07-29-2014, 01:30 AM | #1 |
Drives: 2014 Camaro 2LT RS V6 Silver Join Date: Feb 2014
Which floor jack do I get?
Low profile? Extra long?
My C5 isn't lowered, so there's a lot of clearance, just doesn't seem like it. I also want to be able to use whatever jack I get to work with my F150 pickup as well so most 3 ton jacks aren't low profile if that's what I need for the C5. |
07-29-2014, 01:43 AM | #2 |
Drives: 2011 SIM 2SS/RS LS3 Join Date: Sep 2013
Most if not all low profile jacks will work. Something like this should be good http://www.northerntool.com/shop/too...6598_200326598
2011 2SS/RS built 8/24/10
07-29-2014, 01:51 AM | #3 | |
http://www.amazon.com/Arcan-ALJ3T-Al...rds=floor+jack |
07-29-2014, 02:07 AM | #4 |
That should work
07-29-2014, 04:26 AM | #5 |
Drives: 2010 Camaro 2LT RS, 2009 GTR Join Date: May 2009
These are great jacks as well
aluminum http://www.harborfreight.com/3-ton-a...ump-61386.html http://www.harborfreight.com/3-ton-l...ump-61253.html
Build thread: http://www.camaro5.com/forums/showthread.php?t=152335
Photos: www.flickr.com/bradbeer GTR Instagram: @NoCrustGTR |
07-29-2014, 09:16 AM | #6 |
I saw the harbor freight jacks, kinda staying away from them as I've heard they are good but not great.
07-29-2014, 09:32 AM | #7 |
Drives: 2011 1LT Join Date: Mar 2012
If you are going to CARRY one, as I do, in the car, aluminum will be the way to go, for its weight qualities.
07-29-2014, 09:32 AM | #8 |
Older Than Dirt
Drives: 2010 & 2013 Camaros Join Date: Apr 2010
A lot depends on how often and how you plan on using it. If every week you're using the pee out of it, stay away from the cheaper versions. If once in a blue moon, those little aluminum racing jacks for cheap just may do the trick.
Omega low-profile or Hein-Werner standard (no low profiles that I'm aware of). Not cheapies, but will suffice and are trusted jacks. As long as you're not trying to lift the entire car, a 2 ton unit should be ok. But with a truck, you may want to up to a 3 ton unit, but that's optional. http://www.northerntool.com/shop/too...9613_200329613 http://www.northerntool.com/shop/too...5577_200325577 With that said, you could buy a bunch of cheap ones for 80 bucks each like 4 times over for the same price. But if you spring for a good one up front, you might not have to worry about buying a 2nd one... And putting jack stands under the car is less scary with a good jack.
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
07-29-2014, 09:54 AM | #9 | |
Drives: Black 14 2SS/1LE/RS 14 Tundra Join Date: Dec 2013
07-29-2014, 09:55 AM | #10 |
Drives: Love the one you're with Join Date: Sep 2009
For me, I want quality when it comes to safety. I buy quality jacks and jack stands. Also if you carry in your car make sure it is secured. I hit a phone pole in a trans am one time and the floor jack came out through the quarter panel. It would have surly came through the back seat if I would have hit head on.
07-29-2014, 10:49 AM | #11 |
That's an excellent point: Secured, and lighter weight makes for better safety.
07-29-2014, 11:21 AM | #12 |
I own two, one aluminum and one steel. Had the aluminum one for years. Never had any issues with either them, just thought I would throw the idea out there
07-29-2014, 11:36 AM | #13 |
I don't think I'll be using it a lot; but I will be using it to get the vehicle on jack stands; both my vehicles come with their own scissor jacks (probably not as great as those aluminum jacks).
I've never seen anyone try to lift a whole vehicle using a single jack; I've seen them use two jacks though. If I had $2,300 I'd buy the portable vehicle lift system from Costco (actually sold by another vendor) which picks up exactly not more than 3 tons (my F150 is 5,600lbs so it has a little room but not much). I like the northern tools 2 ton low profile jack, looks sturdier than some of the other 2 ton jacks I've seen; but I don't think I'd want to pick up an F150 with that even if its to just get it on a jack stand (I'm getting 6 ton rated jack stands with double locking) |
07-29-2014, 08:07 PM | #14 |
Drives: 2011 Camaro 2SS/RS M6 - "Mabel" Join Date: Dec 2013
Agree with everyone else, a low boy jack is a must. When I first tried to jack mine up to change my shifter, I had to drive mine up on some 2x12 cuts of wood to get a regular jack under the front because the lower air dam blocked it from going under at normal height
Tags |
wrong subforum |
