04-25-2018, 01:47 PM | #57 | ||
Drives: 2023 2SS Convertible Join Date: May 2009
-Geoff
04-26-2018, 10:24 AM | #58 | |
Drives: 2017 ZL1 Convertible A10 Join Date: Aug 2017
The Bose amp is spidered into everything sending signals regarding on/off status, etc. So when we unplugged it, thinking that we didn't need it, we had reduced system functionality. The dings, backup sounds, etc did not work. When we plugged it back in, it all worked perfectly. The only thing we could deduce is that there are some weird feedback signals that require the OEM amp to be plugged in in order for them to continue to function. The source of the signal is still the OEM headunit, which is still sending a digital signal out via Tos-link. I wish I had a better answer for you, and could explain why the amp is necessary for correct function of the system. But rather than try to figure out why, we simply observed that we needed it, and kept it plugged in.
'17 White ZL1 A10 Convertible - TM ported TB - RotoFab CAI - 2.3" griptech upper pulley - Kooks 1 7/8" Headers with High Flow Cats - Borla S-type Catback - Audio Overhaul - NavTV M650-GM - 20" BlackDiForza- Michelin Pilot Sport4S - Tuned at BRC Raceworks (606rwhp/675trq)
'14 CTS-V Coupe - ZL1 lid - Ported TB - Ported Snout - AirRad CAI - 8.66" lower - 2.55" upper- Greenbelt - SW Headers - SW Catback - Varimax Intercooler Pump - Track Attack Intercooler-Tuned at BRC Raceworks (551rwhp/516trq) '17 Maserati Levante- STOCK |
04-27-2018, 05:16 PM | #59 | |
Drives: 2017 Bright Yellow ZL1 6spd Join Date: May 2010
First, the MOST network is a ring topology. When you add the Nav-TV, it is being added to the ring in front of the Bose amplifier. Everybody on an unmodified ring has a node address that is assigned when the ring starts up.the head unit, which is the master (node address 100), know that the amplifier is(or supposed to be) at node address 101. The Bose amp will take address 101 at ring startup. And the next device would 102, and so on. When you insert the Nav-TV in between the head unit and the Bose amp, the Nav-TV grabs node 101. The head unit doesn’t know that the Bose amp is now at node 102. The head unit make the audio sink connection to node 101(which it hardcodded to know that is the Bose amplifier, in this case), so the Nav-TV takes the audio packet off the ring and processes the audio, which were intended for the Bose amp. Second, why do chimes and beeps only work when the Bose amp is installed? The Bose amp generates the tones internally. The commands of what tones to generate for a specific function are sent to the Bose amp via the CAN bus. Cars used to have chime modules. With DSPs, it’s just a software function now. Third, and last, whether you are listening to the stereo, or not, the Bose amp is always listening with the microphones, and generating an interference signal to the speakers. The ANC is always active, whether the head unit is on or off. Hope this helps.
2017 ZL1 Bright Yellow w/ black center stripe, 6 speed, CF gas door, PDR, Navi
04-27-2018, 09:08 PM | #60 | |
04-27-2018, 10:30 PM | #61 |
11-29-2019, 08:27 PM | #62 |
Drives: 2016 Camaro 2SS Join Date: Oct 2018
Is there any way to get any other setting than talk as a preset? I have talk and custom. That's it
04-28-2020, 07:47 PM | #63 |
Drives: Chevy camaro Join Date: Jul 2019
My setup is bass +1 treble +9 and mid +1, brought the fade to 3 to the rear. This bose system is setup like a concert hall. Really wish they could've made it more surround style. Cant hear the rears at all unless I'm near to it.
2019 Camaro 1 LT 2.0 Riverside Blue Metallic, ZZP strut bar, K&N intake, ZZP catted DP, MRT axle back, Injen IC piping, Trifecta Elite tune, zzp heat shield, turbosmart diverter valve.
Knockoff zl1 sideskirts, gm front chin spoiler, 1le blade spoiler, diode sides, 20" staggered Asanti black labels, azenis 510 245/40/20 fronts, nitto 555 g2s 275/35/20 rears. |
04-29-2020, 09:58 AM | #64 |
Drives: 2021 Acura RDX SH-AWD Advance Join Date: Aug 2019
My set-up is Bass +9, Mid +3, and Treble +6 with the Fader at dead center.
05-22-2020, 10:08 PM | #65 |
Drives: 2017 ZL1 Vert M6 Join Date: Feb 2019
My set up (like Dr. Feelgood) is GIVE UP - take the PLUNGE and EXPUNGE!!!
https://www.camaro6.com/forums/showthread.php?t=561714 |
