04-18-2020, 07:34 AM | #1 |
Drives: 2014 1SS/1LE Join Date: Nov 2015
Whipple intake manifold gaskets
Whipple 2.9 intake plenum comes with o-rings like the stock intake plenum plus a set of cometic gaskets. The instructions make it look like you should use both types but I can't imagine that's right. It looks like the o-rings allow it to seal properly against the heads and that is what I would prefer to use. Does anyone have experience with this or a reason why you would double up on gaskets?
Sent from my Pixel XL using Tapatalk
830 WHP 700 WTQ, Whipple 2.9 @ 13lbs Boost, Flex Fuel Tune by Blevins Tuning, LSA SBE, 3.5 GripTec, ATI LS3 Damper, AFR 260cc Mongoose, ARP Studs, Yella Terra Ultralites, Johnson 2110R, BTR PDS Stage 3, Melling 10355, Improved Racing Baffle, ID1050X, DSX Triple Fuel Pump, RotoFab CAI, NW 103mm TB, Stainless Works 1-7/8" LTH to 3" Speed Eng w/ X-pipe to NPP, Powermaster 9509 XS, Detroit Speed Motor Mounts, MGW, Monster LT1-S, ZL1 Calipers, DBA Rotors & Pads, Bilstein B6 Struts & Shocks, BMR 1.25" Drop Springs & Adj Rear Bar, Pegasus Solid Bushings, Z/28 Wheels, other misc parts.
04-18-2020, 07:49 AM | #2 |
Drives: 2015 Camaro 2SS RS 1LE AGM Join Date: Oct 2013
To help against heat soak would be my guess.
Sent from my SM-G960U using Tapatalk
2015 2SS RS 1LE NPP/w Kooks headers, Procharged, ID1050X injectors, Katech belt tensioner, Mighty Mouse Catch Can, BMR subframe connectors, Matco driveshaft loop, AEM Wideband/Boost/Fuel gauges , Z/28 Splitter and Spoiler/w Wicker bill, Power Stop rotors and brake pads, MRR Z/28 Rep Wheels 20" w/p zeros 285 fronts and 305 rears, ZL1 addons Rock guards and Tow hook, Rear window louvers, Flags on the quarter windows and the moonroof, Billet aluminum door handles.
04-18-2020, 08:07 AM | #3 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
Use both. Had the same question when I did mine. Spoke to jannetty and they had the same question for whipple. The answer is both. Orings on the manifold gaskets on the heads.
Will orings themselves be ok, probably. I chose to follow the instructions and suggestions by whipple.
Whipple 2.9 CAI ID1050x injectors ZL1 Pump JRE FPCM JMS Voltage booster JRE Rough Idle blower cam BTR .660 springs CHE trunnion kit 1 7/8 Speed Engineering Borla Atak JRE scoop 1.5" lowering springs BMR trailing arms and toe links Cradle inserts 704WHP 603WTQ 93 octane
04-18-2020, 08:11 AM | #4 |
I mentioned this is my write up when I did the install. Your intercooler hoses likely won't work either unless they updated their kit. I got a new reservoir with old houses to the passenger side I had to get my own hoses and also had to flip my circulator pump around as it wouldn't work the way it came.
04-18-2020, 08:21 AM | #5 |
That's really strange because it mocked up so nicely without it but I'll probably give it a try. I bought the kit used so I know there's a couple of hoses I'll need but thanks for the heads up on checking the flow.
04-18-2020, 08:24 AM | #6 | |
04-22-2020, 08:06 PM | #7 |
That must be an update to their kit, as I got my kit in 2013 and it only came with o-rings. My inter-cooler hoses had issues and the brackets for the inter-cooler did not work. Apparently, my car was a mid-year cross-dresser, and had more of 2013 parts in the front end than 2012. In any case, I called Whipple and they immediately recognized the issue and sent out the right parts.
04-22-2020, 09:14 PM | #8 | |
04-23-2020, 11:09 AM | #9 |
Drives: 2010 Camaro 2SS LS3 Join Date: May 2012
Hmm, I also have a kit from 2013 on my LS3. Also have larger split in the LTFT,s -2% on one side, -10% on the other under normal driving all these years. I wonder if the O-rings alone don't seal perfect, and they added gaskets to help.
