10-05-2023, 11:33 PM | #1 |
Drives: 2023 Camaro Convertible ZL1 A10 Join Date: Mar 2023
Is this Alignment Correct
When my car was repaired the body shop said that because a wheel (rim and tire) was replaced that an Alignment had to be done before releasing it to me. Now, Looking at the paperwork it looks like they Aligned it for a ZL1 1LE Track use specs on a 2019 -2021. Now is this a problem that my car is a 2023 ZL1convertible and that I don't plan to go on the track. And will it wear down the tires funny or pre mature?
10-06-2023, 08:25 AM | #2 |
Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
I think it's all inspec, it's TOE that will wreck tires, not camber but there is a lot dialed in there, but it should be fine. It's not wrong and they didn't mess up your car though indeed it's ZLE specs.
10-06-2023, 09:37 AM | #3 |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
If you look at it, they printed the ZLE specs, but didn't follow them. Camber is only at 1.x, so basically nothing (which is where it started). They didn't really adjust anything except toe. I would have wanted rear toe to be a little less total, but it's better than it was when they started.
As stated, toe is what kills tires, and they made it better than it started. So you'll have less tire wear than before they aligned it.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp
Past Rides- 2014 ZL1 M6 Red Hot | Tons of mods 2004 CTS-V M6 Silver | Many mods 1995 Corvette M6 Torch Red | A few more mods 1992 Camaro M5 White | A few mods |
10-06-2023, 10:08 AM | #4 |
Thank you Al Oppenheiser!
Yep that's a mostly-good alignment. 99% you'll be fine. I doubt that the 0.01 degree out in the rear will matter more than the difference the replacement tire makes. Either way don't expect more than 10kmi out of the OEM tires, but don't worry about that ... instead enjoy your
Six-Hundred Fifty Horsepower Convertible!! Last edited by Gunkk; 10-06-2023 at 10:20 AM. |
10-08-2023, 10:25 PM | #5 |
meep meep
They "fixed" your toe, didn't touch anything else.
Definitely better than before but mechanic did a "eh, that's good enough" job.
10-09-2023, 07:38 AM | #6 |
PKG4U
And you can obviously see he didn’t attempt to adjust your camber to the specified -2.6-2.9 range. As I would imagine that is the true track camber you would need if running at the track.
2020 Camaro LT1. Bought 10/2020 | GM PERF. CAI | GM Muffler Delete (Performance Exhaust 4” tips). | SOLD 1/2022|
2018 ZL1 Summit White | Bought 1/2022 | PDR, Recaros, Carbon Dash, WeaponX Hx System, Apex SM-10 in ZLE fitment w/PS4S Mods after Warranty “Imma keep it stock” |
10-09-2023, 07:21 PM | #7 | |
