Vararam
Old 01-09-2014, 09:27 PM   #1
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
Boost controller or no boost controller???
Simple question, yes or no for an 1100 rwhp street car that will see the occasional road course and spirited back road driving in north Tx. Will be twin turbo running PTE6766s at 20-22 psi and about 1100rwhp
Been looking at the Eboost 2 for simplicity but am eyeing the AMS-1000 since it seems to be a great unit with more features than i will probably use. But its nice knowing those features are there if needed.
So, yes or no on boost controller. I always thought the right foot was a pretty good boost controller
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 01-09-2014, 09:44 PM   #2
Detoxx03
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Detoxx03's Avatar
Drives: 2008 Corvette
Be crazy not to have one. No sense in going turbo if you're not gonna use one. That's won of the perks of a turbo setup.
D1SC Procharger 932/758 on E85
A Futral Motorsports Creation
https://www.facebook.com/DetoxxAtomic
Detoxx03 is offline   Reply With Quote
Old 01-09-2014, 09:49 PM   #3
acowherd
acowherd's Avatar
Drives: 2010 2ss/RS 4l80. 2009 2500 HD
Heck yes. It would be great for dialing in or out of boost.
Heck I am thinking of throwing on a waste gate and boost controller on my D1sc set up
Follow along as we build and race this 2010 Camaro!
https://www.facebook.com/pages/FNSS-...75028626000379
FNSS Racing!
acowherd is offline   Reply With Quote
Old 01-09-2014, 11:14 PM   #4
yotaman96
yotaman96's Avatar
Drives: 2017 Camaro SS1LE 2000 Trans Am WS6
Installed mine a few days ago. Haven't had a chance to play with it yet. Hoping I hooked everything up properly.
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans
2002 Trans Am
2015 Ram Crew Cab Cummins
yotaman96 is offline   Reply With Quote
Old 01-09-2014, 11:22 PM   #5
Padre
Only drives on Sundays
Padre's Avatar
Drives: '16 2SS A8 NPP MRC NGray
On my D1SC wastegate, I won a True Street index with three runs averaged to within 0.007 of my target.
So, any type of dial-in, it really helps.
Not to mention, with your setup, you might want to have presets for "Sane" and "Insane".
Padre
OLD HOTNESS: The "Heretic": '11 2SS/RS L99 A6 Black/Inferno. Build Journal, Videos
D1SC GT9 JBA-LT = 720/680 | 10.330 @ 133.61, 1.546 sixty... Camaro King at ECS V, Darlington.
NEW HOTNESS: '16 2SS A8 NPP MRC. Bone Stock, 1/8th: 8.051 @ 89.44, 1.919
Padre is offline   Reply With Quote
Old 01-09-2014, 11:41 PM   #6
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
Without the boost controller, you know where you're gonna stand in the power sense. You don't know how tame it'll be on the streets. With the boost controller you can dial the boost down to a more manageable level for every day driving. I would get it.
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline   Reply With Quote
Old 01-10-2014, 02:00 AM   #7
blake-b
blake-b's Avatar
Drives: 2009 ZR1
Yes, definitely get one Bull. Eboost2 here also.
Old 01-10-2014, 09:39 AM   #8
BullF-16
BullF-16's Avatar
Yeah, I'm definitely going to have one. For some reason my shop is recommending against one, or saying it isn't necessary. If it makes the setup better than i think it is necessary
Now time to decide between Eboost 2 or AMS-1000 and get smart on the system
Old 01-10-2014, 10:04 AM   #9
Unobtainium
Fabricator
Unobtainium's Avatar
Drives: 2011 2SS Summit White
I looked at both of those too, and decided on the HKS EVC 6 after talking to a few turbo guys and dyno shops. I'm sure the AMS1000 is killer, but I liked what the HKS offered.
Having a boost controller helps everywhere. It can make the car way more user friendly.
Roto-fab CAI
Unobtainium Welding Exhaust
ARH LT's
393whp L99
GPI VVT Turbo Cam-in
Unobtainium is offline   Reply With Quote
Old 01-10-2014, 10:13 AM   #10
grocerygetter
instigator
grocerygetter's Avatar
Drives: 2020 6.2 Trail Boss, 2022 XC90
the nicer electronic ones can even help spool time. Tested this theory on my Turbo buick years ago. Ended up using a HKS EVC EZ. Spool time was way less that with a halman type or turbonetics type manual set controller.
-John S.
grocerygetter is offline   Reply With Quote
Old 01-10-2014, 10:31 AM   #11
Unobtainium
Fabricator
Yes, one of the biggest advantages for sure.
Roto-fab CAI
ARH LT's
393whp L99
Old 01-10-2014, 10:48 AM   #12
CyberPredator
50 Shades of Prey
Drives: TT/SS
I have the eboost 2 and love it. Also I wouldn't wan't to be stuck at 1100 whp all the time.
Futral Motorsports built and tuned
CyberPredator is offline   Reply With Quote
Old 01-10-2014, 11:15 AM   #13
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10
My understanding is the minimum setting you can set your boost is your wastegate spring pressure. If you're wanting less boost then you have to change out those springs to lessor ones (nominal cost). You can then set your boost controller to a less boost value (only down the the spring pressure), and all the way up to your boost controller/turbos output boost capability. Gives you the range then.
I had to do that with my Tru-Boost controller to get a "wifey" mode in there.
In excess of 1,000WHP
LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates
dreksnot is offline   Reply With Quote
Old 01-10-2014, 11:23 AM   #14
Unreal
Drives: 2006 Z06
Not quite like that. You can usually go ~2.5 spring pressure depending on system, etc. You can't put in 5psi springs then hope to hold 30psi with a boost controller. Typically I would go with the rule of 2x. Run 12psi springs and have good control up to 24psi. Run 7 to 14psi or so as a general rule of thumb. That is way conservative though. 7psi springs probably fine to 18-19psi.
Nick
Corvette Z06 -1200ish rwhp
Unreal is offline   Reply With Quote
