Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
Old 07-11-2014, 12:19 AM   #1
My Caroline
My Caroline's Avatar
Drives: Black 2011 Camaro LS
What is this sound? (Start up choke)
SOLUTION
Well y'all, she's back.
And I have an answer.
As it turns out, the choke on the start up was caused by "excessive carbon build up" on the throttle body. The tech took apart, cleaned, reassembled and relearned the idle. THIS LAST STEP IS IMPORTANT. Over time the carbon on the throttle body caused the throttle to relearn a new position.
NOW, normally I would say this all sounds like bull.... But it worked.
And its only crazy if it doesn't work.
I have been driving the car for a week now just to be sure before I posted, and so far, i have not had one start up issue.
On to the cause of the build up...
bad gas quality.
Now, due to no fault of mine, all the gas where i was out at school was crap gas. I had no choices.
Now that I have transferred schools, I am able to get the good stuff.
Good Luck to anybody else experiencing the issue. Maybe you can tell your dealer where to start.
ORIGINAL POST
Ok guys, this is starting to get to me. My car has gotten to the point that I can predict when this will happen.
Basically, after the car is driven, if I wait around 30 minutes to an hour and go start the car, it coughs like this. This is ONLY when the car is already been driven and warm. Start it and it coughs, shut it off, restart and back to normal, starts just fine.
Cold start is also normal.
Help me out. I'm getting upset at this point.
http://youtu.be/TJRsjJg3EFg
http://youtu.be/XJoZWXKX1C0
http://youtu.be/v8Yy4HHUsBQ
White Fender Hashes from Big Worm Graphix with Custom White Bowties
GM Factory Remote Start and Factory Key Fob
SS Fascia, Factory RS HIDs, Plasma P13W fog lights
Non-RS to RS and fog light harness by Gen5DIY
LED Interior, Trunk, and Licence Plate lights in white
ZL1 Spoiler with Gen5DIY harness
Factory NPP cat back
Blacked out tail light bezels
Factory 20 inch wheels wrapped in Nitto Motivos
Lowered 1.25inch on Eibach Pro springs
My Caroline is offline   Reply With Quote
Old 07-11-2014, 07:07 AM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
Drives: ...and they're both wrong
Embedded them for you
Click to view my build thread
The Stig is offline   Reply With Quote
Old 07-11-2014, 07:38 AM   #3
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
no engine mods? sounds like something in the vacuum system?
2010SLVRBULIT is offline   Reply With Quote
Old 07-11-2014, 08:33 AM   #4
SubSonic
SubSonic's Avatar
Drives: 2014 SS/RS M6
Just throwing it out there, might be a heatsoak issue. I had a jeep that would run rough only if started 10-30 minutes after being full warm. One of the injectors was getting heatsoaked, so the fuel would vaporize. This leaves one of the cylinders without fuel for a few seconds. The TSB solution was to insulate the offending injector that was subject to high temperatures from the intake manifold.
Like I said, I may be off base, but the symptoms are similar.
SubSonic is offline   Reply With Quote
Old 07-11-2014, 08:48 AM   #5
PalmerGA
PalmerGA's Avatar
Drives: 2013 SIM 1SS/RS L99
Sounds reasonable.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
PalmerGA is offline   Reply With Quote
Old 07-11-2014, 08:51 AM   #6
omgitsmikeyC
Drives: 2014 CTS-V- totalled/ 45TH ss- SOLD
I know I've had a few issues with heat soak after my cam. The un coated headers are giving off some serious heat. Getting coated headers and heat wrapping the fuel lines and wiring should help solve it. If you've been tuned, it's time to ditch stock manifolds if you haven't already
2014 CTS-V... with some go-fast bits coming
omgitsmikeyC is offline   Reply With Quote
Old 07-11-2014, 09:00 AM   #7
TheSmokingSuns
TheSmokingSuns's Avatar
Drives: 2017 Camaro 2SS, 2011 Camaro 2LT
Hmmm, that happens to me too after the car is warm everyday now. Cold starts are fine. Sometimes the car even makes a pop noise when I start it. It's been doing this for like a year now and had it for a little over 3 years.
TheSmokingSuns is offline   Reply With Quote
Old 07-11-2014, 12:57 PM   #8
My Caroline
Some good thoughts.
Engine is totally stock.
Any other ideas?
Old 07-11-2014, 02:22 PM   #9
Banshee
Institutionally Insane
Banshee's Avatar
Drives: 2013 IOM 2SS/RS 1LE
Sounds like your A/C compressor clutch kicked in.
Try starting with A/C off.
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspension, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas. What do you say, is it the new Bluesmobile or what?
Banshee is offline   Reply With Quote
Old 07-11-2014, 02:25 PM   #10
wocampb
wocampb's Avatar
Drives: '14 2SS/RS 1LE BRM, '12 Cruze LT 6M
Have them check the fuel pressure to make sure it is holding in the lines after the car is shut off. My car did a similar thing recently and it turned out the fuel pump was bad.
2014 - 2SS 1LE
Ordered - 10/11/13
TPW - 10/28/13
4B00 - 10/30/13
Arrived at dealer - 11/12/13
Arrived in my garage - 11/15/13
SLP Supercharger, SLP headers, SLP Loudmouth Exhaust, Hurst Short Throw Shifter, 1in Hotchkis Springs, SLP Cold-Air Intake, Painted Chrome Strip, Painted Rear Valance, and more to come soon.
wocampb is offline   Reply With Quote
Old 07-11-2014, 11:58 PM   #11
Broke Pilot
Drives: '14 1SS 1LE,'68 Chevelle,'70 Vette
Yep, ^^
Before you go chasing vacuum leaks and heat soak issues, check the fuel/air/spark first.
I'd bet on a fuel pump issue first. After that an ignition issue.
Make sure the pump is always kicking on when the key is turned, hot or cold and check the pressure obviously. Go out and drive it, if you can make the car have the symptom, you're light years ahead of chasing an intermittent issue! Good luck!
Overkill is underrated....
Broke Pilot is offline   Reply With Quote
Old 07-12-2014, 07:39 AM   #12
RollaMo
RollaMo's Avatar
Drives: 2017 2SS
That is what I am hearing too.
1996 Corvette - LT4
2017 Camaro 2SS
2019 GMC Sierra 2500 HD
2015 Harley Davidson Ultra Limited
RollaMo is offline   Reply With Quote
Old 07-12-2014, 08:19 AM   #13
TheSmokingSuns
It's not it. Even with the A/C off, it still hesitates to start.
Old 07-12-2014, 09:22 AM   #14
ChrisBlair
Buick 455 Fan
I can't help myself
wrong subforum
