Old 01-12-2017, 09:28 AM   #1
Dysan911
Dysan911's Avatar
Drives: 2017 50th Anniversary 2SS
M6 - Optimal gear for maximum power..
So those of us with the M6. It's best to always know exactly what gear to target when you need maximum torque no matter what your current speed is.
Say you're cruising along on the highway at 65mph and you need full power. How do you determine which gear to select?
Do you guys keep a speed range in your head at all times like
3rd Gear = 70-85mph being that it would be in the 4k range of the RPMs.
For me it seems 3rd gear is great if you're at around 70mph to 75mph. 2nd gear pulls hard at a speed of 30mph-50mph. 4th gear is for 85 and higher.
Just curious if that's about right with what others go by.
Here's the official chart.
Dysan911 is offline   Reply With Quote
Old 01-12-2017, 10:03 AM   #2
Waiting46
Drives: 1981 silver corvette,Hyper Blue 2SS
Good to know the car will do nearly 300 at max gear/rpm
Waiting46 is offline   Reply With Quote
Old 01-12-2017, 10:12 AM   #3
ctrlz
Originally Posted by Dysan911 View Post
Say you're cruising along the highway at 65mph and you need full power...
Ahh, yes, for when you spot that barricaded on ramp for what used be the bridge over Critter Creek and Rosco is hot on your tail.
I would hit the rev match and drop it in 3rd.
Old 01-12-2017, 10:21 AM   #4
Dysan911
Dysan911's Avatar
LOL. Exactly!
Old 01-12-2017, 10:35 AM   #5
diirk
diirk's Avatar
Drives: 2016 Camaro SS
Peak torque is supposed to be around 4-5k. So that would be where your max power is being made.
16 2SS 6MT NPP White | MRR | ACT | JBA | SCT | C7C
04 Ram 2500 CDT 4x4 Quad
91 Miata 1.8 Feal Wilwood Track Car
1morproject
diirk is offline   Reply With Quote
Old 01-12-2017, 10:55 AM   #6
ctrlz
Yes. Using the rev match is a great way to avoid drivetrain shock in this situation.
Old 01-12-2017, 11:04 AM   #7
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
I always need full power, never leave 3rd gear.
Old 01-12-2017, 11:20 AM   #8
diirk
diirk's Avatar
I still get surprised on occasion when I go WOT and the car breaks loose in 3rd gear at 5k rpm. Love it every single time.
1morproject
Old 01-12-2017, 11:33 AM   #9
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
The rpm that you hit peak torque at doesn't have anything to do with maximum power.
Power (hp) = Torque (ft-lbs) x Engine Speed (rpm) / 5252
You can make 600 ft-lbs of torque at 1000 rpm & you won't even be making 60 hp. But 300 ft-lbs @6000 is almost 350 hp.
Do you want to know when you'll have maximum power, like in your thread title, or maximum torque like in your post? Power and torque are two different things that serve two different purposes. Want to accelerate quickly? You need power. I can't think of a reason why you'd actually want to be at peak torque that wouldn't be better accomplished with more power in a lower gear. Yes, when you downshift to 2nd at 55 mph you are going to be very close to peak toque ... but thats not why you're shifting to that gear. You put it in 2nd because if you had gone down to 1st, you'd already be at redline.
Maximum power comes at 6000 rpm for the LT1. So 50 mph in 1st, 74 in 2nd, 102, 132, 178, & not applicable in a stock Camaro SS.
Max torque is at 4400 in the Camaro LT1. 36 mph, 56 mph, 74, 96, 130, & probably not applicable in a stock Camaro SS
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 01-12-2017, 12:58 PM   #10
Dysan911
Dysan911's Avatar
Ok I think I'm even more confused now. lol I just want to know at any given speed what is the best gear for highest acceleration..
Assuming this is correct I went based on peak torque because as you pointed out you don't want to pick a gear that's going to put you at redline.
I think that's where things can get confusing. Basically you need to know in your head at all times at any given speed what gear to throw to for maximum acceleration. Keeping in mind that you don't want to pick a gear that's going to bring the RPM's up near redline.
Example: You could hold first gear from 0 to 50mph. Peak pulling power is around 4400rpm which would be at a speed of about 36mph. Granted you would not want to throw to 1st if you were near 50mph though as you mentioned since it would be to close to redline.
Based on that and the graph I came up with what I think the gear to throw to if your speed equals the following.
Speed 0-37 = 1st gear
Speed 37-56 = 2nd gear
Speed 56-76 = 3rd Gear
Speed 76-99 = 4th Gear
I know this can be confusing because even though first gear can pull hard to 50mph, you wouldn't want to throw to first if you were already doing say 45mph because that would put you close to 1st gear Redline.
Hope that makes sense.
Old 01-12-2017, 01:27 PM   #11
I`m Batman
I`m Batman's Avatar
Drives: 2016 Camaro SS M6
A = F / M
acceleration = force (torque) divided by mass (weight of the car).
These are approx torque numbers from Chevy website for LT1 crate engine.
Based on the acceleration formula and approx torque and weight of the car... the best RPM to be in is around 4000 - 4500 RPM. Maybe even a little bit lower (3750 or even 3500) so you can get more of the meat for longer!
RPM Torq Mass Acceleration
1000 300 3700 0.081081081
1500 340 3700 0.091891892
2000 380 3700 0.102702703
2500 410 3700 0.110810811
3000 425 3700 0.114864865
3500 440 3700 0.118918919
4000
450 3700 0.121621622
4500
460 3700 0.124324324
5000 445 3700 0.12027027
5500 425 3700 0.114864865
6000 400 3700 0.108108108
Since the mass is a constant, and the only thing that changes is your torque... you can just basically use your torque curve to determine your acceleration.
I`m Batman is offline   Reply With Quote
Old 01-12-2017, 01:42 PM   #12
Dysan911
Dysan911's Avatar
Originally Posted by I`m Batman View Post
A = F / M
RPM Torq Weight Acceleration
4000
4500
Nice so rounding the speeds up just a tad I updated it to be
Speed 0-35 = 1st gear
Speed 35 - 50 = 2nd gear
Speed 50 - 70 = 3rd Gear
Speed 70 - 90 = 4th Gear
Speed 90 - 120 = 5th Gear
Easier to remember too.
Old 01-12-2017, 02:30 PM   #13
DGthe3
Moderator.ca
DGthe3's Avatar
I got 10 minutes into writing a big treatise on power, torque, gearing, speed, and acceleration ... then realized thats probably not what I should be doing right now.
I'll get back this thread later this evening when I've got a lot more time.
Old 01-12-2017, 02:55 PM   #14
Hard Parker
OMWTFYB
Hard Parker's Avatar
Drives: ZL1
holy hell 80mph in second gear lol
2017 Camaro 1LE Nightfall Gray Metallic RIP ☠️☠️☠️
2017 Camaro ZL1 Black Exposed CF|Sunroof|6 Speed
Click HERE to follow my build!!
Click HERE to follow me on Instagram
#savethemanuals
Hard Parker is offline   Reply With Quote
