08-09-2018, 01:12 AM | #1 |
Drives: ZL1 1LE SUMMIT WHITE Join Date: Feb 2018
What RPM. What gear for 6 spd man line-lock burnout?
Never tried it yet. Got a burnout contest this weekend and tempted to give it a shot.
2018 ZLE * StudioRSR Half Cage * SkidmarkGarage Rear Seat Delete * ZL1ADDONS Lift Pads * Roto-Fab CAI * Forgestar CF5-V's * Michelin PS4S * Racequip 6 Pt. Harnesses * Sub-strap Brackets by Carmena Performance * Speedhut Shift Light * Leroy Eng. Hidden Hitch (for the TYR RAT)* Gen5DIY Rapid Flash 3rd Brake Light * KOOKS 2" LT * Green Cats * AWE Cat-back Track Edition *
________________________________________ 2005 NISSAN TITAN 1997 BMW E39 (Thug In A Suit) R.I.P. 10/04/18 2002 MAZDA Protege 5 (Time Attack, Hillclimb) SOLD |
08-10-2018, 08:24 AM | #2 |
Drives: 2016 1SS 6speed Join Date: Mar 2016
Whatever RPM you choose. The higher the RPM, the more the tires spin, the more smoke.
I do my burnouts in second gear at the track. I’m pretty sure you’ll have enough power to do a third gear burnout, as long as they give you a bit of water to start with.
2016 1SS M6 P1SC Stg II 592rwhp/548rwtq (for now)
GForce Outlaw axles & driveshaft, TSP 2” LT’s, turndowns, RTS S71 drag pack with radials. |
08-10-2018, 09:16 AM | #3 |
Drives: 2019 2SS & 1998 SS Join Date: Jul 2017
A burnout contest in a 70k dollar car? Not what I would do with it, but to each their own I suppose. Hopefully the winnings are worth a pair of tires at least. I wouldn't go out there and blow my tires and risk trashing my car for that though...and that's probably the only way you'll win it.
08-10-2018, 10:26 AM | #4 |
Drives: 2017 Camaro 2SS Join Date: Mar 2017
at the strip i line lock in 2nd and fry away and hold around 3500ish. then let it go and power through it.
2017 NGM 2SS NPP M6 MRC Vortech SC, 2" TSP LT No Cats, Borla X, Eibach, Hurst shifter 603hp/547tq |
08-10-2018, 11:50 PM | #5 |
Common sense prevailed and I just spectated. Good info tho! Thanks.
08-23-2018, 02:44 PM | #6 |
The higher gear you're in the more tire spin too.
