04-20-2019, 05:34 PM | #1 |
Drives: 2018 ZL1 Hyper Blue A10 Join Date: Jan 2018
Trans or Rear End Issue?
I know I've come across other threads about this but can't find them.
Haven't driven the car for a couple of weeks and when I went to pull out of the garage nothing, reverse or forward. Turned it on and off couple of times hoping for an electronic glitch but still didn't work. Decided to give it one more try before disconnecting the battery. This time gave it a little gas and clunk, it sounded like it was breaking free from being stuck. Seemed to come more from the rear than the tranny. Took it around the block listening for anything out the ordinary but nothing and now everything seems fine. Is the something I need to worry about or get checked? |
04-20-2019, 05:38 PM | #2 |
Drives: 2010 camaro RS,2017 camaro 1Le Join Date: Mar 2016
Could have been the brakes sticking to rotor or tires sticking to garage floor did you park it wet?
2017 camaro 1le
ROTO fab, Ported MSD, Ported 95mm tb, 2in TSP catless longtubes, flowmaster x-pipe, flowmaster American thunder npp, flex fuel, |
04-20-2019, 05:39 PM | #3 |
Drives: A10 LT4 Join Date: Aug 2016
Did you wash it before putting it away...sounds like the break pads were sticking to me.
04-20-2019, 08:24 PM | #4 |
04-20-2019, 08:29 PM | #5 |
Oh man...pay attn the next time you wash her!! Those discs will be rust colored by the time you finish drying. Next time take it around the block after drying to skim the brakes clean & then you can dry off any streaks on the rest of the car.
04-20-2019, 10:43 PM | #6 |
Kevin
Drives: 2018 Callaway Camaro ZL1 1LE Join Date: Apr 2018
04-21-2019, 12:12 AM | #7 |
Drives: 2SS Hyper Blue Join Date: Jun 2018
parking brake on?
2018 Hyper Blue 2SS - SOLD
04-21-2019, 12:56 AM | #8 |
Drives: 2016 Hyper Blue 2SS Join Date: Feb 2016
Had the same thing happen to me right after washing it and parking it for a couple days. It's just the brakes getting unstuck. No need to get it checked.
2SS Hyper Blue Metallic | A8 | Jet Black Interior | NPP Exhaust
Current Mods: Catch Can | aFe Lowering Springs | GM 2nd Gen Splitter | Hotchkis Sway Bars | MRR FS02 Wheels | Flowmaster Exhaust | Dark Tail Lights | Diode Dynamics Sidemarkers | Roto Fab | Solar TB | PRAY Ported IM | BMR | PRAY Tune Upcoming Mods: |
04-21-2019, 07:22 AM | #9 |
Thank you Al Oppenheiser!
Then yes 99.9% it was stuck brake pads. The brake pads will bond to the rotors if they're put away wet. As said above, after washing just drive it around the block once to dry off the pads/rotors and you won't have the problem again.
04-21-2019, 11:24 AM | #10 |
Thanks for the info guys....
Haven't had an issue since the original occurrence. The noise was so loud I figured whatever happened it wasn't good. Lol |
