dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 07-11-2012, 07:42 PM   #1
CAM ZL1
CAM ZL1
CAM ZL1's Avatar
Drives: 2012 Chevrolet Camaro ZL1
Serious ZL1 Defects
Let me start by saying that I have referenced and researched Camaro5 for information involving both my early production 2010 2SS, and my 2012 ZL1. I have not until now felt that my voice or input was necessary but through the events of the past week I think it is time I put forth my 2 cents.
I ordered my 2012 ZL1 in mid-February at a local but small scale Chevrolet dealership with the hopes that they would come through with an allocation. Several months later and by chance they did receive an allocation and my ZL1 was produced. My ZL1 is number 1526 AGM Manual, and I took delivery of it June 23rd.
I followed the break in instructions to the letter, as per information obtained from Camaro5 along with the owners manual. I passed the 1500 mile point on the 4th of July and proceeded to run the car through some of its paces including accelerating above 4000RPM and a little faster then the 80mph restriction. I by no means drove the car to its limit, but soon found that I could smell some burning oil and as the car had not been driven above 4000rpm at that point I believed it to be normal. I proceeded to park it over night, with the smell of burning oil filling my garage. The next morning I found there was a quite heavy pattern of oil dripping from below the car.
Still hoping for the best I turned the car into the dealership I purchased it from for a post break-in period inspection, oil change, and hopefully to hear the fluid leaking was a normal issue. The spray of oil from the night previous covered a vast portion of the underside of the car and had wrapped onto the rear quarter panel and back of the vehicle.
CAM ZL1 is offline   Reply With Quote
Old 07-11-2012, 07:45 PM   #2
AZ Charlie
AZ Charlie's Avatar
Drives: 2017 ZL1 A10
Okay, so what happened at the dealership?
AZ Charlie is offline   Reply With Quote
Old 07-11-2012, 07:48 PM   #3
xBlackout_Camaro
xBlackout_Camaro's Avatar
Drives: 2011 Camaro SS/RS Cyber Grey
Every car malfunctions, its a part of life
"............don't lose sight of the fact that the Mustang is not only Ford's "Camaro" - it's also their "Corvette". "-FbodFather
xBlackout_Camaro is offline   Reply With Quote
Old 07-11-2012, 07:49 PM   #4
G-Oil Guy
Where am I?
G-Oil Guy's Avatar
Drives: Zoe the ZL1, 2012 Frontier
and what happened? what was the source of the problem? what fixed it?
FOR SALE: 2013 ZL1 Message me if interested
G-Oil Guy is offline   Reply With Quote
Old 07-11-2012, 07:52 PM   #5
TUCSONZL1
Drives: 2012 ZL1-#132
Probably oil filter not tight enough.
TUCSONZL1 is offline   Reply With Quote
Old 07-11-2012, 08:03 PM   #6
CAM ZL1
CAM ZL1
CAM ZL1's Avatar
(Continuation)
After several hours of inspection and some preliminary diagnosing the service manager called me back and had come up with two possible causes for the problem. I drove to the dealership shortly after that and after placing die into the motor oil it was found to be leaking from the open port vents on right side of the bottom of the transmission. The possible causes named were either a defective Rear Main Seal or Oil Pan Seal. The Oil Pan Seal seemed to be the most likely culprit so the following day they dropped the front sub-frame, dissassembled the front fascia and pulled the Oil Pan Gasket which was lacking suffecient sealant so it was replaced and installed with the proper amount of sealant.
Several other issues were discovered as the front fascia was removed in order to get access to the Oil Pan, one of which seems to be a potentially dangerous flaw in production. Attached is a reference photo for the location of this flaw
In this area the service tech found what really could cause a major safety issue.
A wiring harness I highlighted in Red which he said controls the Electric Steering was found mashed between a support and a razer sharp corner of the engine block in the area I highlighted in Green. In his opinion if that harness remained where it was normal engine vibration or road movement could have severed the wiring harness which could leave the ZL1 without steering. He said he would be interested to know if this harness was misplaced during production or if other ZL1's have could have this harness placed in the same location.
