09-26-2014, 03:55 PM | #1 |
Drives: 2014 1LT/RS Camaro; 2012 VW Jetta Join Date: Jul 2014
Is plastidip worth it?
So I am curious if plastidip is worth putting on the wheels? Does it make the wheels look cheap? How durable is it for daily driving? I never hit curbs or go down gravel/dirt roads. I am contemplating this option instead of having them painted.
Mods:
Vitesse Throttle Controller K&N Cold Air Intake MRT V1.0 Axle-Back Exhaust BMR Strut Tower Brace LG Motorsports ZR28 Black Wheels |
09-26-2014, 03:55 PM | #2 |
Drives: 2013 Camaro 2SS/RS BRM LS3 Join Date: Jan 2013
Dude, it's like $8 a can. just try it.
09-26-2014, 03:57 PM | #3 |
Let's go Rangers!
09-26-2014, 03:58 PM | #4 |
Drives: Varies Join Date: Dec 2009
It actually holds up pretty well!!
You will use about 1 can per wheel. If you don't like it, peel it right off! JT |
09-26-2014, 04:02 PM | #5 |
Most hated in NM....
Drives: Sold the 6POINT2, went to a 50THZ06 Join Date: Sep 2011
Totally worth it.
09-26-2014, 04:15 PM | #6 |
Had plastidip on my wheels for over 6 months and there is no sign of wear on them. I have curbed my tire once or twice as well as drive on gravel roads every few weeks.
I think it looks great and you can't really tell that it is plastidip from a distance. Here is my car with my wheels plastidipped: |
09-26-2014, 04:23 PM | #7 |
2010 2SS/RS M6
Drives: 2010 2SS/RS M6 Join Date: Jun 2010
Overall it holds up well, but it can stain easily. However for the cost, can can plasti-dip your wheels a dozen times for the cost of powdercoating them...
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter Bumblebee Racecar Build |
09-26-2014, 04:26 PM | #8 | ||
Drives: 2023 Camaro 1SS Join Date: Apr 2014
Not to knock those who have plasti-dipped, but it's not a permanent solution and produces marginal temporary results. Might be a good idea if you're trying a particular look on for size (i.e. blacked out wheels). But, if you want professional results, and something that holds up long-term, have your wheels professionally painted, powder-coated, clear-coated, baked, and all that good stuff. |
09-26-2014, 08:21 PM | #9 |
VroomVroom
Drives: 2017 50th 2SS Join Date: Apr 2012
It works for me. Takes some time to do it right, but it's cheap enough to experiment. Just be sure to PREP correctly and you'll do fine.
This is 6 coats of Anthracite Gray and 4 coats of Glossifier. I use Adam's Super VRT to keep the PlastiDip clean.
2017 H50 2SS MX8 F55 NPP CF5 RN2
09-27-2014, 12:36 PM | #10 |
Under construction...
Drives: Black 2012 2SS Join Date: Jul 2014
Use Dip Coat from dipyourcar, it will make the plastidip a lot more durable and it will get rid of the rubber feeling and also deepen the black
2012 2SS/RS, mods coming soon
09-27-2014, 03:09 PM | #11 |
Drives: 2014 Camaro 2SS, 2004 Dodge Ram 150 Join Date: Dec 2012
http://www.camaro5.com/forums/showthread.php?t=277844
Did that with my friend and it still looks the exact same today. Very worth it
09-27-2014, 03:21 PM | #12 |
Drives: 14 SS Sedan Join Date: Jul 2008
If you are wanting a high gloss look, then you will be very disappointed with the plastidip/glossifier.
For matte black, plastidip works great. Sent from my iPhone using Tapatalk |
09-27-2014, 04:26 PM | #13 | |
Drives: 2014 Black 2LS Join Date: Jun 2014
09-27-2014, 04:45 PM | #14 |
2010 2SS/RS M6
Soap & water. Just like the rest of the car.
