10-29-2018, 12:23 PM | #1 |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
DSX Flex Fuel kit installed.
I'm getting ready to switch to ethanol and the first step was to install the FF sensor so I can read the ethanol content. I'm sure there's a ton of you guys that run this kit on the SS, and I just wanted to make sure everything looks ok with my install.
I'm not crazy about how the sensor is crammed in there with the other hose routed on top of it, but it seems to be the only way. Is this how yours looks? I pinned the white wire to the empty pin 40. I enabled the Flex Fuel sensor in the tune (no math yet) and flashed the car. Now in the scanner I can see ethanol content of 3.1 percent. Am I good to go? I also used some heater hose to cover my fuel line near the headers.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
10-29-2018, 07:57 PM | #2 |
Served USN - Atomic Chimp
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10 Join Date: Jul 2012
It's a pretty simple physical install. The tuning gets a little gnarly.
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
10-29-2018, 10:01 PM | #3 |
LSx FTW!!!
Drives: 2010 Camaro 2SS RS Join Date: Jan 2017
When you get to tuning, do share what you did.
I'm still working on my DSX FF tune. Cold and hot starts need work. It cranks too long before it fires up.
2010 2SS RS A6 781rwhp on E85
Stage 2 ProCharger D1X Circle D 3400 Triple Disc Kooks Jet Hot Headers Kooks Full 3in exhaust Trick Flow GenX 255's Polished PAC .660's & Ti-retainers TSP VVT 3.2 cam kit w/DoD Delete Smith Bro's Trunnion kit AEM X-Series OBDII Widebands FIC ID1300x Injectors GM ZL1 High Output Fuel Pump DSX Tuning Flex Sensor DSX Auxiliary Fuel System Tim King Stage 4 Max Effort CTSV 6L90 DSS 1 piece aluminum driveshaft JRE 6L80E / 6L90E Dipstick NGK Iridium IX spark plugs #7 heat range Mighty Mouse Camaro 5 Wild w/-12an and Billet Black HP Tuners VCM Suite |
10-30-2018, 08:40 AM | #4 | |
www.jannettyracing.com
10-30-2018, 03:25 PM | #5 |
LSx FTW!!!
Mine is usually 9.x % with 93 octane Exon pump gas.
10-30-2018, 06:21 PM | #6 |
This has been worrying me, becuase its always 3.1%, hasnt fluctuated at all.
10-30-2018, 06:25 PM | #7 |
Im paying a pro, not even gonna mess with it.
10-31-2018, 08:22 AM | #8 |
Drives: 2019 Corvette ZR1 Join Date: May 2017
If you're using HP Tuners, feel free to email your tune file to dave@dsxtuning.com. I'd be happy to check it out. If the sensor isn't activated completely, it won't read properly.
10-31-2018, 02:13 PM | #9 | |
11-01-2018, 03:39 PM | #10 |
Thats looks better.
11-02-2018, 06:30 AM | #11 |
LSx FTW!!!
You need more fuel pump.
Look at your duty cycle at a mere 1,100 rpm's....
11-02-2018, 10:37 AM | #12 |
I think its the PID, its always at 99.6%.
11-02-2018, 03:13 PM | #13 |
LSx FTW!!!
Ahh. That's right. I had the same issue now that I recall.
I've used the BETA stable version ever since. Download BETA version here: https://www.hptuners.com/downloads/ Once you do that, download your current tune off the car and mod it through the BETA from that point forward.
11-03-2018, 08:38 AM | #14 | |
