08-18-2021, 07:12 PM | #1 |
Drives: Track prepped 2018 Camaro ZL1 (a10) Join Date: Aug 2013
Strut towers, max camber and rubbing
Does anyone know if the strut tower assembly, can be installed incorrectly in. 2018 ZL1?
For some reason my Front driver side tire is rubbing on the strut tower lip where the spring is seated, when it never has before even though the alignment is back to the -2.4 camber I had last year when I had no problems. I only noticed this when turning right it only rubs partway through the turn. I am using Camaro ZL1 1LE wheels and tires
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
Tags |
alignment, camber, strut, wheel |
