03-27-2023, 09:10 AM | #1 |
Ported Intake Manifold
Hello, I am wanting to get a ported intake manifold for my 2010 L99. There are so many different ones I am having a hard time deciding which one I want. Which one does everyone suggest? I currently have kooks 1 7/8’ long tube headers, rotofab cai, magnaflow tips.
03-27-2023, 09:16 AM | #2 |
I would go with the rod modded one from GPI. A lot of folks running this one.
03-27-2023, 11:41 AM | #3 |
Second the GPI suggestion. Ported with the Rod Mod. Quality work and noticeable difference.
BBK Long tube headers, Hi flo cats, straight pipe muffler delete with j-pipes. K+N CAI, Soler Performance Ported Throttle Body, Soler Performance Throttle Controller, Phantom Grill, MGW flatstick shifter. 3.91 Gears, Ported Rod Mod Intake, ZTA Spoiler, Rohana RC22 20x10 20x11.
03-27-2023, 02:38 PM | #4 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
+3
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
03-27-2023, 05:23 PM | #5 |
Drives: 2015 camaro 2ss, 87 monte ss Join Date: Jun 2016
Getting my ported rod mod put on by GPI this week. Hopefully get the car back next week. Anyways ported rod mod is worth 6-12rwhp. On a stock motor expect the low end of that. Big cam motors can make 12rwhp or more.
Only downside of having it ported is they don't recommend nitrous or forced induction. Probably going to have to go back to stock or non ported next year.lol |
03-27-2023, 06:41 PM | #6 |
I have the GPI intake a thoroughly pleased with it, I’m making about 500 wheel hp with heads, cam, headers, shaft mounted valvetrain, and E85. through a 6 speed manual. And the car runs great and pulls up to 7k without any issues.
Orange Krush II
03-28-2023, 08:57 AM | #7 | |
Here's ya some food for thought...
03-29-2023, 07:50 AM | #8 |
GPI Sales Consultant
These guys all covered it really well, but I'll be one more echo - GPI ported rod mod! The OEM really did a phenomenal job with that manifold from the factory, and outside of a hi-rpm combination that plans to rip 7500+rpm, it's very tough to beat for it's overall power curve.
The rod mod really helps the air in the plenum make the sharp transition into the intake runner by giving the air a radius, rather than an edge to follow. Air hates sharp edges! Most of that 6-12whp gain is the result of those radius rods. The porting (which also includes removing the the stands/supports in the middle of the manifold) doesn't seem to do much to add more peak power, but it has a fairly substantial influence on midrange power and torque the engine produces. That's a seat of the pants difference you'll feel every time you rip through that 3500-5000rpm range. As a few noted, we recommend against the porting for boosted/nitrous applications, as it reduces the integrity of the manifold slightly. Specifically, the plugs in the bottom of the manifold where the stands once were are likely to push out under increased manifold pressure.
GPI Max Package 2.0: Brodix BR7 heads/GPI porting, MAX3 cam, ST2116LSR, BSR Max Lift rockers, LS7 LSXR with 103mm TB, Vararam OTR, Mcleod RXT, G-Force/Strange 9" IRS setup with 4.63 gear. 551whp, 11.1@124mph.
Got a question about a GPI product? Feel free to shoot me a message! |
03-29-2023, 08:22 AM | #9 |
Tri-County Camaro SWFL
I went with Rick Crawford, which is basically the same as the GPI. Rick ports the center posts out, GPI has an option for that.
03-29-2023, 01:18 PM | #10 | |
03-29-2023, 04:19 PM | #11 |
Drives: ZL1 Join Date: Dec 2016
Have anyone tried Wilson Manifold?
03-30-2023, 05:38 PM | #12 |
Which shaft mount setup you go with?
03-31-2023, 07:06 AM | #13 |
I know you didn't ask me... but I'll chime in. I have the BSR Max Lift shaft rockers in my build. The quality looked great out of the box, and so far so good with about 5k miles on them. I very much like that they are still a light weight OEM rocker, but coated and treated for strength, bushed, and of course shaft mounted for rigidity and stability under increased spring pressure and RPM.
We've been slipping these into more builds lately - for the money it's really not a bad upgrade for the aggressive hydraulic roller applications. We recommend the shaft mount stuff when you get over 450lbs open pressure - that really starts moving things around on factory individual pedestals.
03-31-2023, 09:34 AM | #14 | |
Drives: 2010 2SS LS3 and 1978 STROKER 383 Join Date: Feb 2018
I'm quite interested. I would consider this another light upgrade to my engine. Must I have a new tune? I assume the procedure will be the same as for the ported throttle body. Datalog and subsequent correction of the fuel map according to the datalog. it is so?
My life is a constant struggle with Camaro.
K&N CAI, Stainless Power longtubes, high flow cats, modified Ragazzon High Performance axle back, Soler Performance ported throttle body, Soler Performance throttle controller, RAM clutch adjuster, modified LS7 clutch kit, Tick Performance billet bearing support, Tick Performance remote bleeder, separate clutch reservoir, BMR trailing arms, BMR toe rods, Pedders Suspension cradle bushing inserts, Control Arm Bushings, Strut tower brace, oil catch can, Hurst T-handle shifter, 20mm wheel spacers, DBA brakes, QTP Cutouts, Dynosteve tune. |
