06-06-2020, 12:23 AM | #29 |
Drives: Velvet Blue Metallic 2015 1SS 1LE Join Date: Apr 2018
Finally got these all set last week.
2015 1LE on ARC-8's: 19x10 ET20 & 19x11 ET43 in satin black. Tires are the Michelin PS4S: 295/35/19's on all 4 corners. |
06-17-2020, 04:53 PM | #30 |
Drives: Camaro Z28 Join Date: Jan 2017
Doris from Woman Driven rocking a square track setup. 18x11" ET25 front and rear, 1/2" spacer with extended studs up front for strut clearance. Wrapped in 305/680 Pirelli DH slicks
Cory
Cory - Fitment Specialist | Phone: 925.245.0773 | experts@apexraceparts.com
Website | Instagram | Facebook | Blog |
07-29-2020, 05:36 PM | #31 |
This beautiful Procharged ZL1 built by PRE Racing just got a wheel and tire upgrade to handle all that power!
Front: 19x11" ET11 with 305/30-19 Goodyear SC3R Rear: 19x12" ET41 with 325/30-19 Goodyear SC3R - Cory
08-20-2020, 11:26 AM | #32 |
Jeremy's has been tearing up the AutoX courses lately with his 19x11" ARC-8 setup and 305 meats at all four corners.
Front: 19x11" ET11 Rear: 19x11" ET43 305/30-19 RE71R square -2.7* camber front, -1.4* rear with coilovers and camber plates - Cory
10-20-2020, 04:54 PM | #33 |
New 18" and 19" SM-10 fitments coming soon for you Camaro!
APEX Wheel Fitment Specs: Front: 19x11" ET11, Rear: 19x12" ET41 Tires: Goodyear 3R Front: 305/30-19, Rear: 325/30-19
10-21-2020, 11:30 AM | #34 |
^^^^ now that looks killer !!
10-24-2020, 08:33 AM | #35 |
Drives: Moneypit Join Date: Nov 2013
What is the "new" 18" fitment for the SM10? As I still can't decide, the FL-5 or the SM-10 square setup.
Currently, I have 20" TSW Interlagos(square) I've had for a couple years. But need more sidewall in the rears. Thanks |
12-08-2020, 06:50 PM | #36 |
Checkout our Customer Dave's #7 of 24 Hertz-Hendrick Motorsports Camaro ZL1 1LE rocking a set of APEX ARC-8 wheels!
Owner's Instagram
12-08-2020, 06:59 PM | #37 | |
These are aggressive track setups that will require additional negative camber that is normal for track use, but may be a bit much for daily driving. Our 19" lineup will have 19x10" ET20/19x11" ET35 as a direct bolt on with factory alignment settings. - Cory
12-17-2020, 06:37 PM | #38 |
We got some amazing pictures of Chris's ZL1 1LE on a set of our new soon to be available 19" Camaro fitment SM-10 wheels in Anthracite finish!
APEX Fitment Specs: Front: 19x11" ET11 APEX SM-10 with 305/35-19 tires Rear: 19x12" ET41 APEX SM-10 with 325/35-19 tires Tires: Goodyear Supercar 3R Suspension: Stock -Ian
12-31-2020, 04:06 PM | #39 |
Our customer David sent in some awesome photos from his track day at Laguna Seca. His 5th gen Camaro was looking good on a set of 19" APEX ARC-8s in Satin Black.
01-07-2021, 06:33 PM | #40 |
SM-10s really suit the lines of the 6th gen Camaro. Take a look at Stephen's 2018 Camaro SS 1LE on 19" SM-10 Wheels in Race Silver.
01-15-2021, 01:28 PM | #41 |
Back with some ARC-8 content. Our customer James is running a 19x10" ET20 square fitment in Anthracite finish. This is a perfect no nonsense direct fit setup on both the 5th and 6th gen produced with a Camaro Specific center bore.
-Ian
01-21-2021, 06:08 PM | #42 |
Checkout this perfectly modded Camaro SS with Z28 flares. The yellow brake calipers and Anthracite 19" ARC-8s really give an aggressive yet subtle look.
