12-17-2011, 09:04 PM | #1 |
Gunning for Sixth
Drives: '03 ZR2 Blazer Join Date: Sep 2008
Took the bird out for a spin, factory Serp-Belt chirping..
Yep, that's right. I'm still running the factory serpentine belt @ 44,441 miles. Chirping is more prominent toward the lower half of the belt path (around the crank pulley). Also noticed a slight loping idle speed when at a light after the car has warmed up. Not that common, but it'll drop to around 550 or raise to 1000 RPM for at most a second. Blipping the throttle sometimes brings it back to a steady 750 idle. Seeing as the last ~15K were put on rather quickly as opposed to the rest of the car, I'm fearing one of two things:
1) The factory belt is finally glazed and giving out or 2) My pullies are going out of adjustment (namely idler pulley). Also taking this to LS1tech but if any of you guys have comments or suggestions I'd like to hear 'em. Especially since this is my 3rd car and I've never had one that had an idler pulley/tensioner or an actual belt go back. Well outside of a catastrophic pulley/belt failure but that's another story altogether.. |
12-18-2011, 06:26 PM | #2 |
get a new belt
12-18-2011, 08:47 PM | #3 |
Drives: 2002 Camaro SS; 2001 Silverado Join Date: Aug 2008
Replace the belt because it's cheap to do. It might fix the problem. Next would be the tensioner. Still relatively cheap.
However, a chirp as opposed to a squeal is probably an alignment problem. Two ways to check and confirm it: 1. Get a spray bottle and wet the belt with water while the engine is running. If the chirp goes away, it's an alignment problem. 2. Put the belt on upside down. If the chirp goes away, it's an alignment problem. The minimal difference in the grooves when the belt is reversed corrects for the misalignment. |
12-19-2011, 12:48 PM | #4 | ||
Truth Enforcer
Drives: anything I can get my hands on Join Date: Sep 2006
replace the belt (duh)
check the tensioner check the waterpump pulley for alignment
A group as a whole tends to be smarter than the smartest person in that group until one jackass convinces everyone otherwise. Quote:
12-19-2011, 02:31 PM | #5 | |
Gunning for Sixth
< Is retarded..
Just.. Yeah, looked up the whole 'shitty factory grease' thing, too. Looks to be simple. Belt isn't wildly/obviously misaligned but the AC belt is almost cracked through. I wanna beat the previous owner with a lead pipe.. holy f'k.. (then again I'm just as guilty so I'll hit myself afterwards..) |
12-22-2011, 11:43 PM | #6 |
Drives: Like I Stole It! Join Date: Jun 2009
Be happy it was a quick fix and you didn't have to replace your a/c. I once spilled coolant on the a/c pulley and that chirp does NOT go away. I guess the coolant gets in the clutch bearings or something and just doesn't play nice.
12-23-2011, 01:03 AM | #7 |
Gunning for Sixth
Oh she was cracked pretty good, that belt. Gonna replace both eventually, but probably just the serp and have the tensioners checked out. All I really need is heat and I have it still so I'm not at all at odds with just leaving the belt off for the sake of less things to replace down the line.
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
irpq11 has permagrin...updated with vids..... | PQ | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 198 | 01-15-2014 12:23 AM |
Superchips checking in | Scott@Superchips | Tuning / Diagnostics -- engine and transmission | 127 | 10-24-2013 04:54 AM |
DIY : Install underdrive pulley on 2010 Camaro SS | Nine Ball | Camaro DIY & HOW-TO instructions & discussions | 34 | 09-30-2013 08:25 PM |
A few questions about BA amp replacement and factory BA audio system | Bama 2SS/RS | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 4 | 03-27-2011 04:41 AM |
