Old 11-30-2023, 07:25 PM   #1
FlukeSS
FlukeSS's Avatar
Drives: 2020 Camaro 2SS A10
Stock ZLE vs Stock Huracan
Should change the name to Surecant
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | Roto-Fab CAI | LT2 Ported | 95mm ZR1 TB | LSA crankshaft conversion w/modified crank gear | LS1 thrust bearing | LS MSD Plug Wire Set | BTR Stage I Cam | ARP Rod Bolts | Delphi Lifter set | NGK LTR5IX-11 spark plug set | DOD Delete | VVT Limiter | ECM, TCM & E85 | Retuned by: Justin L. | Dyno: 510 rwhp 472 rwtq | Best 1/4 Time: 11.639
