Vararam
Old 04-03-2014, 06:04 PM   #1
DaveA
Drives: 2013 Camaro SS vert
Slight mistake with touch up paint. Need advice.
I bought touch up paint from the dealer. These damn doors are so big and my garage was so small that I hit the door against the side of the garage. It was light but enough to put a few wear marks on the edge of the door.
I dabbed just a touch of paint on and it worked. However, I got some of the paint on the side of the door, too. It's tiny but obviously I notice it and it bugs me. Can I get some fine sandpaper to remove it or should I just live with it?
I should have used the pen part of the touch up paint. Live and learn.
Thanks for any help.
DaveA is offline   Reply With Quote
Old 04-03-2014, 06:08 PM   #2
Dukeboy01
Dukeboy01's Avatar
Drives: 2002 Camaro SS; 2001 Silverado
If you just did it, I'd try very carefully wiping off the offending drip with paint thinner before it sets.
Dukeboy01 is offline   Reply With Quote
Old 04-03-2014, 06:12 PM   #3
DaveA
No it was like a week ago. I can live with it if necessary. I certainly don't want to damage the factory paint.
Old 04-03-2014, 06:30 PM   #4
SnowyCamaro
SnowyCamaro's Avatar
Drives: 2013 Camaro ZL1, 2006 Chevy Equinox
Did you put clear over it? because there are thinners out there that can remove the touch up paint since touch up paint is usually a different composition. Apparently clear is tougher I dunno. I'm not sure what the difference is but one is enamel and factory is urethane. I think. Hopefully someone can add to this cause I'm not 100% but when I bought my car someone added some bad touch paint to the door and when I had a different panel repainted, my paint guy had some thinner that took the touch up right off without affecting the paint underneath.
I know something exists for this situation, but you'll have to ask a paint guy for the specifics. Hopefully that helps
SnowyCamaro is offline   Reply With Quote
Old 04-03-2014, 06:33 PM   #5
ChrisBlair
Buick 455 Fan
Oh gosh no sandpaper! Just get a good polish and use some elbow grease. No problem
Dave, post a photo. I don't know if I have time this weekend but I'm just outside of Boston down rte. 138
Old 04-03-2014, 06:39 PM   #6
Ron71
Drives: 2013 Camaro 2SS RS Convertible
Lacquer thinner will easily remove the unwanted touch up without removing the factory paint or clear. Just go easy. You need just a little and rub lightly.
Ron71 is offline   Reply With Quote
Old 04-03-2014, 08:20 PM   #7
DARK AGE 53
DARK AGE 53's Avatar
Drives: 2010 SS
Brake Cleaner will work just fine, I've even have used brake cleaner to smooth out touch up paint.
POW/MIA - YOU ARE LOST BUT NOT FORGOTTEN IN SOUTHEAST ASIA
DARK AGE 53 is offline   Reply With Quote
Old 04-03-2014, 08:36 PM   #8
MBS
MBS's Avatar
Drives: 2010 rs 2lt
Just spit on it and wipe vigorously
MBS is offline   Reply With Quote
Old 04-03-2014, 08:59 PM   #9
nUcLeArEnVoY
Oldbie that nobody knows
nUcLeArEnVoY's Avatar
Drives: 2011 1SS/RS M6
Send a message via AIM to nUcLeArEnVoY
Langka system will get rid of that lickety-split. It's also good to have since ti makes for decent touch up jobs.
nUcLeArEnVoY is offline   Reply With Quote
Old 04-03-2014, 09:01 PM   #10
rebelyell22
rebelyell22's Avatar
Drives: 2011 SIM 2SS/RS LS3
twss
2011 2SS/RS built 8/24/10
rebelyell22 is offline   Reply With Quote
Old 04-03-2014, 09:17 PM   #11
beany323
beany323's Avatar
Drives: Camaro 2SS /RS/1LE
classic ..
"The fact the GT500 can barely beat a $37k car with 200 less horsepower speaks volumes. There are about a million mods you can do to a LS3 to make a Camaro do the 1/4 faster then a GT500." (Vroom.)
Updated w/ Willow Springs:
1. Nissan GTR Track Pack 1:19.6 2. Ducati 1198 S 1:19.7 3. Nissan GTR 1:20.3 4. Corvette Z06 1:20.4
5. Audi R8 V10 Plus 1:22.0 6. Ferrari 458 Italia 1:22.3
7. CAMARO SS 1LE 1:22.7
8. Shelby GT 500 1:23.5
9. Mustang Gt Track Pack 1:25.8
beany323 is offline   Reply With Quote
Old 04-03-2014, 10:10 PM   #12
HDRDTD
Here's a suggestion.
I stopped by the local home improvement store and bout a pack of 4 large rubber 1/2" thick 24"x24" tiles that are meant to go on the floor and interlock with each other, and instead of putting them on the floor, I fastened them to the side of the garage so the door hits the rubber tiles if I open the door too far.
Old 04-03-2014, 10:34 PM   #13
OrangeVert
"Catharine"
OrangeVert's Avatar
Drives: '11 2SS/RS LS-3 IOM/IO vert
Great idea!!
OrangeVert is offline   Reply With Quote
Old 04-03-2014, 10:38 PM   #14
jravenfan
Drives: 2013 2SS Blue Ray Metallic
I second the Langka but not the system , just the blob eliminator.
jravenfan is offline   Reply With Quote
