Old 08-22-2020, 01:12 PM   #1
camarodoob1
camarodoob1's Avatar
Drives: 2011 2SS
Supercharger preference
I have seen a lot of differing opinions on Maggie vs. Whipple vs. Centrifugal, etc.
I have a 2011 LS3, with cold air, 1 7/8 Stainless Power longtubes with hi flo cats, and StainlessWorks Retro Chambered with rdp remote tune.
About ready to pull the trigger on forced induction, just want to get everyone's thoughts. I want as much power possible without grenading the bottom end or drivetrain. What direction would you guys recommend?
camarodoob1 is offline   Reply With Quote
Old 08-22-2020, 01:14 PM   #2
Vegas Bound
Drives: 2013 Sparkly Red One
I'd say get a LSA or maybe a ProCharger or a Kong or a Heartbeat.
Vegas Bound is offline   Reply With Quote
Old 08-22-2020, 01:50 PM   #3
Yellow 1
Grumpy Grey-haired Guy
Yellow 1's Avatar
Drives: Camaro, Corvette & Merc C300(daily)
Got a Heartbeat couple of years back. No issues with it. 700+ at the crank. Puppy in traffic, animal when you get on it. Reasonable gas mileage (if that's a concern) well-designed and great looking. Lotta people look under my hood and can't believe it's not a factory-installed option; it looks THAT good.
All the boosted guys rave about what they have fitted on their own rides, I'm no different. Bottom line is - boost is best!
Yellow 1 is offline   Reply With Quote
Old 08-22-2020, 01:52 PM   #4
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2011 2SS/RS/A6 cammed-n-whippled
With the manual trans, I'd go for a centri (I had an ECS Paxton novi kit on mine, made 623rwhp, only other real mod was LT headers and hi flow cats). It wasn't too harsh on the drivetrain and traction was less of an issue, because boost builds with rpm.
NY5thgen.com
POWERFREAK is offline   Reply With Quote
Old 08-22-2020, 02:17 PM   #5
fireman1153
Drives: 2010 Camaro SS
Procharger has a lot of options to choose from and the centri route will definitely be more driver friendly and easier on drivetrain parts.
2010 Camaro 2SS/RS - 416 stroker, F1A-94 procharger, BTR blower cam, Big Red race valve, AGP intercooler, Alky dual nozzle kit, ZL1 fuel pump with DSX Aux pump, DSX flex fuel sensor, Bosch 210 injectors, Mcleod RXT1200 clutch, MGW flat stick, Tick Performance Level 3 trans, DSS 3.5 aluminum driveshaft, Strange S60 rear, DSS 1400hp axles, Texas speed 1 7/8 headers, X-pipe and MBRP muffler delete, BMR lowering springs, BMR trailing arms and toe rods, Poly motor mounts, RevShift trans mount instert, rear sub frame braces, Tuned by Joey at Pure Fabrication in Panama City, FL
fireman1153 is offline   Reply With Quote
Old 08-22-2020, 03:56 PM   #6
Mauimax3
Mauimax3
Mauimax3's Avatar
Drives: 2013 Camaro SS
Maggie here...love it. Easy to install. Just had it Dyno'd.. https://youtu.be/Nx6IRNnqqLI
Good luck with your decision.
Magnuson Supercharger, ZL-1 Fuel Pump, Kenny Belle Boost-a-Pump, Kook's LongTube, BTR Stage II, Trunion upgrade, ATI Superdampner, Nick Williams 102mm, Elite Eng. Can, Borla ATAK exhaust w/flow thru cats, CAI box. BMR Suspension upgrades. Dr Phil tuned.
Mauimax3 is offline   Reply With Quote
Old 08-22-2020, 04:02 PM   #7
Silver14
Drives: 2014 SIM 2SS
If you're only criteria is the most power on the stock bottom end, have you considered turbos?
Silver14 is offline   Reply With Quote
Old 08-22-2020, 04:52 PM   #8
Bo White
Bo White's Avatar
Drives: 2015 Summit White 2SS 1LE
Centri blowers are rpm dependant meaning boost builds with rpm.
Positive displacement blowers are same amount of boost no matter the rpm for the most part.
Bo White is offline   Reply With Quote
Old 08-22-2020, 07:32 PM   #9
camarodoob1
Drives: 2011 2SS
Not opposed to turbo either, have just always heard they are complicated. I was just looking at the Turbonetics single 76. Is it as simple to install as they claim?
Old 08-22-2020, 07:44 PM   #10
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
Pro chargers can get noisy but also probably give one of the best options to get more boost if you wanted too.
Whipples seem to be more daily driver friendly
I never owned either just going off of what I’ve heard
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
Bigdumogre is offline   Reply With Quote
Old 08-22-2020, 08:58 PM   #11
hammdo
'It's an experiment'
hammdo's Avatar
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE
LSA has been good to me...
-Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari
See My Build: http://www.camaro5.com/forums/showthread.php?t=385577
hammdo is offline   Reply With Quote
Old 08-22-2020, 10:55 PM   #12
Speeddmn
Drives: Chevy Silverado
I have a vortech v2 on a mustang and enjoy it. Bought the car that way. If I did forced induction again it would be roots style. I feel they look better and keep the engine bay cleaner also.
Performance wise they all are great now. Turbo is always an option but again I feel it clutters the engine
Speeddmn is offline   Reply With Quote
Old 08-22-2020, 11:53 PM   #13
Js2fst
2010 transformer
Js2fst's Avatar
Drives: 2010 ss camaro
Procharger or lsa but look at how many failures and rebuilds the others have
2010 transformer, vertical doors, 315nt05 rears, pedders supercar coilovers, hotchkis sway bars, links, adjustable, toe bars, bmr poly cradle bushings, 1le control arms, bmr tunnel brace, bmr subframe connectors. Cam 227/239-623-620@114 Mast medium bore heads, sw 1 7/8 headers, cat delete, x pipe, 3" dynomax true duals, fuel rails, fast 102 intake and NW 102 throttle body, catch can, rotofab cai, shifter, raptor custom shift light. Dss drive shaft, 3.91 gears. 492 rwhp
Js2fst is offline   Reply With Quote
Old 08-23-2020, 05:51 AM   #14
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
Turbos are simple and make more power per pound of boost as its not parasitic. Id go with the agp twin kit in a heartbeat for a daily. No changing pulleys for different boost levels, no belt slip issues, and they just sound amazing lol.
12 camaro ss 427lsx, th400, f310 heads, crower shaft mounts, gpi specd solid roller, shearerfab 2k hp a/w, twin bullseye 88mm turbos, hughes pro ssx bolt together converter, holley dominator, 8.50 cert, backhalf, Ford 9", 33x17x16 tires, c16 fuel
ttshovel is offline   Reply With Quote
