2011, 12:24 PM   #12
Synner
Drives: cars
You just stick it in the oven for a few minutes when the wife isn't home. It expands the aluminum a bit and lets it go in place properly.
Synner is offline   Reply With Quote
Old 05-25-2011, 01:34 PM   #13
forplay
forplay's Avatar
but she will know!!! they always find out !!!
Old 05-25-2011, 01:56 PM   #14
Unreal
Drives: 2006 Z06
Get a LS9 setup from Richie. Great clutch.
Just throw it in the over at 200F for 30 minutes.
Nick
Corvette Z06 -1200ish rwhp
Unreal is offline   Reply With Quote
I want a new clutch, you too????? Sign here tjbusa V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 370 08-10-2013 03:27 AM
clutch pedal repeatedly stuck, minimal load cab2g Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 2 04-26-2011 09:39 AM
What exactly burns the clutch on an m6? DarkneSS 5th Gen Camaro SS LS LT General Discussions 49 04-15-2011 10:55 AM
Clutch being replaced MillerTime V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 29 10-25-2010 04:37 PM
Oil Change Ramp mjlash22 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 17 01-21-2010 10:40 PM
