Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 10-12-2013, 01:28 PM   #1
Ladykiller
Drives: 2013 Camaro ZL1
Where to locate jackstands or blocks for winter storage?
I will be storing my ZL1 for the winter soon, and I need to know where the best location is on the ZL1 to locate wooden blocks or jackstands for the winter. I will be taking the tirings/rims off to store indoors for the winter. Any help? If it helps any, I'll upload an undercarriage picture later.
Ladykiller is offline
Old 10-12-2013, 02:54 PM   #2
kmthor00
Drives: 2013 ZL1 Black
Why is this necessary? I have been storing corvettes since 1996 & have never jacked them up, pump up a little extra psi in the tires is all.
kmthor00 is offline
Old 10-12-2013, 02:57 PM   #3
DanSSRS
Drives: 2011 Camaro 1SS RS
I believe its not advisable to let the suspension just hang like that all winter.
DanSSRS is offline
Old 10-12-2013, 03:48 PM   #4
Ladykiller
If neither of you know the answer to the question, why waste your time posting?
Old 10-12-2013, 03:55 PM   #5
montreal2010yellow
montreal2010yellow's Avatar
Drives: 2 LT/RS YELLOW, AUTO., VIN NO. 602
Because leaving the suspension loose for months will do more arm that letting the car sit with added air pressure. That's our 2cents.
T2 Facia, ACS TL1 Hood, ACS Winglets. G5CR CAI. Hotchsic Strut Brace and more...
montreal2010yellow is offline
Old 10-12-2013, 03:59 PM   #6
montreal2010yellow
But this might help. There are other videos, do a search.
Old 10-12-2013, 04:02 PM   #7
KlugSS
Guest
Posts: n/a
I would never advise someone to do this unless it's sitting for the rest of its life.
I would make sure your floor is 100% level in every direction. If it wasn't I could see it doing more harm then letting it sit on the wheels and tires.
Old 10-12-2013, 04:32 PM   #8
Skylane765
Skylane765's Avatar
Drives: ZL1-1LE, Z/28
Place the jack stands under the sub frame.
Skylane765 is offline
Old 10-12-2013, 04:40 PM   #9
Ladykiller
I never said anything about leaving the suspension loose. I'd prefer to be blocked up on the suspension.
Old 10-12-2013, 04:47 PM   #10
djnice
djnice's Avatar
Drives: 13 ZL1 SIM, 99 Z28 Black
I found this photo of the proper lifting points in the misc gallery at the Z1 registry. http://www.***********.com/gallery.php
Basically, you just lift on the front and rear subframes.
These look like a good jackstand option. http://jackpointjackstands.com/
Name:  ZL1 proper lifting points.jpg
2018 C7 Z06 - WGG, M7. / 2013 ZL1 - SIM, 6 spd, RotoFab CAI, Can. / 1999 Z28 - Black, 6 spd, K&N, Subframe. / More Fun Stuff - www.inlandspeed.com
djnice is offline
Old 10-12-2013, 05:24 PM   #11
roSSco
∞ Smiles per mile
roSSco's Avatar
Drives: 2013 ZL1 Summit White A6
Do you have to remove the belly pan to access the ones in the front?
2013 ZL1 #4739
'Heisenberg'
Color - Walter White
Roto-Fab CAI
On Reddit? Check out /r/ZL1/
roSSco is offline
Old 10-12-2013, 05:32 PM   #12
HDRDTD
I believe the OP's reason was to take the tires/wheels off to store them somewhere warm for the winter, thus the need to rest it on jack stands.
Goodyear issued a bulletin a long time ago regrading proper care of the ZL1 tires in which they stated, the tires should not be even STORED at temps below 20 degrees F.
I also take mine off for the winter and keep them in the basement.
Fortunately, I have an extra set of wheels/tires off my 2011 SS than I can put on while the car is in winter storage.
HDRDTD is offline
Old 10-12-2013, 07:17 PM   #13
Ladykiller
Hey, finally someone with some intelligence posted on this thread instead of just offering their $0.02 opinion.
Old 10-13-2013, 01:10 PM   #14
djnice
djnice's Avatar
No you dont have take the pan off to lift on those lift points.
djnice is offline
