Old 05-07-2022, 04:52 PM   #1
TLSTWIN
Romans10:9-13
TLSTWIN's Avatar
Drives: /\yes, this is me/\
ZL1-1LE BRAKE LINES -STAINLESS STEEL?
SO, for all my track friends, and even more so for the ZL1-1LE guys.
Has anyone swapped out oem to any stainless steel brake lines?
I always have on my cars and bikes, but I have been told by some, "it isn't needed".
I figured you guys that track more often woud give some insight to your thoughts, experiences, opinions.
Thanks
TLSTWIN is offline   Reply With Quote
Old 05-08-2022, 05:23 AM   #2
That1guy_tim
That1guy_tim's Avatar
Drives: Camaro 1ss
Check this thread out
https://www.camaro6.com/forums/showthread.php?t=561322
That1guy_tim is offline   Reply With Quote
Old 05-08-2022, 05:34 AM   #3
khcoaching
khcoaching's Avatar
Drives: 2021 1SS 1LE
I'm swapping to ZLE calipers now with SS lines and will report when I track them at the end of the month....
Ken
khcoaching is offline   Reply With Quote
Old 05-08-2022, 07:12 AM   #4
TLSTWIN
Romans10:9-13
TLSTWIN's Avatar
Originally Posted by That1guy_tim View Post
Long read, skimmed through the blah blah. Seemed like people were interested, but not sure why people weren't just getting the ss lines from Goodridge? Were they not available at the time?
Old 05-08-2022, 07:30 AM   #5
sr71bb
sr71bb's Avatar
Drives: 2019 Camaro Z-28
Thanks
Bottom line is YES, they are beneficial. When the brakes are INITIALLY applied you can notice QUICKER caliper engagement as well as HARDER caliper engagement because stainless lines DO NOT internally flex outward as the brake fluid is being pushed thru them under pressure compared to a stock rubber brake line. It is kind of the same effect as using a HARDER track brake pad in that the brakes engage quicker and HARDER. I use GOODRIDGE stainless brake lines and I know quite a few of the other track rats use them as well.
2019 SS 1LE BIG NA A10
Eagles Canyon Raceway 2.7 CCW Below
https://youtu.be/c9M5UHDftcA
4-15-23 at SCCA TT U1 Class
MEGA Thread on THIS car:
https://www.camaro6.com/forums/showthread.php?t=602092
Retired Cars BELOW:
1973 Camaro, 1969 Camaro, 1969 Camaro SS RS
2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10
sr71bb is offline   Reply With Quote
Old 05-08-2022, 08:13 AM   #6
TLSTWIN
Romans10:9-13
TLSTWIN's Avatar
Old 05-08-2022, 08:37 AM   #7
20Bluezl1
I wanted to buy the Carbon brake lines. I even placed the order and paid never received them and eventually got my money back. Most likely going to order some SS lines just looking to see what the best one to order.
20Bluezl1 is online now   Reply With Quote
Old 05-08-2022, 02:29 PM   #8
TLSTWIN
Romans10:9-13
TLSTWIN's Avatar
These are the only ones I have found.
https://www.phastekperformance.com/G...idge-12299.htm
Old 05-08-2022, 02:50 PM   #9
20Bluezl1
I found this one for ours also
https://www.essexparts.com/spiegler-...t-camaro-sszl1
Also found one for the CTS-V not sure if it fits are cars also.
https://www.renickperformance.com/pr...brake-line-kit
Old 05-08-2022, 02:56 PM   #10
TLSTWIN
Romans10:9-13
TLSTWIN's Avatar
I am very leary if someone hasn't made them for the specific car. the lengths can be too short, which is a problem. Thats why even in goodridge they have ones for the 6 piston and different ones for the 4 piston.
Spieglers are great, used those on my SV1000s and SV650S.
Old 05-08-2022, 07:31 PM   #11
synolimit
Drives: 22 ZL1 1LE A10
i find it hard to believe we buy a $7500 package and they cant add a $100 item onto the car from the factory. the 1LE 100% has crappy rubber lines?
synolimit is offline   Reply With Quote
Old 05-08-2022, 07:42 PM   #12
synolimit
makes no sense goodridge states for the 6 pot but then places that sell them say not for the 1LE. hows the zl1 and the 1le different in braking besides the no dust shield and the 2 piece front rotors?
FYI i emailed the contact for spieglers since they are in dayton ohio and do custom sets. im in ohio too.
Old 05-08-2022, 08:29 PM   #13
TLSTWIN
Romans10:9-13
TLSTWIN's Avatar
interested if spiegler gets back to you. I like their products as well.
The non 1le fitment refers to the ss 1LE if I recall. the location (top or bottom of the caliper) where the line connects between the 4 and 6 pistons makes a huge difference in length. I remember it being an issue on the 5th gen too.
Old 05-08-2022, 08:51 PM   #14
MatthewAMEL
MatthewAMEL's Avatar
Drives: 2023 CT5 Blackwing
They are a dress up item. They will make no difference in braking performance.
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
