10-01-2013, 12:52 AM | #1 |
Drives: 2013 ZL1 Black on black Join Date: Sep 2013
Wet driving!
I'm fixing to take a trip to hometown Jackson, Ms to show off new Z. IF it should rain, should I change to wet mode for better traction?? Thanks
Carol
10-01-2013, 12:53 AM | #2 |
Drives: 13 ZL1 | 13 SRT GC | 13 SRT CHARGER Join Date: Nov 2010
I've put mine in wet mode once, it behaved pretty well.
10-01-2013, 01:46 AM | #3 |
Drives: 13 ZL1 vert blac fastlane/LPE 750 Join Date: Jul 2011
I have driven my car only twice since i purchased it 3 weeks ago,and its got 612rwhp,and it drove fine in the rain since it rain and rained freaking hard both days i just left it in touring ,and just didnt get crazy or go fast in it.
http://www.camaro5.com/forums/showthread.php?t=346589 CHECK OUT THE BUILDING OF MY RANCH FOR DISABLED VETS, COMPLETE WITH A GUN RANGE .
10-01-2013, 07:53 AM | #4 |
Drives: Camaro ZL1 Join Date: May 2012
yes, use ptm1
2012 A6 Coupe 630RWHP 10.93@125
Mods: ID850 Injectors; D3PE HX, Reservoir & Atmospheric Catch-Can; LPE 2.55 Upper & 9.1 Lower Pulleys w/ ATI Damper; LPE Idler Pulley Relocation Bracket; "Green" Serp. Belt; Cat delete;ADM Exhaust Override; Magnaflow X-Pipe Muffler (in addition to stock mufflers); Cold Air Inductions CAI; 160 thermostat; LS9 Isolator; Port/polish snout and intake runners; LPE GT9 camshaft with dual springs and titanium retainers; Kenne Bell BAP, Install and Engine Tune by Serious Hp; Fab work by D3 Performance Engineering; Trans Tune by Keith; Coming Soon: Flex Fuel Conversion. |
10-01-2013, 08:23 AM | #5 |
IG @Brian_ _Self
Drives: 2010 Camaro 2SS M6+17'Tesla Model S Join Date: Nov 2012
Is the wet mode only on the ZL1s?
10-01-2013, 10:58 AM | #6 |
Drives: 13 ZL1 SIM, 99 Z28 Black Join Date: Feb 2013
You can just leave it in touring where it is when you start the car. I usually go to PTM1 for the fun of it and compare the difference. Both work fine.
2018 C7 Z06 - WGG, M7. / 2013 ZL1 - SIM, 6 spd, RotoFab CAI, Can. / 1999 Z28 - Black, 6 spd, K&N, Subframe. / More Fun Stuff - www.inlandspeed.com
10-01-2013, 11:26 AM | #7 | |
HAMMER PILOT
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado Join Date: Nov 2011
I would definitely run in wet mode in the rain. And also be careful! There have been many ZL1 accidents and some in the rain. 580HP and rain do not go well together, add those tires and you are set up for an accident waiting to happen. Respect the car!
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
10-01-2013, 11:48 AM | #8 |
Well said sven59,, RESPECT THE CAR!
10-01-2013, 12:01 PM | #9 |
Drives: SW 2017 ZL1, M6, Carbon, Nav, MR, Join Date: Dec 2012
I imagine it would suck to live in Seattle with this car. This car terrifies me in the rain. Even driving slow and respectfully at 55 mph in a 70 mph zone on the highway the rear end still wants to fishtail. Also the manual tells you that wet mode is not intended for anything other than light rain. I was a bit puzzled by that.
10-01-2013, 12:04 PM | #10 |
∞ Smiles per mile
Drives: 2013 ZL1 Summit White A6 Join Date: Jun 2009
How many miles on your tires? Are they the stock Goodyears? I can stay near 70 even in heavy rain with mine. Only about 6000 miles on them.
2013 ZL1 #4739
'Heisenberg' Color - Walter White Roto-Fab CAI On Reddit? Check out /r/ZL1/ |
10-01-2013, 12:13 PM | #11 |
Drives: 2013 ZL1 Join Date: Jun 2013
PTM1 is helpful if you have to pass, etc. If you have a manual and throw it down a gear and get on it to pass, you will go to ditch without PTM1. If you go hard you may end up in a ditch even with PTM1, cause the ZL1 is a badass!
10-01-2013, 12:21 PM | #12 | |
Drives: 2012 ZL1 - #670 Join Date: Jun 2009
10-01-2013, 12:23 PM | #13 |
Drives: ( . )( . ) Join Date: Feb 2010
10-01-2013, 01:46 PM | #14 | |
