TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Camaro V6 LLT Engine, Exhaust, and Bolt-Ons
Old 04-13-2014, 08:59 PM   #1
10RsCamaro
Slow v6
10RsCamaro's Avatar
Drives: Automatic Automobile
Send a message via Skype™ to 10RsCamaro
Auto v6 to SS rear.
Ok guys! Starting to buy everything for this project. It is bigger than I thought it would be haha. Already got the differential, and SS axles.
I still need the hubs, and I was asking a forum member a few questions, but if anybody know the part numbers for them let me know!
I will be updating as I go and will be letting everybody know how the butt dyno feels. I'm going 4.10, hopefully it won't be too much :p.
While this is going on, should I take advantage of the install? I know a lot of people say diff bushings while I'm there.
Any input is much appreciated!
Thanks and I am happy to be back!
Matt
Full bolt on 2lt/Rs. Any questions? always a pm away!
Obx/Mace/Rx/Mrt/Vararam/Bcam/4.11 Gears/SS Brakes
USAF. Stationed in TX
10RsCamaro is offline   Reply With Quote
Old 04-13-2014, 10:03 PM   #2
c_cook94
c_cook94's Avatar
Drives: 2011 Rally Yellow 1LT
I'm subscribing. I've been wanting to do this also. Probably 3.91s but to each there own
c_cook94 is offline   Reply With Quote
Old 04-13-2014, 10:05 PM   #3
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
If you already have the ss diff out of the car might as well upgrade the diff bushings since it will be really easy. Don't forget you will also need the second half of the stock driveshaft.
Old 04-14-2014, 07:35 AM   #4
10RsCamaro
Slow v6
10RsCamaro's Avatar
Yeah, looking into that or getting a 1 piece.
Old 04-14-2014, 02:14 PM   #5
10RsCamaro
Slow v6
10RsCamaro's Avatar
Got the SS driveshaft, rear, and axles on the way. Just need to grab some hubs, diff bushings, and I think I should be good to go.
Old 04-14-2014, 02:25 PM   #6
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
Will you be doing the install? I'll be tuning into this one
Click Picture for Build Thread
lscamaro is offline   Reply With Quote
Old 04-14-2014, 02:27 PM   #7
MagnumForceGB
MagnumForceGB's Avatar
Drives: Fastest 2010 Camaro V6
If you can't find the numbers for SS hubs I can try to find them tonight. Make sure you get new axle nuts also. 1LE nuts are different than SS nuts, which are different from V6 auto nuts.
Camaro V6 = 11.268 @ 120.11
MagnumForceGB is offline   Reply With Quote
Old 04-14-2014, 02:35 PM   #8
10RsCamaro
Slow v6
10RsCamaro's Avatar
Thanks for that tip! Yeah I found the SS ones on parts direct. $107 each it looked like. Also if you have the part numbers to the axle nuts that would help. You've been a big help!
Old 04-14-2014, 02:36 PM   #9
10RsCamaro
Slow v6
10RsCamaro's Avatar
It honestly depends. I'm going to ask a few local shops how much it would cost, but I would love to tackle this one myself. If they charge less than 500 I might pay them. The rear already has the 4.10 installed, so it should not be too hard for the install.
Old 04-14-2014, 07:44 PM   #10
MagnumForceGB
The ones I bought for SS Axles are 13217120. They won't fit 1LE axles though.
Old 04-15-2014, 03:15 PM   #11
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
IMO, leave the differential bushings stock. They will introduce a lot of unnecessary NVH for little to no benefit. I typically only recommend them to high HP drag racers.
Best regards,
Tyler
888-308-6007
JDP Sales is offline   Reply With Quote
Old 04-15-2014, 04:00 PM   #12
600hp-lpe
Drives: 2010
that would be a good project to tackle yourself if you have access to a garage, jack stands, and the tools needed to swap everything over.
I have had my rear cradle on the floor quite a few times.
600hp-lpe is offline   Reply With Quote
Old 04-15-2014, 04:43 PM   #13
10RsCamaro
Slow v6
10RsCamaro's Avatar
Yeah, I think I might do it myself!
The diff already has 4.10, and bmr pro bushings in it. I got a deal that I could not refuse, and took a chance at it being too much gearing. I drive the car for fun, not 1/4 at a time.
Old 04-16-2014, 04:47 PM   #14
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Man wish I could get one of these deals lmfao