Old 07-11-2012, 08:15 PM   #7
72MachOne99GT
Anthrax Popcorn User
72MachOne99GT's Avatar
Drives: 2013 GT500
That one hundred percent blows man.
Hopefully they get it put back together and running soon, and also find out the wiring harness on your car is a fluke.
2013 GT500
1999 GT- sold
1972 Mach 1- sold
...if you want to compare performance numbers, well, the GT500 retains it's title of the highest hp, worst performing car in the world.
72MachOne99GT is offline   Reply With Quote
Old 07-11-2012, 08:23 PM   #8
CAM ZL1
CAM ZL1
CAM ZL1's Avatar
(Continued)
I attached the images of just some of the damage caused by the oil leak. Including some heavy burn and scoring all along the exhaust and on primarily the right side catalytic converter. The tunnel was splattered and as I said the oil had wrapped around the back of the car so heavily the rear camera was useless until I wiped it off.
So the service tech replaced the Oil Pan Gasket, re-assembled the sub-frame and front fascia. He also found that several line supports and clips for cooling lines and wiring were improperly connected, or not utalized at all which I hope explained some of the odd noises I heard from the front end during break-in. He also found that a front end air duct that sends air to the radiator was literally loose in the front fascia so he installed it properly.
I picked up the car 4 days after I had dropped it off which was a very nerve racking 4th of July weekend. I picked it up around 5pm Monday July 9th, drove it for several hours once again putting it through its paces and sure enough the smell of burning oil came back sporadically. I was hoping it was residual from the scoring on the exhaust. I parked the car in my driveway around 9pm and when I had come out around 11pm there was what looked to be about a half quart of fluid which seemed to be motor oil in the relative location of the Oil Pan so I immediately drove it to the dealership. Tuesday the 10th of July the service tech proceeded to remove the exhaust system, and pulled the transmission to have clearance to try and locate the continuing leak.
They pulled the transmission to discover the plate on the back of the block appeared to have small fluid leaks around several bolts.
Also the flywheel which has a balancing fluid similar to motor oil was leaking severely from around the small weld.
The housing and clutch were both sprayed which has caused some severe scoring on the flywheel surface.
So here I am, with my ZL1 less then a month from date of delivery now spending its 7th night on a lift as replacement parts which I hope aren't on constraint are in the process of being shipped to the dealership.
Old 07-11-2012, 08:31 PM   #9
bumblebeecamaro
Car Lover By Nature
Drives: 2016 Hyper Blue Metallic SS
Damn man, that sucks. I'd tell the dealership to keep that car and order you another.
bumblebeecamaro is offline   Reply With Quote
Old 07-11-2012, 08:33 PM   #10
yotaman96
yotaman96's Avatar
Drives: 2017 Camaro SS1LE 2000 Trans Am WS6
That's horrible. They should replace anything that shows signs of the leak. For instance, that exhaust should be replaced. Keep track of everything and how long it stays in the shop in case you end up qualifying for the lemon law. I would not be happy.
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans
2002 Trans Am
2015 Ram Crew Cab Cummins
yotaman96 is offline   Reply With Quote
Old 07-11-2012, 08:36 PM   #11
sammyv
sammyv's Avatar
Drives: 2013 red Lingenfelter ZL1
What a nightmare!
sammyv is offline   Reply With Quote
Old 07-11-2012, 08:36 PM   #12
CAM ZL1
CAM ZL1
CAM ZL1's Avatar
I told the service manager several times to look the exhaust over and the best I have heard so far was that they are going to try to clean it with steel wool. I'm not happy with that sort of response to what I still think qualifies as "New"
Old 07-11-2012, 08:38 PM   #13
CAM ZL1
CAM ZL1
CAM ZL1's Avatar
Unfortunately I don't think they would be able to replace it with a limited production 2012 MY.
Old 07-11-2012, 08:40 PM   #14
grimmace
Drives: 2012 ZL1
get a 2013 and chalk it up to bad luck....from what you have shown make them take the car back and chalk it up to a life experience.
grimmace is offline   Reply With Quote
2012, issue, oil leak, pcv, pos, problem, zl1
