![]() Drives: 2011 camaro 2SS Join Date: Apr 2017
Hand turning crank I hear pop
I am in the middle of installing tsp vvt 2.2 cam and am putting the crank pulley. When rotating slowly I dont have a lot of resistance and do not hear anything. When I turn with a ratchet at a faster pace I hear a pop (like when the spring is off and you pull the valve up quick).
I had crank and cam set at 12 when i put timing chain on, i took the rockers back off to see if keepers were loose. Everything seems right. Obviously dont want to start and blow stuff apart. Any ideas? |
The spark plugs are out btw.
![]() ![]() Drives: 2010 1SS Join Date: Aug 2015
manual? It is the throw out bearing if so.. no worries.
2010 1SS LS3, Black, 235/250, .621/.615, 114 + 4, Kooks Stepped Headers, 3.91's, Bo White PTB, Flowmaster Mufflers, Cold Air Industries CAI, Apex Scoop & Windshield Washer Relocate, SLP Wheels, Skip Shift Eliminate, Barton Flat Stick, OEM HID/Halos, Dyno Tuned by ECS
Started#gottalovethatblue
VVT cam = L99 = automatic.
Hope I can find some advice. I have a completed cam install ready to run, but dont want to start it up. Considering taking the head off and inspecting valves. They were fine when I put the springs on though.
![]() Drives: 2014 Camaro 1SS Join Date: Jun 2010
I remeber hearing a bit of a pop when turning it over by hand. I think it was the valves snapping shut on the seats.
2014 1SS - BTR Stg3, GMPP CNC Heads, Kooks LTs & cats, Magnaflow 2.5" Street w/Res X, Z28 CAI
#7 |
![]() ![]() ![]() Drives: Z06 wannabe Join Date: Feb 2015
My cam chain would sling back against the ls2 dogbone tensioner. I was obvious what it was with timing cover off....echoed thru heads when cover was on. Didnt happen until rockers were on and pressure on lifters.... was kind of like said, valves quickly shutting with spring pressure creating a whiplash like effect of the chain on the dogbone tensioner.
Just an idea, if the timing cover is off and noise is still in the motor or behind then I dunno. I had to pull timing cover and I could visually see it happen. Good Luck!
Apex Focused
#8 |
My plugs were out too.
Apex Focused
#9 |
![]() Drives: 2010 Camaro 2SS LS3 Join Date: May 2012
crank it over with the starter. IF everything sounds normal, and it should, your good to go. I had a header crossover tube leaking once on a new build first start.. sounded like a rod knock. Oh how things that aren't anything can sound like things that are huge.
#10 |
It could be absolutely nothing and I'm just scared to start. I put plugs in and tried to hand crank. Much harder obviously with none of that noise. Just really worried about hitting that key and a hole in the piston being the outcome. Wishing I would have been happy with just bolts on at this point.
#11 |
I have it all back together and really dont want to pull that pulley again. Watching rockers with cover off it seems to come when springs are at total lift. Spoke with dyno steve and texas speed and provided video with both baffled. Thinking about putting camera in each cylinder and if no visual signs of clearance issues just hitting that key. I only decided to go the cam after a weeks worth of good over time. Hopefully wont takes weeks more I'd it goes bad.
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
Looks like your not going to be satisfied as to what it is until you take the timing cover off and have a look. So take the timing cover off and the valve covers off and turn it over by hand a see where the pop sound is coming from . You have gone this far , so just bite the bullet and check it out.
OLD GUY FLYING FAST AND LOW
#13 |
![]() Drives: 2SS/RS L99 ABM Join Date: Aug 2009
I have the same thing going on after having my car sit for a year, finally got it back together, ready to fire, turned it over by hand and hear a clunk every 180* turn, it’s in the same spot every rotation. I don’t remember hearing it the first cam swap. I may just be paranoid from all I’ve been thru with this car. Plugs were out and mines an auto as well.
Rotofab CAI, 2" LT Headers/non catted, 3" Straight Pipe w/ X-Pipe, Elite Catch Can, GPI SS3 VVT, 9" 4000 Triple Disc, Yella Terra Ultralite Rocker Arms, MSD Super Conductor wires
#14 |
Update. I about crapped my pants turning the key, but I started the beast. I am facing getting the tune right at the moment but nothing came flying out. I'm pretty sure the noise was just the valves closing, but it was weird that not many people were mentioning experiencing the same thing.
