08-15-2022, 03:30 PM | #1 |
Drives: 2018 Camaro SS1 1LE Join Date: Feb 2017
4th gen Z28
There's a 4th gen Z28 for sale locally. AT, Convertible. About 100,000 miles. Any thoughts on what I'm look at if I were to buy it and plan on upgrading the Optispark, putting a catch can on it and new plugs and wires? It looks pretty clean inside and out, haven't looked in the engine bay.
Any telltale stuff to look for? |
08-15-2022, 05:39 PM | #2 |
Drives: 2018 ZL1 Convertible M6 Join Date: Nov 2019
What year?
08-15-2022, 05:51 PM | #3 |
Drives: '86 IROC-Z '18 ZL1 Join Date: Jul 2019
Since your saying optispark, I'm going to guess it's an lt1 year. Personally, I wouldn't even look at them and go more for a 98+ for the LS motor. **this coming from someone with a TPI motor in one of their cars.
To answer your question though, optispark will always be a huge pain in the ass for you. There are better aftermarket ones out there but it's going to be totally random when they go out and when they do, it's a pain in the ass. I wouldn't worry about a catch can either. Do a normal tune up.. plugs, wires, belts, fluids, filters, ect. With it being a Convertible, obviously check the rear window and around it for any holes where water could leak into it. |
08-15-2022, 07:07 PM | #4 |
It’s a 95.
08-15-2022, 07:09 PM | #5 | |
08-15-2022, 11:48 PM | #6 | |
Edit: Idk how active the forum is, but check out camaroz28.com if you haven't already. It's a huge 4th Gen forum with tons of knowledge on there. If its happened, it's on CamaroZ28.com |
08-16-2022, 01:11 AM | #7 |
That’s good information! Thanks!
08-16-2022, 08:36 PM | #8 |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
You may want to check out Camaro5.com. Scroll on down and there's an entire section devoted to 4th Gens along with a market place. Your Camaro6 login SHOULD work.
08-17-2022, 06:28 AM | #9 | |
Drives: 2019 Camaro 2SS Join Date: Aug 2020
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
08-17-2022, 03:19 PM | #10 |
Nothing wrong with a 95. Just needs a torqued head 24x conversion and a 411 pcm upgrade. Or LS swap it all together.
2016 NFG 1SS A8
08-17-2022, 04:33 PM | #11 | |
I'm SLOWLY getting mine back in the road. To bad first 2 things I have to do it put in a new starter and fuel pump. |
08-17-2022, 07:00 PM | #12 |
Don't know about the LT1's, but the LS1's for 98 and up had a terrible power steering fluid cooler design that was INLINE with the engine coolant - basically a pipe the engine coolant hoses attached to that contained a little heat exchanger inside for PS fluid. Guaranteed corrosion/leak. So you might want to check for some nasty looking coolant as a sign of that. (I ended bypassing it and putting in a proper PS fluid radiator down below).
08-17-2022, 07:38 PM | #13 | |
Drives: 2023 Camaro 1SS Join Date: Apr 2014
http://shbox.com I've only had 5... 4th gens. Only one LT1 though, which I still have. |
08-18-2022, 06:26 AM | #14 |
Good information. Thanks!
