Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
Old 08-29-2018, 06:41 PM   #1
Buddy2
Buddy2's Avatar
Drives: 2012 camaro convertible 45th Ed.
Fuse Pull Trick?
Does this trick apply to the 2012 model, or did GM fix the problem by then?
Thanks in advance.
CAI Intake, MagnaFlow Exhaust
Buddy2 is offline   Reply With Quote
Old 08-29-2018, 06:44 PM   #2
Nb1081
Drives: 10 2ss/rs
Pull em and find out but if you run premium fuel probably wont do anything
[/SIGPIC]10 2ss ls3 sw long tubes,cai intake,phastek scoop,se3" exhaust,elite e2, bw stg2tb, tsp f35, motive 4.10 lpw cover, 15" conversion, 510whp tuned by john donovan
Nb1081 is offline   Reply With Quote
Old 08-29-2018, 06:50 PM   #3
Spec
Drives: 2010 Camaro 1SS LS3
Since your sig says Magnaflow, then I assume you mean the 5 and 20?
Its not really a problem, its how these cars manage the different octanes of fuel out in the wild.
The mapping/timing is adjusted depending on the type of fuel you're using. I guess you can call it a problem since it all doesn't revert automatically back to higher octane mapping once the lower octane is gone, and you've refueled with premium.
This works all the way through the 15's I believe...
Spec is offline   Reply With Quote
Old 08-30-2018, 07:11 PM   #4
pincoin
Camaro owner since 1982
pincoin's Avatar
Drives: 2012 Camaro 2SS-RS Conv IBM L99
Thanks in advance.
This only works on V8 cars
2012 Camaro RS-SS Conv IBM, L99
1968 Camaro RS Coupe 327 AT
1968 Camaro RS-SS Conv, sold 1993
pincoin is offline   Reply With Quote
Old 08-31-2018, 05:56 AM   #5
Texas5thGen
Drives: 2012 2SS-RS L99
I did it on my 2012 that I bought used. It had been running 89 for however long the guy could remember. I then filled her up with 93 and did the fuse pull. It does make a difference for sure, but taper you expectations. Your car won't suddenly feel like 500 to the wheels but it absolutely works. I believe it's also mainly an L99 thing but LS3 owners do report it works on theirs as well.
Texas5thGen is offline   Reply With Quote
Old 08-31-2018, 08:34 AM   #6
Overflow
Space Shuttle Aficionado
Overflow's Avatar
The fuse pull only works on 2010's and 2011's. The "bug" was fixed on 2012 and 2013 MYs.
Overflow is offline   Reply With Quote
Old 08-31-2018, 08:53 AM   #7
qcman
qcman's Avatar
Drives: 2013 Camaro 2SS RDP Tuned L99
The fuse pull only works on 2010's and 2011's. The "FEATURE" was fixed on 2012 and 2013 MYs.
I fixed it for you LOL. Really I hadn't heard it was fixed I thought my car was affected still. Thx!
qcman is offline   Reply With Quote
Old 08-31-2018, 09:47 AM   #8
Spurshot
Drives: 2014 2SS blue
Wheres the fuse again? I forgot.
Spurshot is offline   Reply With Quote
Old 08-31-2018, 09:59 AM   #9
Nb1081
Drives: 10 2ss/rs
Fuse panel under the hood #5&#20 fuse id is on bottom of lid pull em out over night
Old 08-31-2018, 10:04 AM   #10
Spec
Make sure you've refeuled a few times with premium, and that the low octane fuel is complete gone before you do so......
Still not sure how this affects you if you're tuned, though.......... its been one of those things no one's been able to answer. I guess it would depend on the tune, and how often you reflash your system? Dunno...
Old 08-31-2018, 10:59 AM   #11
Royal Tiger
I noticed a difference doing it on my 2013 when I bought it.
Old 08-31-2018, 11:42 AM   #12
StingrayblueSS
StingrayblueSS's Avatar
Drives: 2013 Camaro SS
It's not a bug. It's to protect the engine in case someone uses low octane fuel.
StingrayblueSS is offline   Reply With Quote
Old 08-31-2018, 12:47 PM   #13
HyperV117
HyperV117's Avatar
I remember asking DynoSteve about this. I asked him if he could just "delete" the low octane table but I recall him saying something like "that's not possible" or "that's not how that works".
HyperV117 is offline   Reply With Quote
