04-09-2016, 01:59 PM | #15 |
04-09-2016, 02:14 PM | #16 |
Drives: 2020 Camaro 2SS Join Date: Aug 2009
Haven't got there yet. I think 5x7 or 6x9 i believe. There was a pic of someone on here replacing the accent piece, Thats where i saw it. I plan on doing my doors in about 2 weeks. so i can give a better answer then.
04-15-2016, 02:02 PM | #17 |
Drives: 2016 2SS Hyper Blue Join Date: Apr 2016
A small thread bump to see if anyone has had any luck tweaking the Bose system.
But to throw my 2 cents in, it seems the imaging is VERY dependent on where your head is in the car. I was at a light other other day and was moving my head around. Closer to the steering wheel, more back to the headrest, higher lower.....etc. People must of though i was on something. .... But if i put my head back more towards the headrest....it sounded a little better and more normal. If they can release an update to the stereo...they should throw in more options and settings. Bass/Mid/Treble PLUS Subwoofer and dash levels. Also enable/disable any sound DSP or cancelling. I have the bass in the middle and its still boomy. Its the one and only thing about this car that I don't like. I hate BOSE....always did and this isn't helping me change my mind either.
'16 2SS Hyper Blue Metallic - M6 - NPP - MRC -Black bowties - CAI Intake - SW Cat Back w/NPP
Other money pits: '13 S1000RR '11 R1200 GS Adventure '01 HD Sporty 1250 |
04-23-2016, 07:37 AM | #18 | |
Drives: 2016 Convertible 2SS Join Date: Jun 2014
Vert - 2SS, NGM, Kalahari, Grey wheels, NPP, MRC, NAV, A8
1100 2/22 6000 4/9 |
04-25-2016, 06:51 AM | #19 | |
04-25-2016, 10:12 AM | #20 |
Drives: GMC Highrider Join Date: Apr 2016
This explains the Bose "Clean Sheet Approach" for designing automotive audio systems:
http://www.bose-automotive.co.kr/flv...tapproach.html |
04-25-2016, 12:03 PM | #21 |
^^ Thanks for that.
04-25-2016, 12:49 PM | #22 |
Drives: 16 Camaro, 11 Stryker, 00 Explorer Join Date: Dec 2015
Bumped up Bass and Treble. Fader to the back one notch. Don't remember the exact amounts off hand.
NGM, 2SS, 6MT, NPP, MRC, Nav, Kalahari, Grey Wheels
1100 12/14/2015 3000 1/8/2016 (TPW 2/1) 3800 2/1/2016 5000 3/5/2016 |
04-25-2016, 04:36 PM | #23 |
One more short video on Bose designing sound systems for specific cars . . . in this case, GM:
https://vimeo.com/160942498 |
05-02-2016, 06:09 PM | #24 | |
Sure, why not?
Drives: 2016 Camaro 2SS, Jeep JKU Rubicon Join Date: Mar 2015
05-03-2016, 07:31 AM | #25 | |
At least its not just me. The system has bass....but just at all the wrong frequencies and curves. This is what pisses me off about Bose the most. Their level of sound customization is too small. (Some by design with the actual speaker design and placement and some by their "Apple" attitude which revolves around "We know more than you do and this is what we think is best for you") They almost build their systems (anything, car, home, headphones...) around "light" music. With soundstages and pre-selected EQ'ing to compliment such music. So I'm sure if I were to tune into a jazz or classical station on XM, it might be alright. But guess what bose....not everyone listens to one type of music. Case in point, I like to listen a lot of stuff but mostly rock/metal/classic rock/some electronic...etc. The vocals come out of the front/dash almost too clear (I'll give it that). But certain frequencies are either missing or are gained up too much. So say for example....80's metal where it's alot of mid's and trebles, but not too much low end. I find the sound too tinny and gutless. If i up the bass slider, I don't gain any substantial and listenable low end. And if I do, it gets washed out by the "boomy" pre-selected and gained up frequencies. Or if I listen to something more modern that has a much fuller sound to it, it's still a no win situation. It might have too much treble, then if i kick down the trebles it starts to completely lose its clarity and vocals. The mid slider almost doesn't so much at all. And the bass is again boomy with no punch or low end. I know it is what it is, but im not dumping money into changing the sound system out. If i had a realistic wish, I wish Bose/GM would release an update to MyLink with more sound customization options. At least have list of music genre types with thier predefined sound processing maps and then we can tweak the trev/mid/bass around them. But chances are that might be a 2018 feature and us early Gen6er's are gonna get nothing. End rant....
05-03-2016, 08:55 AM | #26 | |
Sure, why not?
05-03-2016, 09:37 AM | #27 |
Yeah, I looked into that and there are ton's of sound processors, equalizers, etc...out there. But that's a quite an expensive undertaking. The few I looked at, all convert the speaker level inputs into line level inputs, while EQ'ing them in the process. Not bad....but since the outputs are line level, we'll need an amplifier to boost the sound back to speaker level outputs. Amps need more wiring for power and tap into the control circuit....which might overpower the stock speakers, so I might need new speakers too...
My biggest gripe, is that my 2SS is a lease. So hacking apart the factory Bose connections,amps...and wiring up possibly 2 grand+ worth of gear, just to correct the sound, that's not in my cards. Now if someone were to design a module that uses the factory connections out the Bose amp, and A) is directly swapable with the bose amp with no issues or B) can be put in after the Bose amp and corrects the sound, before the speakers .....I'd be sold. Maybe I'm being too critical of the bose system, but coming from my 2008 A4 which just had the basic sound system in it, it's disappointing. I put an aftermarket headunit in it 3 years ago to get iphone functionality and it sounded even better. No sub, just the stock rear deck little woofer, stock speakers, no amp.
05-03-2016, 09:50 AM | #28 |
Sure, why not?
I find that if I back off the bass a bit, it isn't quite as boomy, but it still doesn't provide a clean bass sound.
